[GRASS-SVN] r34917 - grass/branches/develbranch_6/vector/v.out.ascii
svn_grass at osgeo.org
Wed Dec 17 14:25:09 EST 2008
Author: martinl
Date: 2008-12-17 14:25:09 -0500 (Wed, 17 Dec 2008)
New Revision: 34917
grass/branches/develbranch_6/vector/v.out.ascii/b2a.c
grass/branches/develbranch_6/vector/v.out.ascii/description.html
grass/branches/develbranch_6/vector/v.out.ascii/local_proto.h
grass/branches/develbranch_6/vector/v.out.ascii/out.c
v.out.ascii: attribute selection added (v.out.ascii.db merged)
new parameters: where, layer, columns (point mode point)
Modified: grass/branches/develbranch_6/vector/v.out.ascii/b2a.c
--- grass/branches/develbranch_6/vector/v.out.ascii/b2a.c 2008-12-17 17:09:34 UTC (rev 34916)
+++ grass/branches/develbranch_6/vector/v.out.ascii/b2a.c 2008-12-17 19:25:09 UTC (rev 34917)
@@ -1,11 +1,15 @@
#include <grass/Vect.h>
#include <grass/gis.h>
+#include <grass/dbmi.h>
#include <grass/glocale.h>
#include "local_proto.h"
-int bin_to_asc(FILE * ascii,
- FILE * att, struct Map_info *Map, int ver,
- int format, int dp, char *fs, int region_flag)
+static int srch(const void *pa, const void *pb);
+int bin_to_asc(FILE *ascii,
+ FILE *att, struct Map_info *Map, int ver,
+ int format, int dp, char *fs, int region_flag,
+ int field, char* where, char **columns)
int type, ctype, i, cat, proj;
double *xptr, *yptr, *zptr, x, y;
@@ -14,9 +18,47 @@
char *xstring = NULL, *ystring = NULL, *zstring = NULL;
struct Cell_head window;
+ /* where */
+ struct field_info *Fi;
+ dbDriver *driver;
+ dbValue value;
+ dbHandle handle;
+ int *cats, ncats;
/* get the region */
G_get_window(&window);
+ ncats = 0;
+ cats = NULL;
+ if (where || columns) {
+ Fi = Vect_get_field(Map, field);
+ if (!Fi) {
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ field);
+ driver = db_start_driver(Fi->driver);
+ if (!driver)
+ G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
+ db_init_handle(&handle);
+ db_set_handle(&handle, Fi->database, NULL);
+ if (db_open_database(driver, &handle) != DB_OK)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ /* select cats (sorted array) */
+ ncats = db_select_int(driver, Fi->table, Fi->key, where, &cats);
+ G_debug(3, "%d categories selected from table <%s>", ncats, Fi->table);
+ if (!columns) {
+ db_close_database(driver);
+ db_shutdown_driver(driver);
Points = Vect_new_line_struct(); /* init line_pnts struct */
Cats = Vect_new_cats_struct();
@@ -29,15 +71,40 @@
Vect_rewind(Map);
while (1) {
- if (-1 == (type = Vect_read_next_line(Map, Points, Cats)))
- return (-1);
+ if (-1 == (type = Vect_read_next_line(Map, Points, Cats))) {
+ if (columns) {
+ return -1;
- if (type == -2) /* EOF */
- return (0);
+ if (type == -2) { /* EOF */
+ if (columns) {
+ return 0;
if (format == FORMAT_POINT && !(type & GV_POINTS))
continue;
+ if (cats) {
+ /* check category */
+ for (i = 0; i < Cats->n_cats; i++) {
+ if ((int *)bsearch((void *) &(Cats->cat[i]), cats, ncats, sizeof(int),
+ srch)) {
+ /* found */
+ break;
+ if (i == Cats->n_cats)
+ continue;
if (ver < 5) {
Vect_cat_get(Cats, 1, &cat);
@@ -115,8 +182,49 @@
else {
fprintf(ascii, "%s%s%s", xstring, fs, ystring);
- if (Cats->n_cats > 0)
+ if (Cats->n_cats > 0) {
+ if (Cats->n_cats > 1) {
+ G_warning(_("Feature has more categories. Only first category (%d) "
+ "is exported."), Cats->cat[0]);
fprintf(ascii, "%s%d", fs, Cats->cat[0]);
+ /* print attributes */
+ if (columns) {
+ for(i = 0; columns[i]; i++) {
+ if (db_select_value(driver, Fi->table, Fi->key, Cats->cat[0],
+ columns[i], &value) < 0)
+ G_fatal_error(_("bUnable to select record from table <%s> (key %s, column %s)"),
+ Fi->table, Fi->key, columns[i]);
+ if (db_test_value_isnull(&value)) {
+ fprintf(ascii, "%s", fs);
+ else {
+ switch(db_column_Ctype(driver, Fi->table, columns[i]))
+ case DB_C_TYPE_INT: {
+ fprintf(ascii, "%s%d", fs, db_get_value_int(&value));
