[GRASS-SVN] r34949 - in grass/trunk: gui/wxpython/gui_modules
lib/python
svn_grass at osgeo.org
Fri Dec 19 18:03:51 EST 2008
Author: martinl
Date: 2008-12-19 18:03:51 -0500 (Fri, 19 Dec 2008)
New Revision: 34949
grass/trunk/gui/wxpython/gui_modules/gdialogs.py
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/lib/python/grass.py
grass.py: list_grouped2() renamed to mlist_grouped()
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2008-12-19 23:00:28 UTC (rev 34948)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py 2008-12-19 23:03:51 UTC (rev 34949)
@@ -690,7 +690,7 @@
@param mapset mapset name
try:
- self.map_layers = grass.list_grouped2(type=type, mapset=mapset)[mapset]
+ self.map_layers = grass.mlist_grouped(type=type, mapset=mapset)[mapset]
except KeyError:
self.map_layers = []
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-12-19 23:00:28 UTC (rev 34948)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-12-19 23:03:51 UTC (rev 34949)
@@ -210,7 +210,7 @@
mapsets[i] = mapsets[0]
mapsets[0] = curr_mapset
- filesdict = grass.list_grouped2(elementdict[element])
+ filesdict = grass.mlist_grouped(elementdict[element])
for dir in mapsets:
dir_node = self.AddItem('Mapset: '+dir)
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2008-12-19 23:00:28 UTC (rev 34948)
+++ grass/trunk/lib/python/grass.py 2008-12-19 23:03:51 UTC (rev 34949)
@@ -296,7 +296,7 @@
result[mapset].extend(line.split())
return result
-def list_grouped2(type, mapset = None, pattern = None):
+def mlist_grouped(type, mapset = None, pattern = None):
"""Returns the output from running g.mlist, as a dictionary where the keys
are mapset names and the values are lists of maps in that mapset.
