[GRASS-SVN] r34861 - grass-addons/raster/r.pack
Sat Dec 13 23:20:48 EST 2008
Author: hamish
Date: 2008-12-13 23:20:48 -0500 (Sat, 13 Dec 2008)
New Revision: 34861
Removed:
   grass-addons/raster/r.pack/r.pack2
   grass-addons/raster/r.pack/r.unpack2
rename new element versions of r.pack2 to r.pack name
Deleted: grass-addons/raster/r.pack/r.pack2
--- grass-addons/raster/r.pack/r.pack2	2008-12-14 04:20:20 UTC (rev 34860)
+++ grass-addons/raster/r.pack/r.pack2	2008-12-14 04:20:48 UTC (rev 34861)
@@ -1,133 +0,0 @@
-#!/bin/sh
-#  r.pack   --  pack up a raster map:
-#     collect raster map elements => gzip
-#   (c) 2004-2008 GRASS Development Team
-#   AUTHOR: Hamish Bowman, Otago University, New Zealand
-#   This program is free software under the GNU General Public
-#   License (>=v2). Read the file COPYING that comes with GRASS
-#   for details.
-#%Module
-#%  description: Packs up a raster map and support files for copying
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Name of an existing raster map
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new_file,file,output
-#% description: Name for output file (default is input-map.pack)
-#% required : no
-#%end
-if [ -z "$GISBASE" ] ; then
-   echo "You must be in GRASS GIS to run this program." >&2
-   exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-  exec g.parser "$0" "$@"
-fi
-# check for tar  (is there a better way?)
-if [ -z "`which tar`" ] ; then
-   echo "ERROR: tar must be installed to use this program."
-   exit 1
-fi
-# check for gzip
-if [ -z "`which gzip`" ] ; then
-   echo "ERROR: gzip must be installed to use this program."
-   exit 1
-fi
-if [ -n "$GIS_OPT_OUTPUT" ] ; then
-   outfile="$GIS_OPT_OUTPUT"
-else
-   outfile="$GIS_OPT_INPUT.pack"
-fi
-#be overly helpful
-outfile="`basename "$outfile" .pack`.pack"
-eval `g.findfile elem=cell file="$GIS_OPT_INPUT"`
-if [ -z "$name" ] ; then
-   g.message -e "Map not found"
-   exit 1
-fi
-# create temporary directory to hold bits
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
-   g.message -e "Unable to create temporary files"
-fi
-rm -f "$TMP"
-mkdir "$TMP"
-TMP_DIR="$TMP/$name"
-mkdir "$TMP_DIR"
-if [ ! -d "$TMP_DIR" ] ; then
-   g.message -e "Unable to create temporary directory"
-   exit 1
-fi
-BASEDIR=`echo "$file" | sed -e 's+/cell/.*$++'`
-OLDDIR=`pwd`
-for ELEMENT in cats cell cellhd colr fcell grid3 hist ; do
-    if [ -e "$BASEDIR/$ELEMENT/$GIS_OPT_INPUT" ] ; then
-	cp "$BASEDIR/$ELEMENT/$name" "$TMP_DIR/$ELEMENT"
-    fi
-done
-if [ -d "$BASEDIR/cell_misc/$GIS_OPT_INPUT/" ] ; then
-    mkdir "$TMP_DIR/cell_misc/"
-    cp "$BASEDIR/cell_misc/$name/"* "$TMP_DIR/cell_misc/"
-fi
-if [ -z "`ls $TMP_DIR`" ] ; then
-   g.message -e "No map components found"
-   exit 1
-fi
-# copy projection info
-#   (would prefer to use g.proj*, but this way is 5.3 and 5.7 compat)
-eval `g.gisenv`
-for SUPPORT in INFO UNITS ; do
-   if [ -e "$GISDBASE/$LOCATION_NAME/PERMANENT/PROJ_$SUPPORT" ] ; then
-       cp "$GISDBASE/$LOCATION_NAME/PERMANENT/PROJ_$SUPPORT" "$TMP_DIR"
-   fi
-done
-# pack it all up
-cd "$TMP"
-tar czf "$outfile" *
-# clean up
-mv "$outfile" "$OLDDIR/"
-if [ $? -ne 0 ] ; then
-   g.message -e "Saving file to <$OLDDIR/$outfile>"
-   rm -rf "$TMP"
-   exit 1
-fi
-cd "$OLD_DIR"
-rm -rf "$TMP"
-g.message -v "Done. Map saved to <$OLDDIR/$outfile>"
-exit 0
Deleted: grass-addons/raster/r.pack/r.unpack2
--- grass-addons/raster/r.pack/r.unpack2	2008-12-14 04:20:20 UTC (rev 34860)
+++ grass-addons/raster/r.pack/r.unpack2	2008-12-14 04:20:48 UTC (rev 34861)
@@ -1,162 +0,0 @@
-#!/bin/sh
-#  r.unpack   --  unpack up a raster map packed with r.pack:
-#     tar+gzip'd map elements => GRASS 6 mapset structure
-#   for details.