+ break;
+ case DB_C_TYPE_DOUBLE: {
+ fprintf(ascii, "%s%.*f", fs, dp, db_get_value_double(&value));
+ break;
+ case DB_C_TYPE_STRING: {
+ fprintf(ascii, "%s%s", fs, db_get_value_string(&value));
+ break;
+ case DB_C_TYPE_DATETIME: {
+ break;
+ default: G_fatal_error(_("Column <%s>: unsupported data type"),
+ columns[i]);
fprintf(ascii, "\n");
@@ -187,3 +295,15 @@
/* not reached */
+int srch(const void *pa, const void *pb)
+ int *p1 = (int *)pa;
+ int *p2 = (int *)pb;
+ if (*p1 < *p2)
+ return -1;
+ if (*p1 > *p2)
+ return 1;
+ return 0;
Modified: grass/branches/develbranch_6/vector/v.out.ascii/description.html
--- grass/branches/develbranch_6/vector/v.out.ascii/description.html 2008-12-17 17:09:34 UTC (rev 34916)
+++ grass/branches/develbranch_6/vector/v.out.ascii/description.html 2008-12-17 19:25:09 UTC (rev 34917)
@@ -1,68 +1,73 @@
<h2>DESCRIPTION</h2>
-<em>v.out.ascii</em>
-converts a GRASS vector map in binary format to a GRASS vector map in ASCII
-format. Using flag <b>-o</b> <em>v.out.ascii</em> output will be in old
-(version 4) ASCII format.
-<P>
+<em>v.out.ascii</em> converts a GRASS vector map in binary format to a
+GRASS vector map in ASCII format. Using
+flag <b>-o</b> <em>v.out.ascii</em> output will be in old (version 4)
+ASCII format.
+<p>
If the <b>output</b> parameter is not given then the coordinates of any
<em>point</em> data within the vector map is sent to stdout.
<h2>NOTES</h2>
-The GRASS program <em><a HREF="v.in.ascii.html">v.in.ascii</a></em>
-performs the function of <em>v.out.ascii</em> in reverse; i.e., it
-converts vector maps in ASCII format to their binary format.
-These two companion programs are useful both for importing and exporting
-vector maps between GRASS and other software, and for transferring data
+The <em><a href="v.in.ascii.html">v.in.ascii</a></em> module performs
+the function of <em>v.out.ascii</em> in reverse; i.e. it converts
+vector maps in ASCII format to their binary format. These two
+companion module are useful both for importing and exporting vector
+maps between GRASS and other software, and for transferring data
between machines.
-<P>
-If the <b>format</b> parameter is set to <b>standard</b>, A GRASS ASCII vector map will be exported,
-which may contain a mix of primitives including points, lines, boundaries, centroids, areas, faces,
-and kernels. The beginning of the output ascii file will contain a header listing any metadata for the
-input vector, if such metadata exists. An example of the <b>standard</b> format is given below.
-<P>
+<o>
+If the <b>format</b> parameter is set to <b>standard</b>, a GRASS
+ASCII vector map will be exported, which may contain a mix of
+primitives including points, lines, boundaries, centroids, areas,
+faces, and kernels. The beginning of the output ascii file will
+contain a header listing any metadata for the input vector map, if
+such metadata exists. An example of the <b>standard</b> format is
+given below.
+<p>
The primitive codes are as follows:
-<UL>
-<LI>'P': point</LI>
-<LI>'L': line</LI>
-<LI>'B': boundary</LI>
-<LI>'C': centroid</LI>
-<LI>'F': face (3D boundary)</LI>
-<LI>'K': kernel (3D centroid)</LI>
-<LI>'A': area (boundary) - better use 'B'; kept only for backward compatibility</LI>
+<ul>
+<li>'P': point</li>
+<li>'L': line</li>
+<li>'B': boundary</li>
+<li>'C': centroid</li>
+<li>'F': face (3D boundary)</li>
+<li>'K': kernel (3D centroid)</li>
+<li>'A': area (boundary) - better use 'B'; kept only for backward compatibility</li>
+</ul>
-</UL>
+The coordinates are listed following the initial line containing the
+primitive code, the total number of vectors in the series, and the
+number of categories (1 for a single layer, higher for multiple
+layers). Below that 1 or several lines follow to indicate the layer
+number and the category number.
