[GRASS-SVN] r34929 - grass/trunk/lib/cairodriver
svn_grass at osgeo.org
Thu Dec 18 16:49:58 EST 2008
Author: glynn
Date: 2008-12-18 16:49:58 -0500 (Thu, 18 Dec 2008)
New Revision: 34929
Added:
grass/trunk/lib/cairodriver/read_xid.c
grass/trunk/lib/cairodriver/write_xid.c
grass/trunk/lib/cairodriver/Graph.c
grass/trunk/lib/cairodriver/Makefile
grass/trunk/lib/cairodriver/cairodriver.h
grass/trunk/lib/cairodriver/read.c
grass/trunk/lib/cairodriver/write.c
Fix, improve handling of X Pixmap surfaces
Modified: grass/trunk/lib/cairodriver/Graph.c
--- grass/trunk/lib/cairodriver/Graph.c 2008-12-18 17:32:51 UTC (rev 34928)
+++ grass/trunk/lib/cairodriver/Graph.c 2008-12-18 21:49:58 UTC (rev 34929)
@@ -49,60 +49,52 @@
static void init_xlib(void)
#if defined(USE_X11) && CAIRO_HAS_XLIB_SURFACE
- Display *dpy;
- Drawable win;
unsigned long xid;
XVisualInfo templ;
XVisualInfo *vinfo;
+ int scrn;
int count;
- Window root;
- unsigned int depth;
- int si;
- unsigned int ui;
- Visual *visual;
char *p;
- p = getenv("GRASS_CAIRO_DRAWABLE");
- if (!p || sscanf(p, "%li", &xid) != 1)
- G_fatal_error(_("Invalid Drawable XID: %s"), p);
- win = xid;
- dpy = XOpenDisplay(NULL);
- if (!dpy)
+ ca.dpy = XOpenDisplay(NULL);
+ if (!ca.dpy)
G_fatal_error(_("Unable to open display"));
+ p = getenv("GRASS_CAIRO_SCREEN");
+ if (!p || sscanf(p, "%i", &scrn) != 1)
+ scrn = DefaultScreen(ca.dpy);
p = getenv("GRASS_CAIRO_VISUAL");
- G_fatal_error(_("invalid Visual XID: %s"), p);
+ xid = DefaultVisual(ca.dpy, scrn)->visualid;
templ.visualid = xid;
+ templ.screen = scrn;
- vinfo = XGetVisualInfo(dpy, VisualIDMask, &templ, &count);
+ vinfo = XGetVisualInfo(ca.dpy, VisualIDMask, &templ, &count);
if (!vinfo || !count)
G_fatal_error(_("Unable to obtain visual"));
- visual = vinfo[0].visual;
+ ca.visual = vinfo[0].visual;
- if (!XGetGeometry
- (dpy, win, &root, &si, &si, &width, &height, &ui, &depth))
- G_fatal_error(_("Unable to query drawable"));
+ if (!ca.win)
+ ca.win = XCreatePixmap(
+ ca.dpy, RootWindow(ca.dpy, scrn),
+ ca.width, ca.height, vinfo[0].depth);
+#endif
- surface = cairo_xlib_surface_create(dpy, win, visual, width, height);
- if (cairo_surface_status(surface) != CAIRO_STATUS_SUCCESS)
- G_fatal_error(_("Failed to initialize Xlib surface"));
- cairo = cairo_create(surface);
- ca.file_name = "<X11>";
- file_type = FTYPE_X11;
- screen_right = screen_left + ca.width;
- screen_bottom = screen_top + ca.height;
+static void fini_xlib(void)
+#if defined(USE_X11) && CAIRO_HAS_XLIB_SURFACE
+ XSetCloseDownMode(ca.dpy, RetainPermanent);
+ XCloseDisplay(ca.dpy);
#endif
static void init_file(void)
int is_vector = 0;
+ int is_xlib = 0;
