[GRASS-SVN] r34939 - grass/trunk/lib/python
svn_grass at osgeo.org
Fri Dec 19 15:41:47 EST 2008
Author: glynn
Date: 2008-12-19 15:41:47 -0500 (Fri, 19 Dec 2008)
New Revision: 34939
grass/trunk/lib/python/grass.py
Python has a distinct boolean type
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2008-12-19 20:36:57 UTC (rev 34938)
+++ grass/trunk/lib/python/grass.py 2008-12-19 20:41:47 UTC (rev 34939)
@@ -526,10 +526,10 @@
current_mapset = gisenv()['MAPSET']
if find_file(name = map)['mapset'] == current_mapset:
run_command('r.support', map = map, history = os.environ['CMDLINE'])
- return 1
+ return True
warning("Unable to write history for <%s>. Raster map <%s> not found in current mapset." % (map, map))
- return 0
+ return False
# run "r.info -rgstmpud ..." and parse output
