[GRASS-SVN] r34851 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules vdigit
svn_grass at osgeo.org
Sat Dec 13 11:44:33 EST 2008
Author: martinl
Date: 2008-12-13 11:44:33 -0500 (Sat, 13 Dec 2008)
New Revision: 34851
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp
grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp
wxGUI/vdigit: fix select features by cat (layer>1)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-12-13 16:16:54 UTC (rev 34850)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-12-13 16:44:33 UTC (rev 34851)
@@ -1094,7 +1094,7 @@
if digitToolbar and digitToolbar.GetLayer() and \
digitToolbar.GetLayer().GetName() == self.vectmap:
- self.mapdisplay.digit.driver.SetSelected(cats, cats=True)
+ self.mapdisplay.digit.driver.SetSelected(cats, field=self.layer)
if zoom:
n, s, w, e = self.mapdisplay.digit.driver.GetRegionSelected()
self.mapdisplay.Map.GetRegion(n=n, s=s, w=w, e=e,
@@ -1904,7 +1904,7 @@
digitToolbar = self.mapdisplay.toolbars['vdigit']
- self.mapdisplay.digit.driver.SetSelected(map(int, cats), cats=True)
+ self.mapdisplay.digit.driver.SetSelected(map(int, cats), field=self.layer)
self.mapdisplay.digit.DeleteSelectedLines()
else:
gcmd.Command(['v.edit',
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2008-12-13 16:16:54 UTC (rev 34850)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2008-12-13 16:44:33 UTC (rev 34851)
@@ -913,16 +913,16 @@
return id
- def SetSelected(self, id, cats=False):
+ def SetSelected(self, id, field=-1):
"""Set selected vector features
- @param id line id to be selected
- @param cats if True expect categories instead of feature ids
+ @param id list of feature ids/categories to be selected
+ @param field field(layer) number, -1 for ids instead of cats
Debug.msg(4, "CDisplayDriver.SetSelected(): id=%s" % \
id)
- self.__display.SetSelected(id, cats)
+ self.__display.SetSelected(id, field)
def UnSelect(self, id):
"""Unselect vector features
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp 2008-12-13 16:16:54 UTC (rev 34850)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp 2008-12-13 16:44:33 UTC (rev 34851)
@@ -42,7 +42,8 @@
points = Vect_new_line_struct();
pointsScreen = new wxList();
cats = Vect_new_cats_struct();
+ selected.field = -1;
selected.cats = Vect_new_list();
selected.ids = Vect_new_list();
selected.idsDupl = Vect_new_list();
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2008-12-13 16:16:54 UTC (rev 34850)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2008-12-13 16:44:33 UTC (rev 34851)
@@ -48,9 +48,10 @@
struct _selected {
- struct ilist *cats;
- struct ilist *ids;
- struct ilist *idsDupl;
+ int field; // field number
+ struct ilist *cats; // list of cats
+ struct ilist *ids; // list of ids
+ struct ilist *idsDupl; // list of duplicated features
} selected;
bool drawSelected;
@@ -191,7 +192,7 @@
std::map<int, std::vector<double> > GetSelectedCoord();
std::map<int, std::vector <int> > GetDuplicates();
std::vector<double> GetRegionSelected();
- int SetSelected(std::vector<int>, bool);
+ int SetSelected(std::vector<int>, int);
int UnSelect(std::vector<int>);
std::vector<int> GetSelectedVertex(double, double, double);
void DrawSelected(bool);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp 2008-12-13 16:16:54 UTC (rev 34850)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver_draw.cpp 2008-12-13 16:44:33 UTC (rev 34851)
@@ -173,6 +173,7 @@
/* reset list of selected features by cat
-> list of ids - see IsSelected()
Vect_reset_list(selected.cats);
Vect_destroy_list(listLines);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp 2008-12-13 16:16:54 UTC (rev 34850)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver_select.cpp 2008-12-13 16:44:33 UTC (rev 34851)
@@ -196,7 +196,7 @@
else { /* select by cat */
for (int i = 0; i < cats->n_cats; i++) {
- if (cats->field[i] == 1 && /* TODO: field */
+ if (cats->field[i] == selected.field &&
Vect_val_in_list(selected.cats, cats->cat[i])) {
/* remember id
-> after drawing all features selected.cats is reseted */
@@ -337,19 +337,23 @@
\brief Set selected vector objects
- \param[in] list of GRASS ids to be set
- \param[in] cat if True expect categories instead of feature ids
+ \param id list of feature ids to be set
+ \param field field number (-1 for ids instead of cats)
\return 1
-int DisplayDriver::SetSelected(std::vector<int> id, bool cat)
+int DisplayDriver::SetSelected(std::vector<int> id, int field)
drawSelected = true;
- if (cat)
+ if (field > 0) {
+ selected.field = field;
VectorToList(selected.cats, id);
- else
+ else {
+ field = -1;
VectorToList(selected.ids, id);
if (id.size() < 1)
drawSegments = false;