-The coordinates are listed following the initial line containing the
-primitive code, the total number of vectors in the series, and the number
-of categories (1 for a single layer, higher for multiple layers).
-Below that 1 or several lines follow to indicate the layer number and
-the category number (ID).
-<BR>
<p>
-The order of coordinates for new (standard) version of ASCII file is <BR><BR>
+The order of coordinates for new (standard) version of ASCII file is
+<div class="code"><pre>
X Y [Z]
-<BR><BR>
-the order of coordinates for old version of ASCII file is <BR><BR>
+</pre></div>
+the order of coordinates for old version of ASCII file is
Y X
+</pre></div>
-<p>
-If old version is requested, the <B>output</B> files from <em>v.out.ascii</em> will be placed
+If old version is requested, the <b>output</b> files from <em>v.out.ascii</em> will be placed
in the <tt>$LOCATION/$MAPSET/dig_ascii/</tt> and <tt>$LOCATION/$MAPSET/dig_att</tt> directory.
<p>
-Only features with a category number will be exported. Use <em>v.category</em>
-to add them if needed.
+Only features with a category number will be
+exported. Use <em>v.category</em> to add them if needed.
<p>
-<em>v.out.ascii</em> does not copy the <em>dig_cats</em>
-file associated with the binary vector <em>input</em> map
-to the new <em>output</em> file name. The user must copy
-the <em>dig_cats</em> file to the new <em>output</em> name
-if this is desired (e.g., using the UNIX <em>cp</em>
-command).
+<em>v.out.ascii</em> does not copy the <em>dig_cats</em> file
+associated with the binary vector <em>input</em> map to the
+new <em>output</em> file name. The user must copy
+the <em>dig_cats</em> file to the new <em>output</em> name if this is
+desired (e.g. using the UNIX <em>cp</em> command).
<p>
It is possible to output the coordinates of vertices in a non-points vector
@@ -72,7 +77,7 @@
<h2>EXAMPLES</h2>
-<h3>Example 1a) - standard mode - using the 'quads' vector from Spearfish dataset:</h3>
+<h3>Standard mode</h3>
<p>
@@ -109,9 +114,8 @@
1 2
</pre></div>
-<h3>Example 1b) - point mode</h3>
+<h3>Point mode</h3>
-<p>
v.out.ascii input=quads format=point
@@ -119,15 +123,24 @@
604433.84|4921087.1|2
</pre></div>
+v.out.ascii input=archsites format=point where="cat > 5 and cat <= 8" columns=str1
+600375|4925235|6|Prairie Site
+606635|4920773|7|Jensen Pass
+595755|4925300|8|No Name
+</pre></div>
<h2>SEE ALSO</h2>
<em>
-<a HREF="v.category.html">v.category</a><BR>
-<a HREF="v.in.ascii.html">v.in.ascii</a><BR>
-<a HREF="v.to.points.html">v.to.points</a></em><BR>
-<a HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass6/doc/vector/vector.html#ascii">Vector ASCII Format Specification</a>
-<BR><BR>
+<a href="v.category.html">v.category</a>,
+<a href="v.in.ascii.html">v.in.ascii</a>,
+<a href="v.to.points.html">v.to.points</a></em>
+<br><br>
+<a HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass6/doc/vector/vector.html#ascii">Vector
+ASCII Format Specification</a>
<h2>AUTHORS</h2>
@@ -140,5 +153,8 @@
Research Laboratory
<br>
Radim Blazek, ITC-Irst, Trento, Italy
+<br>
+Attribute selection added by Martin Landa, CTU in Prague, Czech Republic (2008/12)
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/develbranch_6/vector/v.out.ascii/local_proto.h
--- grass/branches/develbranch_6/vector/v.out.ascii/local_proto.h 2008-12-17 17:09:34 UTC (rev 34916)
+++ grass/branches/develbranch_6/vector/v.out.ascii/local_proto.h 2008-12-17 19:25:09 UTC (rev 34917)
@@ -3,6 +3,6 @@
/* b2a.c */
int bin_to_asc(FILE *, FILE *, struct Map_info *, int ver, int format, int dp,
- char *, int);
+ char *, int, int, char *, char **);
/* head.c */
int write_head(FILE * dascii, struct Map_info *Map);
Modified: grass/branches/develbranch_6/vector/v.out.ascii/out.c
--- grass/branches/develbranch_6/vector/v.out.ascii/out.c 2008-12-17 17:09:34 UTC (rev 34916)
+++ grass/branches/develbranch_6/vector/v.out.ascii/out.c 2008-12-17 19:25:09 UTC (rev 34917)
@@ -5,6 +5,7 @@
