[GRASS-SVN] r34894 - grass/trunk/raster/r.watershed/front
svn_grass at osgeo.org
Sun Dec 14 22:46:17 EST 2008
Author: hamish
Date: 2008-12-14 22:46:17 -0500 (Sun, 14 Dec 2008)
New Revision: 34894
grass/trunk/raster/r.watershed/front/r.watershed.html
removed some old interactive comments, concentrate flag descr at the top
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html 2008-12-15 03:41:51 UTC (rev 34893)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html 2008-12-15 03:46:17 UTC (rev 34894)
@@ -7,9 +7,7 @@
<p>
<!-- Interactive mode not activated in GRASS 6.
<em>r.watershed</em> can be run either interactively or non-interactively.
-If the user types <tt>r.watershed</tt>
-on the command line without program arguments, the program will prompt the user
-with a verbose description of the input maps. The interactive version of
+The interactive version of
<em>r.watershed</em> can prepare inputs to lumped-parameter hydrologic models.
After a verbose interactive session, <em>r.watershed</em> will query the user
for a number of
@@ -17,21 +15,8 @@
to an output file. This output file is organized to ease data entry into a
lumped-parameter hydrologic model program. The non-interactive version of
<em>r.watershed</em> cannot create this file.
-<p>
-The user can run the program non-interactively, by specifying input map names
-on the command line. Parameter names may be specified by their
-full names, or by any initial string that distinguish them from other parameter names.
-In <em>r.watershed</em>'s case, the first two letters of each name sufficiently
-distinguishes parameter names.
-For example, the two expressions below are equivalent inputs to <em>r.watershed</em>:
-<p>
-<pre>
- el=elev.map th=100 st=stream.map ba=basin.map
- elevation=elev.map threshold=100 stream=stream.map basin=basin.map
-</pre>
<h2>OPTIONS</h2>
<dl>
@@ -43,29 +28,29 @@
on disk which allows larger maps to be processed but is considerably
slower.
-<dt><em>memory</em>
-<dd>Maximum amount of memory in MB to be used with -m set. More memory
-speeds up the processes.
<dt><em>-s</em>
<dd>Use single flow direction (SFD) instead of multiple flow direction (MFD).
MFD is enabled by default.
+<dt><em>-4</em>
+<dd>Allow only horizontal and vertical flow of water.
+Stream and slope lengths are approximately the same as outputs from default
+surface flow (allows horizontal, vertical, and diagonal flow of water).
+This flag will also make the drainage basins look more homogeneous.
+<dt><em>memory</em>
+<dd>Maximum amount of memory in MB to be used with -m set. More memory
+speeds up the processes.
<dt><em>convergence</em>
<dd>Convergence factor for MFD. Lower values result in higher divergence,
flow is more widely distributed. Higher values result in higher convergence,
flow is less widely distributed, becoming more similar to SFD.
-<dt><em>-4</em>
-<dd>Allow only horizontal and vertical flow of water.
-Stream and slope lengths are approximately the same as outputs from default surface
-flow (allows horizontal, vertical, and diagonal flow of water).
-This flag will also make the drainage basins look more homogeneous.
<dt><em>elevation</em>
<dd>Input map: Elevation on which entire analysis is based.
