[GRASS-SVN] r34882 - in grass/trunk/scripts: . v.to.3d
svn_grass at osgeo.org
Sun Dec 14 15:29:50 EST 2008
Author: martinl
Date: 2008-12-14 15:29:50 -0500 (Sun, 14 Dec 2008)
New Revision: 34882
Added:
grass/trunk/scripts/v.to.3d/
grass/trunk/scripts/v.to.3d/v.to.3d.html
grass/trunk/scripts/v.to.3d/v.to.3d.py
Removed:
grass/trunk/scripts/v.to.3d/description.html
grass/trunk/scripts/Makefile
grass/trunk/scripts/v.to.3d/Makefile
very initial version of v.to.3d
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile 2008-12-14 19:53:45 UTC (rev 34881)
+++ grass/trunk/scripts/Makefile 2008-12-14 20:29:50 UTC (rev 34882)
@@ -60,6 +60,7 @@
v.out.gps \
v.rast.stats \
v.report \
+ v.to.3d \
v.what.vect
# d.vect.thematic \
Copied: grass/trunk/scripts/v.to.3d (from rev 34879, grass/branches/develbranch_6/scripts/v.to.3d)
Property changes on: grass/trunk/scripts/v.to.3d/Makefile
___________________________________________________________________
+ text/x-sh
+ Author Date Id
+ native
Deleted: grass/trunk/scripts/v.to.3d/description.html
--- grass/branches/develbranch_6/scripts/v.to.3d/description.html 2008-12-14 19:32:54 UTC (rev 34879)
+++ grass/trunk/scripts/v.to.3d/description.html 2008-12-14 20:29:50 UTC (rev 34882)
@@ -1,28 +0,0 @@
-<h2>DESCRIPTION</h2>
-The <em>v.to.3d</em> module is used to transform 2D vector features
-to 3D. Height (z-coordinate) of 3D vector features can be specified
-by <b>height</b> parameter as fixed value or by <b>column</b>
-parameter.
-<h2>TODO</h2>
-<ul>
- <li>Implement reverse transformation</li>
- <li>Some examples</li>
-</ul>
-<h2>SEE ALSO</h2>
-<em>
-<a href="v.transform.html">v.transform</a>,
-<a href="v.extrude.html">v.extrude</a>,
-<a href="v.drape.html">v.drape</a>
-</em>
-<h2>AUTHORS</h2>
-Martin Landa, CTU in Prague, Czech Republic
-<p>
-<i>Last changed: $Date: 2008-11-12 02:39:48 +0100 (Wed, 12 Nov 2008) $</i>
Deleted: grass/trunk/scripts/v.to.3d/v.to.3d
--- grass/branches/develbranch_6/scripts/v.to.3d/v.to.3d 2008-12-14 19:32:54 UTC (rev 34879)
+++ grass/trunk/scripts/v.to.3d/v.to.3d 2008-12-14 20:29:50 UTC (rev 34882)
@@ -1,117 +0,0 @@
-#!/bin/sh
-# MODULE: v.to.3d
-# AUTHOR: Martin Landa, CTU in Prague, Czech Republic
-# PURPOSE: Transform 2D vectors to 3D vectors
-# (frontend to v.transform)
-# COPYRIGHT: (c) 2008 Martin Landa, and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Performs transformation of 2D vector features to 3D.
-#% keywords: vector, transformation, 3D
-#%End
-#%Option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#%End
-#%Option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name for output vector map
-#% gisprompt: new,vector,vector
-#%End
-#%Option
-#% key: height
-#% type: double
-#% required: no
-#% multiple: no
-#% description: Fixed height for 3D vector features
-#%End
-#%Option
-#% key: layer
-#% type: integer
-#% required: no
-#% multiple: no
-#% label: Layer number
-#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
-#% answer: 1
-#% gisprompt: old_layer,layer,layer
-#%End
-#%Option
-#% key: column
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: name
-#% description: Name of attribute column used for height
-#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
-#%End
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." 1>&2
- exit 1
-fi
-# save command line
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
-fi
-map3d=` v.info "$GIS_OPT_INPUT" -t | grep map3d | cut -d'=' -f2`
-if [ "$map3d" -eq "1" ] ; then
- g.message -e "Vector map <$GIS_OPT_INPUT> is 3D"
- exit 1
-fi
-if [ -n "$GIS_OPT_HEIGHT" ] ; then
- if [ -n "$GIS_OPT_COLUMN" ] ; then
- g.message -e "Either 'height' or 'column' parameter have to be used"
- exit 1
- fi
- # fixed height
- v.transform input="$GIS_OPT_INPUT" output="$GIS_OPT_OUTPUT" zshift="$GIS_OPT_HEIGHT"
-else
- if [ -z "$GIS_OPT_COLUMN" ] ; then
- exit 1
- fi
- # attribute height, check column type