* AUTHOR(S): Michael Higgins, U.S. Army Construction Engineering Research Laboratory
* James Westervelt, U.S. Army Construction Engineering Research Laboratory
* Radim Blazek, ITC-Irst, Trento, Italy
+ * Martin Landa, CTU in Prague, Czech Republic (v.out.ascii.db merged)
* PURPOSE: v.out.ascii: writes GRASS vector data as ASCII files
* COPYRIGHT: (C) 2000-2008 by the GRASS Development Team
@@ -29,9 +30,10 @@
int main(int argc, char *argv[])
FILE *ascii, *att;
- struct Option *input, *output, *format_opt, *dp_opt, *delim_opt;
+ struct Option *input, *output, *format_opt, *dp_opt, *delim_opt,
+ *field_opt, *column_opt, *where_opt;
struct Flag *verf, *region_flag;
- int format, dp;
+ int format, dp, field;
char *fs;
struct Map_info Map;
int ver = 5, pnt = 0;
@@ -40,18 +42,14 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("vector");
+ module->keywords = _("vector, export");
module->description =
_("Converts a GRASS binary vector map to a GRASS ASCII vector map.");
input = G_define_standard_option(G_OPT_V_INPUT);
- output = G_define_option();
- output->key = "output";
- output->type = TYPE_STRING;
+ output = G_define_standard_option(G_OPT_F_OUTPUT);
output->required = NO;
- output->multiple = NO;
- output->gisprompt = "new_file,file,output";
output->description =
_("Path to resulting ASCII file or ASCII vector name if '-o' is defined");
@@ -64,22 +62,30 @@
format_opt->answer = "point";
format_opt->description = _("Output format");
- delim_opt = G_define_option();
- delim_opt->key = "fs";
- delim_opt->type = TYPE_STRING;
- delim_opt->required = NO;
+ delim_opt = G_define_standard_option(G_OPT_F_SEP);
delim_opt->description = _("Field separator (points mode)");
- delim_opt->answer = "|";
+ delim_opt->guisection = _("Points");
dp_opt = G_define_option();
dp_opt->key = "dp";
dp_opt->type = TYPE_INTEGER;
dp_opt->required = NO;
dp_opt->options = "0-32";
- dp_opt->answer = "8"; /*This value is taken from the lib settings in G_format_easting() */
+ dp_opt->answer = "8"; /* This value is taken from the lib settings in G_format_easting() */
dp_opt->description =
_("Number of significant digits (floating point only)");
+ dp_opt->guisection = _("Points");
+ field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ field_opt->guisection = _("Selection");
+ column_opt = G_define_standard_option(G_OPT_COLUMNS);
+ column_opt->description = _("Name of attribute column(s) to be exported (point mode)");
+ column_opt->guisection = _("Points");
+ where_opt = G_define_standard_option(G_OPT_WHERE);
+ where_opt->guisection = _("Selection");
verf = G_define_flag();
verf->key = 'o';
verf->description = _("Create old (version 4) ASCII file");
@@ -88,15 +94,23 @@
region_flag->key = 'r';
region_flag->description =
_("Only export points falling within current 3D region (points mode)");
+ region_flag->guisection = _("Points");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ field = atoi(field_opt->answer);
if (format_opt->answer[0] == 'p')
format = FORMAT_POINT;
else
format = FORMAT_ALL;
+ if (format == FORMAT_ALL) {
+ G_warning(_("Parameter '%s' ignored in standard mode"),
+ column_opt->key);
if (verf->answer)
ver = 4;
@@ -127,9 +141,10 @@
Vect_set_open_level(1); /* only need level I */
- Vect_open_old(&Map, input->answer, "");
+ if (Vect_open_old(&Map, input->answer, "") < 0)
+ G_fatal_error(_("Unable to open vector map <%s>"),
+ input->answer);
if (output->answer) {
if (ver == 4) {
ascii = G_fopen_new("dig_ascii", output->answer);
@@ -161,12 +176,14 @@
G_fatal_error(_("dig_att file already exist"));
if ((att = G_fopen_new("dig_att", output->answer)) == NULL)
- G_fatal_error(_("Unable to open dig_att file <%s>\n"),
+ G_fatal_error(_("Unable to open dig_att file <%s>"),
output->answer);
- bin_to_asc(ascii, att, &Map, ver, format, dp, fs, region_flag->answer);
+ bin_to_asc(ascii, att, &Map, ver, format, dp, fs,
+ region_flag->answer, field, where_opt->answer,
+ column_opt->answers);
if (ascii != NULL)
fclose(ascii);
if (att != NULL)