int do_read = 0;
int do_map = 0;
char *p;
@@ -120,8 +112,7 @@
ca.file_name = p;
/* get file type (from extension) */
- if (ca.file_type == FTYPE_X11) ; /* skip */
- else if (ends_with(ca.file_name, ".ppm"))
+ if (ends_with(ca.file_name, ".ppm"))
ca.file_type = FTYPE_PPM;
else if (ends_with(ca.file_name, ".bmp"))
ca.file_type = FTYPE_BMP;
@@ -141,6 +132,10 @@
else if (ends_with(ca.file_name, ".svg"))
ca.file_type = FTYPE_SVG;
#endif
+ else if (ends_with(ca.file_name, ".xid"))
+ ca.file_type = FTYPE_X11;
+#endif
else
G_fatal_error(_("Unknown file extension: %s"), p);
G_debug(1, "File type: %s (%d)", ca.file_name, ca.file_type);
@@ -151,6 +146,9 @@
case FTYPE_SVG:
is_vector = 1;
break;
+ case FTYPE_X11:
+ is_xlib = 1;
+ break;
p = getenv("GRASS_PNG_MAPPED");
@@ -175,6 +173,15 @@
if (do_read && do_map)
map_file();
+ if (is_xlib) {
+ if (do_read)
+ cairo_read_image();
+ else
+ ca.win = 0;
+ init_xlib();
+ ca.mapped = 1;
if (!ca.mapped && !is_vector)
ca.grid = G_malloc(ca.height * ca.stride);
@@ -244,11 +251,7 @@
if (p && G_strcasecmp(p, "subpixel") == 0)
antialias = CAIRO_ANTIALIAS_SUBPIXEL;
- if (p)
- init_xlib();
- else
- init_file();
+ init_file();
cairo_set_antialias(cairo, antialias);
@@ -262,6 +265,13 @@
G_debug(1, "Cairo_Graph_close");
+ if (ca.file_type == FTYPE_X11) {
+ XFlush(cairo_xlib_surface_get_display(surface));
+ ca.mapped = 0;
+#endif
cairo_write_image();
if (cairo) {
@@ -272,6 +282,11 @@
cairo_surface_destroy(surface);
surface = NULL;
+ fini_xlib();
+#endif
static void init_cairo(void)
@@ -308,6 +323,13 @@
ca.file_name, (double) ca.width, (double) ca.height);
break;
#endif
+ case FTYPE_X11:
+ surface =
+ (cairo_surface_t *) cairo_xlib_surface_create(
+ ca.dpy, ca.win, ca.visual, ca.width, ca.height);
+ break;
+#endif
default:
G_fatal_error(_("Unknown Cairo surface type"));
break;
@@ -356,3 +378,4 @@
ca.mapped = 1;
#endif
Modified: grass/trunk/lib/cairodriver/Makefile
--- grass/trunk/lib/cairodriver/Makefile 2008-12-18 17:32:51 UTC (rev 34928)
+++ grass/trunk/lib/cairodriver/Makefile 2008-12-18 21:49:58 UTC (rev 34929)
@@ -9,6 +9,10 @@
include $(MODULE_TOPDIR)/include/Make/Lib.make
+ifneq ($(USE_X11),)
+EXTRA_CFLAGS += -DUSE_X11=1
+endif
ifneq ($(USE_CAIRO),)
default: lib
endif
Modified: grass/trunk/lib/cairodriver/cairodriver.h
--- grass/trunk/lib/cairodriver/cairodriver.h 2008-12-18 17:32:51 UTC (rev 34928)
+++ grass/trunk/lib/cairodriver/cairodriver.h 2008-12-18 21:49:58 UTC (rev 34929)
@@ -21,6 +21,13 @@
#include <cairo.h>
+#include <X11/X.h>
+#include <X11/Xlib.h>
+#include <X11/Xutil.h>
+#include <cairo-xlib.h>
+#endif
#include <grass/config.h>
#include <grass/gis.h>
@@ -56,6 +63,11 @@
