[GRASS-SVN] r34859 - grass-addons/raster/r.pack
svn_grass at osgeo.org
Sat Dec 13 23:18:23 EST 2008
Author: hamish
Date: 2008-12-13 23:18:23 -0500 (Sat, 13 Dec 2008)
New Revision: 34859
Added:
grass-addons/raster/r.pack/r.pack.mat
grass-addons/raster/r.pack/r.unpack.mat
Removed:
rename away old MAT versions of r.pack
Deleted: grass-addons/raster/r.pack/r.pack
--- grass-addons/raster/r.pack/r.pack 2008-12-14 04:17:03 UTC (rev 34858)
+++ grass-addons/raster/r.pack/r.pack 2008-12-14 04:18:23 UTC (rev 34859)
@@ -1,88 +0,0 @@
-#!/bin/sh
-# r.pack -- pack up a raster map:
-# r.out.mat file + support files => gzip
-# (c) 2004 GRASS Development Team
-# AUTHOR: Hamish Bowman, Otago University, New Zealand
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Packs up a raster map and support files for copying
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Name of an existing raster map
-#% required : yes
-#%end
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
-fi
-# check for tar (is there a better way?)
-if [ -z "`which tar`" ] ; then
- echo "ERROR: tar must be installed to use this program."
- exit 1
-fi
-# check for gzip
-if [ -z "`which gzip`" ] ; then
- echo "ERROR: gzip must be installed to use this program."
- exit 1
-fi
-# create temporary directory to hold bits
-TMP_DIR="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP_DIR" ] ; then
- echo "ERROR: unable to create temporary files" 1>&2
- exit 1
-fi
-rm -f "$TMP_DIR"
-mkdir "$TMP_DIR"
-if [ ! -d "$TMP_DIR" ] ; then
- echo "ERROR: unable to create temporary directory" 1>&2
- exit 1
-fi
-# output map
-r.out.mat input="$GIS_OPT_INPUT" output="$TMP_DIR"/map.mat
-# copy support files
-for SUPPORT in colr hist cats ; do
- eval `g.findfile element=$SUPPORT file="$GIS_OPT_INPUT"`
- if [ ! -z "$file" ] ; then
- cp "$file" "$TMP_DIR"/$SUPPORT
- fi
-done
-# copy projection info
-# (would prefer to use g.proj*, but this way is 5.3 and 5.7 compat)
-eval `g.gisenv`
-cp "$GISDBASE"/"$LOCATION_NAME"/PERMANENT/PROJ_INFO "$TMP_DIR"/proj_info
-# pack it all up
-OLD_DIR="`pwd`"
-cd "$TMP_DIR"/
-tar czf "$OLD_DIR"/"$GIS_OPT_INPUT".pack *
-# clean up
-cd "$OLD_DIR"
-rm -rf "$TMP_DIR"
-echo Finished.
-exit 0
Copied: grass-addons/raster/r.pack/r.pack.mat (from rev 34846, grass-addons/raster/r.pack/r.pack)
--- grass-addons/raster/r.pack/r.pack.mat (rev 0)
+++ grass-addons/raster/r.pack/r.pack.mat 2008-12-14 04:18:23 UTC (rev 34859)
@@ -0,0 +1,88 @@
+#!/bin/sh
+# r.pack -- pack up a raster map:
+# r.out.mat file + support files => gzip
+# (c) 2004 GRASS Development Team
+# AUTHOR: Hamish Bowman, Otago University, New Zealand
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Packs up a raster map and support files for copying
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Name of an existing raster map
+#% required : yes
+#%end
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+# check for tar (is there a better way?)
+if [ -z "`which tar`" ] ; then
+ echo "ERROR: tar must be installed to use this program."
+ exit 1
+fi
+# check for gzip
+if [ -z "`which gzip`" ] ; then
+ echo "ERROR: gzip must be installed to use this program."
+ exit 1
+fi
+# create temporary directory to hold bits
+TMP_DIR="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP_DIR" ] ; then
+ echo "ERROR: unable to create temporary files" 1>&2
+ exit 1
+fi
+rm -f "$TMP_DIR"
+mkdir "$TMP_DIR"
+if [ ! -d "$TMP_DIR" ] ; then
+ echo "ERROR: unable to create temporary directory" 1>&2
+ exit 1
+fi
+# output map
+r.out.mat input="$GIS_OPT_INPUT" output="$TMP_DIR"/map.mat
+# copy support files
+for SUPPORT in colr hist cats ; do
+ eval `g.findfile element=$SUPPORT file="$GIS_OPT_INPUT"`
+ if [ ! -z "$file" ] ; then
+ cp "$file" "$TMP_DIR"/$SUPPORT
+ fi
+done
+# copy projection info
+# (would prefer to use g.proj*, but this way is 5.3 and 5.7 compat)
+eval `g.gisenv`
+cp "$GISDBASE"/"$LOCATION_NAME"/PERMANENT/PROJ_INFO "$TMP_DIR"/proj_info
+# pack it all up
+OLD_DIR="`pwd`"
+cd "$TMP_DIR"/
+tar czf "$OLD_DIR"/"$GIS_OPT_INPUT".pack *
+# clean up
+cd "$OLD_DIR"
+rm -rf "$TMP_DIR"
+echo Finished.