-#%Module
-#%  description: UnPacks a raster map packed with r.pack
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old_file,file,input
-#% description: Name of an existing pack file
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
-#% description: Output raster map (default: taken from input file internals)
-#% required : no
-#%end
-#%flag
-#%  key: o
-#%  description: Override projection check (use current location's projection)
-#%end
-   exit 1
-fi
-fi
-# check for tar,gzip
-for PRGM in tar gzip ; do
-   if [ -z "`which $PRGM`" ] ; then
-      g.message -e "$PRGM must be installed to use this program."
-      exit 1
-   fi
-done
-if [ -z "$GRASS_OVERWRITE" ] ; then
-   GRASS_OVERWRITE=0
-fi
-if [ ! -e "$GIS_OPT_INPUT" ] ; then
-   g.message -e "File not found <$GIS_OPT_INPUT>"
-   exit 1
-fi
-eval `g.gisenv`
-MSET_DIR="$GISDBASE/$LOCATION_NAME/$MAPSET"
-TMP_DIR="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP_DIR" ] ; then
-   exit 1
-fi
-rm -f "$TMP_DIR"
-mkdir "$TMP_DIR"
-   exit 1
-fi
-cleanup()
-   g.message -v "Cleaning up ..."
-   cd "$MSET_DIR"
-   rm -rf "$TMP_DIR"
-#### trap ctrl-c so that we can clean up tmp
-trap 'cleanup' 2 3 15
-cp "$GIS_OPT_INPUT" "$TMP_DIR"/
-cd "$TMP_DIR"/
-# remove .pack and path from $GIS_OPT_INPUT
-#MAP_NAME="`basename "$GIS_OPT_INPUT" | sed -e 's/\.pack$//'`"
-INPUT_BASE=`basename $GIS_OPT_INPUT`
-DATA_NAME=`tar tzf "$INPUT_BASE" | head -n 1 | cut -f1 -d'/'`
-if [ -z "$DATA_NAME" ] ; then
-   g.message -e "Pack file unreadable"
-   cleanup
-   exit 1
-fi
-if [ -z "$GIS_OPT_OUTPUT" ] ; then
-   MAP_NAME="$DATA_NAME"
-else
-   MAP_NAME="$GIS_OPT_OUTPUT"
-fi
-eval `g.findfile element=cell file="$MAP_NAME" mapset=.`
-if [ ! -z "$file" ] && [ "$GRASS_OVERWRITE" -ne 1 ] ; then
-   g.message -e "Raster map <$MAP_NAME> already exists"
-   cleanup
-   exit 1
-fi
-# extract data
-tar xzf "$INPUT_BASE"
-   cleanup
-   exit 1
-fi
-cd "$DATA_NAME"/
-# check projection compatibility in a rather crappy way
-if [ ! -z `diff PROJ_INFO "$MSET_DIR"/../PERMANENT/PROJ_INFO` ] ; then
-    if [ $GIS_FLAG_O -eq 1 ] ; then
-        g.message -w "Projection information does not match. Proceeding.."
-    else
-        g.message -e "Projection information does not match. Aborting."
-        cleanup
-        exit 1
-    fi
-fi
-# install in $MAPSET
-    if [ -e "$ELEMENT" ] ; then
-	if [ ! -d "$MSET_DIR/$ELEMENT/" ] ; then
-	   mkdir "$MSET_DIR/$ELEMENT/"
-	fi
-	cp "$ELEMENT" "$MSET_DIR/$ELEMENT/$MAP_NAME"
-    fi
-done
-if [ -d "cell_misc" ] ; then
-    if [ ! -d "$MSET_DIR/cell_misc" ] ; then
-	mkdir "$MSET_DIR/cell_misc"
-    fi
-    cp -r "cell_misc"/ "$MSET_DIR/cell_misc/$MAP_NAME"
-fi
-cleanup
-g.message -v "Done. Map saved to <$MAP_NAME>"
-exit 0