double bgcolor_r, bgcolor_g, bgcolor_b, bgcolor_a;
int modified;
int mapped;
+ Display *dpy;
+ Drawable win;
+ Visual *visual;
+#endif
extern struct cairo_state ca;
@@ -93,10 +105,12 @@
extern void cairo_read_image(void);
extern void cairo_read_ppm(void);
extern void cairo_read_bmp(void);
+extern void cairo_read_xid(void);
/* write.c */
extern void cairo_write_image(void);
extern void cairo_write_ppm(void);
extern void cairo_write_bmp(void);
+extern void cairo_write_xid(void);
#endif /* __CAIRODRIVER_H__ */
Modified: grass/trunk/lib/cairodriver/read.c
--- grass/trunk/lib/cairodriver/read.c 2008-12-18 17:32:51 UTC (rev 34928)
+++ grass/trunk/lib/cairodriver/read.c 2008-12-18 21:49:58 UTC (rev 34929)
@@ -47,6 +47,12 @@
cairo_surface_destroy(img_surf);
#endif
+ G_debug(1, "Reading XID from %s", ca.file_name);
+ cairo_read_xid();
+#endif
/* vector format files are written directly to file */
ca.modified = 0;
Added: grass/trunk/lib/cairodriver/read_xid.c
--- grass/trunk/lib/cairodriver/read_xid.c (rev 0)
+++ grass/trunk/lib/cairodriver/read_xid.c 2008-12-18 21:49:58 UTC (rev 34929)
@@ -0,0 +1,27 @@
+#include <grass/glocale.h>
+#include "cairodriver.h"
+void cairo_read_xid(void)
+ FILE *fp;
+ char buf[64];
+ unsigned long xid;
+ fp = fopen(ca.file_name, "r");
+ if (!fp)
+ G_fatal_error(_("Unable to open input file <%s>"), ca.file_name);
+ if (!fgets(buf, sizeof(buf), fp))
+ G_fatal_error(_("Unable to read input file <%s>"), ca.file_name);
+ if (sscanf(buf, "%lu", &xid) != 1)
+ G_fatal_error(_("Unable to parse input file <%s>"), ca.file_name);
+ fclose(fp);
+ ca.win = (Drawable) xid;
+#endif
Modified: grass/trunk/lib/cairodriver/write.c
--- grass/trunk/lib/cairodriver/write.c 2008-12-18 17:32:51 UTC (rev 34928)
+++ grass/trunk/lib/cairodriver/write.c 2008-12-18 21:49:58 UTC (rev 34929)
@@ -14,7 +14,7 @@
-#if CAIRO_HAS_XLIB_SURFACE
#endif
@@ -46,9 +46,10 @@
cairo_surface_write_to_png(surface, ca.file_name);
#endif
else if (ca.file_type == FTYPE_X11) {
- XFlush(cairo_xlib_surface_get_display(surface));
+ G_debug(1, "Writing XID to %s", ca.file_name);
+ cairo_write_xid();
#endif
Added: grass/trunk/lib/cairodriver/write_xid.c
--- grass/trunk/lib/cairodriver/write_xid.c (rev 0)
+++ grass/trunk/lib/cairodriver/write_xid.c 2008-12-18 21:49:58 UTC (rev 34929)
@@ -0,0 +1,24 @@
+void cairo_write_xid(void)
+ FILE *fp;
+ char buf[64];
+ fp = fopen(ca.file_name, "w");
+ if (!fp)
+ G_fatal_error(_("Unable to open output file <%s>"), ca.file_name);
+ sprintf(buf, "0x%08lx\n", (unsigned long) ca.win);
+ if (fputs(buf, fp) < 0)
+ G_fatal_error(_("Unable to write output file <%s>"), ca.file_name);
+ fclose(fp);
+#endif
