[GRASS-SVN] r34935 - in grass/trunk: lib/python
scripts/i.landsat.rgb
svn_grass at osgeo.org
Fri Dec 19 12:36:51 EST 2008
Author: martinl
Date: 2008-12-19 12:36:51 -0500 (Fri, 19 Dec 2008)
New Revision: 34935
grass/trunk/lib/python/grass.py
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
i.landsat.rgb: write history only for raster maps in the current mapset
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2008-12-19 17:14:52 UTC (rev 34934)
+++ grass/trunk/lib/python/grass.py 2008-12-19 17:36:51 UTC (rev 34935)
@@ -519,9 +519,18 @@
def raster_history(map):
"""Set the command history for a raster map to the command used to
invoke the script (interface to `r.support').
+ @return 1 on success
+ @return 0 on failure
- run_command('r.support', map = map, history = os.environ['CMDLINE'])
+ current_mapset = gisenv()['MAPSET']
+ if find_file(name = map)['mapset'] == current_mapset:
+ run_command('r.support', map = map, history = os.environ['CMDLINE'])
+ return 1
+ warning("Unable to write history for <%s>. Raster map <%s> not found in current mapset." % (map, map))
+ return 0
# run "r.info -rgstmpud ..." and parse output
def raster_info(map):
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2008-12-19 17:14:52 UTC (rev 34934)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2008-12-19 17:36:51 UTC (rev 34935)
@@ -21,7 +21,7 @@
#%Module
-#% description: Auto-balancing of colors for LANDSAT images
+#% description: Performs auto-balancing of colors for LANDSAT images.
#% keywords: raster, imagery, colors
#%End
#%option
@@ -111,7 +111,7 @@
if not preserve:
for i in [red, green, blue]:
- grass.message("Processing <%s> ..." % i)
+ grass.message("Processing <%s>..." % i)
v0 = get_percentile(i, 2)
v1 = get_percentile(i, brightness)
grass.debug("<%s>: min=%f max=%f" % (i, v0, v1))
@@ -120,7 +120,7 @@
all_max = 0
all_min = 255