+exit 0
Deleted: grass-addons/raster/r.pack/r.unpack
--- grass-addons/raster/r.pack/r.unpack 2008-12-14 04:17:03 UTC (rev 34858)
+++ grass-addons/raster/r.pack/r.unpack 2008-12-14 04:18:23 UTC (rev 34859)
@@ -1,116 +0,0 @@
-#!/bin/sh
-# r.unpack -- unpack up a raster map packed with r.pack:
-# tar+gzip => r.in.mat + support files
-# for details.
-#%Module
-#% description: UnPacks a raster map packed with r.pack
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: file,file,file
-#% description: Name of an existing pack file
-#% required : yes
-#%end
-#%flag
-#% key: o
-#% description: Override projection (use location's projection)
-#%end
- exit 1
-fi
-fi
- exit 1
-fi
-# check for gzip
- exit 1
-fi
-eval `g.gisenv`
-MSET_DIR="$GISDBASE/$LOCATION_NAME/$MAPSET"
-if [ ! -e "$GIS_OPT_INPUT" ] ; then
- echo "ERROR: file not found [$GIS_OPT_INPUT]"
- exit 1
-fi
-# remove .pack and path from $GIS_OPT_INPUT
-MAP_NAME="`basename "$GIS_OPT_INPUT" | sed -e 's/\.pack$//'`"
-echo "The imported map will be named [$MAP_NAME]."
-eval `g.findfile element=cell file="$MAP_NAME"`
-if [ ! -z "$file" ] ; then
- echo "ERROR: '$MAP_NAME' already exists."
- exit 1
-fi
- exit 1
-fi
-rm -f "$TMP_DIR"
-mkdir "$TMP_DIR"
- exit 1
-fi
-cp "$GIS_OPT_INPUT" "$TMP_DIR"/
-cd "$TMP_DIR"/
-tar xzf "`basename $GIS_OPT_INPUT`"
-# check projection compatibility in a rather crappy way
-if [ ! -z "`diff proj_info "$MSET_DIR"/../PERMANENT/PROJ_INFO`" ] ; then
- if [ $GIS_FLAG_O -eq 1 ] ; then
- echo "WARNING: Projection information does not match. Proceeding.."
- else
- echo "ERROR: Projection information does not match. Aborting."
- # clean up
- cd "$MSET_DIR"
- rm -rf "$TMP_DIR"
- exit 1
- fi
-fi
-r.in.mat input=map.mat output="$MAP_NAME"
- if [ -e $SUPPORT ] ; then
- cp $SUPPORT "$MSET_DIR"/$SUPPORT/"$MAP_NAME"
- fi
-done
-# clean up
-cd "$MSET_DIR"
-rm -rf "$TMP_DIR"
-echo Finished.
-exit 0
Copied: grass-addons/raster/r.pack/r.unpack.mat (from rev 34858, grass-addons/raster/r.pack/r.unpack)
--- grass-addons/raster/r.pack/r.unpack.mat (rev 0)
+++ grass-addons/raster/r.pack/r.unpack.mat 2008-12-14 04:18:23 UTC (rev 34859)
@@ -0,0 +1,116 @@
+#!/bin/sh
+# r.unpack -- unpack up a raster map packed with r.pack:
+# tar+gzip => r.in.mat + support files
+# for details.
+#%Module
+#% description: UnPacks a raster map packed with r.pack
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: file,file,file
+#% description: Name of an existing pack file
+#% required : yes
+#%end
+#%flag
+#% key: o
+#% description: Override projection (use location's projection)
+#%end
+ exit 1
+fi
+fi
+ exit 1
+fi
+# check for gzip
+ exit 1
+fi
+eval `g.gisenv`
+MSET_DIR="$GISDBASE/$LOCATION_NAME/$MAPSET"
+if [ ! -e "$GIS_OPT_INPUT" ] ; then
+ echo "ERROR: file not found [$GIS_OPT_INPUT]"
+ exit 1
+fi
+# remove .pack and path from $GIS_OPT_INPUT
+MAP_NAME="`basename "$GIS_OPT_INPUT" | sed -e 's/\.pack$//'`"
+echo "The imported map will be named [$MAP_NAME]."
+eval `g.findfile element=cell file="$MAP_NAME"`
+if [ ! -z "$file" ] ; then
+ echo "ERROR: '$MAP_NAME' already exists."
+ exit 1
+fi
+ exit 1
+fi
+rm -f "$TMP_DIR"
+mkdir "$TMP_DIR"
+ exit 1
+fi
+cp "$GIS_OPT_INPUT" "$TMP_DIR"/
+cd "$TMP_DIR"/
+tar xzf "`basename $GIS_OPT_INPUT`"
+# check projection compatibility in a rather crappy way
+if [ ! -z "`diff proj_info "$MSET_DIR"/../PERMANENT/PROJ_INFO`" ] ; then
+ if [ $GIS_FLAG_O -eq 1 ] ; then
+ echo "WARNING: Projection information does not match. Proceeding.."
+ else
+ echo "ERROR: Projection information does not match. Aborting."
+ # clean up
+ cd "$MSET_DIR"
+ rm -rf "$TMP_DIR"
+ exit 1
+ fi
+fi
+r.in.mat input=map.mat output="$MAP_NAME"
+ if [ -e $SUPPORT ] ; then
+ cp $SUPPORT "$MSET_DIR"/$SUPPORT/"$MAP_NAME"
+ fi
+done
+# clean up
+cd "$MSET_DIR"
+rm -rf "$TMP_DIR"
+echo Finished.
+exit 0
