[GRASS-SVN] r34877 - in grass/branches/develbranch_6/scripts: .
	v.to.3d
    svn_grass at osgeo.org
    Sun Dec 14 14:25:23 EST 2008
Author: martinl
Date: 2008-12-14 14:25:22 -0500 (Sun, 14 Dec 2008)
New Revision: 34877
Added:
   grass/branches/develbranch_6/scripts/v.to.3d/
   grass/branches/develbranch_6/scripts/v.to.3d/Makefile
   grass/branches/develbranch_6/scripts/v.to.3d/description.html
   grass/branches/develbranch_6/scripts/v.to.3d/v.to.3d
   grass/branches/develbranch_6/scripts/Makefile
very initial version of v.to.3d module (trac #82)
Modified: grass/branches/develbranch_6/scripts/Makefile
--- grass/branches/develbranch_6/scripts/Makefile	2008-12-14 16:48:33 UTC (rev 34876)
+++ grass/branches/develbranch_6/scripts/Makefile	2008-12-14 19:25:22 UTC (rev 34877)
@@ -78,8 +78,9 @@
 	v.out.gpsbabel \
 	v.rast.stats \
 	v.report \
+	v.to.3d \
 	v.univar.sh \
-	v.what.vect
+	v.what.vect \
 include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass/branches/develbranch_6/scripts/v.to.3d/Makefile
--- grass/branches/develbranch_6/scripts/v.to.3d/Makefile	                        (rev 0)
+++ grass/branches/develbranch_6/scripts/v.to.3d/Makefile	2008-12-14 19:25:22 UTC (rev 34877)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.to.3d
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass/branches/develbranch_6/scripts/v.to.3d/description.html
--- grass/branches/develbranch_6/scripts/v.to.3d/description.html	                        (rev 0)
+++ grass/branches/develbranch_6/scripts/v.to.3d/description.html	2008-12-14 19:25:22 UTC (rev 34877)
@@ -0,0 +1,29 @@
+<h2>DESCRIPTION</h2>
+The <em>v.to.3d</em> module is used to transform 2D vector features
+to 3D. Height (z-coordinate) of 3D vector features can be specified
+by <b>height</b> parameter as fixed value or by <b>column</b>
+parameter.
+<h2>TODO</h2>
+<ul>
+  <li>Check if input vector map is already 3D</li>
+  <li>Implement reverse transformation</li>
+  <li>Some examples</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.transform.html">v.transform</a>,
+<a href="v.extrude.html">v.extrude</a>,
+<a href="v.drape.html">v.drape</a>
+</em>
+<h2>AUTHORS</h2>
+Martin Landa, CTU in Prague, Czech Republic
+<p>
+<i>Last changed: $Date: 2008-11-12 02:39:48 +0100 (Wed, 12 Nov 2008) $</i>
Added: grass/branches/develbranch_6/scripts/v.to.3d/v.to.3d
--- grass/branches/develbranch_6/scripts/v.to.3d/v.to.3d	                        (rev 0)
+++ grass/branches/develbranch_6/scripts/v.to.3d/v.to.3d	2008-12-14 19:25:22 UTC (rev 34877)
@@ -0,0 +1,110 @@
+#!/bin/sh
+# MODULE:       v.to.3d
+# AUTHOR:       Martin Landa, CTU in Prague, Czech Republic
+# PURPOSE:      Transform 2D vectors to 3D vectors
+#                 (frontend to v.transform)
+# COPYRIGHT:    (c) 2008 Martin Landa, and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#% description: Performs transformation of 2D vector features to 3D.
+#% keywords: vector, transformation, 3D
+#%End
+#%Option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output vector map
+#% gisprompt: new,vector,vector
+#%End
+#%Option
+#% key: height
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Fixed height for 3D vector features
+#%End
+#%Option
+#% key: layer
+#% type: integer
+#% required: no
+#% multiple: no
+#% label: Layer number
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
+#% answer: 1
+#% gisprompt: old_layer,layer,layer
+#%End
+#%Option
+#% key: column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of attribute column used for height
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
+#%End
+if  [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." 1>&2
+    exit 1
+fi
+# save command line
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+  exec g.parser "$0" "$@"
+fi
+if [ -n "$GIS_OPT_HEIGHT" ] ; then
+   if [ -n "$GIS_OPT_COLUMN" ] ; then
+      g.message -e "Either 'height' or 'column' parameter have to be used"
+      exit 1
+   fi
+   # fixed height
+   v.transform input="$GIS_OPT_INPUT" output="$GIS_OPT_OUTPUT" zshift="$GIS_OPT_HEIGHT"
+else
+   if [ -z "$GIS_OPT_COLUMN" ] ; then
+      exit 1
+   fi
+   # attribute height, check column type
+   coltype=`v.info -c map="$GIS_OPT_INPUT" layer="$GIS_OPT_LAYER" --quiet | grep -w "$GIS_OPT_COLUMN" | cut -d'|' -f1`
+   if [ "$coltype" = "INTEGER" -o "$coltype" = "DOUBLE PRECISION" ] ; then
+       table=`v.db.connect map="$GIS_OPT_INPUT" -g fs=',' | grep ^"$GIS_OPT_LAYER" | cut -d',' -f2`
+       v.transform input="$GIS_OPT_INPUT" output="$GIS_OPT_OUTPUT" layer="$GIS_OPT_LAYER" columns="zshift:${GIS_OPT_COLUMN}" table="$table"
+   else
+       if [ -z "$coltype" ] ; then
+	   g.message -e "Column <$GIS_OPT_COLUMN> not found"
+       else
+	   g.message -e "Column type must be numeric"
+       fi
+       exit 1
+   fi
+fi
+exit 0