- coltype=`v.info -c map="$GIS_OPT_INPUT" layer="$GIS_OPT_LAYER" --quiet | grep -w "$GIS_OPT_COLUMN" | cut -d'|' -f1`
- if [ "$coltype" = "INTEGER" -o "$coltype" = "DOUBLE PRECISION" ] ; then
- table=`v.db.connect map="$GIS_OPT_INPUT" -g fs=',' | grep ^"$GIS_OPT_LAYER" | cut -d',' -f2`
- v.transform input="$GIS_OPT_INPUT" output="$GIS_OPT_OUTPUT" layer="$GIS_OPT_LAYER" columns="zshift:${GIS_OPT_COLUMN}" table="$table"
- else
- if [ -z "$coltype" ] ; then
- g.message -e "Column <$GIS_OPT_COLUMN> not found"
- else
- g.message -e "Column type must be numeric"
- fi
- exit 1
- fi
-fi
-exit 0
Copied: grass/trunk/scripts/v.to.3d/v.to.3d.html (from rev 34879, grass/branches/develbranch_6/scripts/v.to.3d/description.html)
--- grass/trunk/scripts/v.to.3d/v.to.3d.html (rev 0)
+++ grass/trunk/scripts/v.to.3d/v.to.3d.html 2008-12-14 20:29:50 UTC (rev 34882)
@@ -0,0 +1,28 @@
+<h2>DESCRIPTION</h2>
+The <em>v.to.3d</em> module is used to transform 2D vector features
+to 3D. Height (z-coordinate) of 3D vector features can be specified
+by <b>height</b> parameter as fixed value or by <b>column</b>
+parameter.
+<h2>TODO</h2>
+<ul>
+ <li>Implement reverse transformation</li>
+ <li>Some examples</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.transform.html">v.transform</a>,
+<a href="v.extrude.html">v.extrude</a>,
+<a href="v.drape.html">v.drape</a>
+</em>
+<h2>AUTHORS</h2>
+Martin Landa, CTU in Prague, Czech Republic
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass/trunk/scripts/v.to.3d/v.to.3d.html
+ text/html
+ Author Date Id
+ native
Copied: grass/trunk/scripts/v.to.3d/v.to.3d.py (from rev 34879, grass/branches/develbranch_6/scripts/v.to.3d/v.to.3d)
--- grass/trunk/scripts/v.to.3d/v.to.3d.py (rev 0)
+++ grass/trunk/scripts/v.to.3d/v.to.3d.py 2008-12-14 20:29:50 UTC (rev 34882)
@@ -0,0 +1,118 @@
+#!/usr/bin/env python
+# MODULE: v.to.3d
+# AUTHOR: Martin Landa, CTU in Prague, Czech Republic
+# PURPOSE: Transform 2D vectors to 3D vectors
+# (frontend to v.transform)
+# COPYRIGHT: (c) 2008 Martin Landa, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Performs transformation of 2D vector features to 3D.
+#% keywords: vector, transformation, 3D
+#%End
+#%Option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output vector map
+#% gisprompt: new,vector,vector
+#%End
+#%Option
+#% key: height
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Fixed height for 3D vector features
+#%End
+#%Option
+#% key: layer
+#% type: integer
+#% required: no
+#% multiple: no
+#% label: Layer number
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
+#% answer: 1
+#% gisprompt: old_layer,layer,layer
+#%End
+#%Option
+#% key: column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of attribute column used for height
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
+#%End
+import sys
+import os
+import grass
+def main():
+ input = options['input']
+ output = options['output']
+ layer = options['layer']
+ column = options['column']
+ height = options['height']
+ map3d = int(grass.parse_key_val(grass.read_command('v.info', map = input, flags = 't'))['map3d'])
+ if map3d == 1:
+ grass.fatal("Vector map <%s> is 3D" % input)
+ if height:
+ if column:
+ grass.fatal("Either 'height' or 'column' parameter have to be used")
+ # fixed height
+ grass.run_command('v.transform', input = input, output = output,
+ zshift = height)
+ else:
+ if not column:
+ # attribute height, check column type
+ try:
+ coltype = grass.vector_columns2(map = input, layer = layer)[column]
+ except KeyError:
+ grass.fatal("Column <%s> not found" % column)
+ if coltype not in ('INTEGER',
+ 'DOUBLE PRECISION'):
+ grass.fatal("Column type must be numeric")
+ table = grass.vector_db(map = input, layer = layer)[1]
+ columns = "zshift:%s" % column
+ layer = layer, columns = columns,
+ table = table)
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass/trunk/scripts/v.to.3d/v.to.3d.py
+ text/x-python
+ Author Date Id
+ native
