[GRASS-SVN] r34942 - grass/branches/releasebranch_6_4/lib/python
Fri Dec 19 16:39:40 EST 2008
Author: martinl
Date: 2008-12-19 16:39:40 -0500 (Fri, 19 Dec 2008)
New Revision: 34942
   grass/branches/releasebranch_6_4/lib/python/grass.py
grass.py synchronized with devbr6
Modified: grass/branches/releasebranch_6_4/lib/python/grass.py
--- grass/branches/releasebranch_6_4/lib/python/grass.py	2008-12-19 20:53:21 UTC (rev 34941)
+++ grass/branches/releasebranch_6_4/lib/python/grass.py	2008-12-19 21:39:40 UTC (rev 34942)
@@ -494,7 +494,7 @@
 # run "v.info -c ..." and parse output
 def vector_columns(map, layer = None, **args):
-    """Return the directory of columns for the database table connected to
+    """Return a dictionary of the columns for the database table connected to
     a vector map (interface to `v.info -c').
     s = read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True, **args)
@@ -519,9 +519,18 @@
 def raster_history(map):
     """Set the command history for a raster map to the command used to
     invoke the script (interface to `r.support').
+    @return True on success
+    @return False on failure
-    run_command('r.support', map = map, history = os.environ['CMDLINE'])
+    current_mapset = gisenv()['MAPSET']
+    if find_file(name = map)['mapset'] == current_mapset:
+        run_command('r.support', map = map, history = os.environ['CMDLINE'])
+        return True
+    warning("Unable to write history for <%s>. Raster map <%s> not found in current mapset." % (map, map))
+    return False
 # run "r.info -rgstmpud ..." and parse output
 def raster_info(map):
