[GRASS-SVN] r34956 - grass/trunk/scripts/v.dissolve
svn_grass at osgeo.org
Sat Dec 20 11:58:42 EST 2008
Author: martinl
Date: 2008-12-20 11:58:42 -0500 (Sat, 20 Dec 2008)
New Revision: 34956
grass/trunk/scripts/v.dissolve/v.dissolve.py
v.dissolve: variable typo
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-12-20 16:39:06 UTC (rev 34955)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-12-20 16:58:42 UTC (rev 34956)
@@ -75,13 +75,13 @@
# does map exist?
if not grass.find_file(input, element = 'vector')['file']:
grass.fatal("Vector map <%s> not found" % input)
if not column:
grass.run_command('v.extract', flags = 'd', input = input,
output = output, type = 'area', layer = layer)
else:
try:
- coltype = grass.vector_columns(map, layer)[column]
+ coltype = grass.vector_columns(input, layer)[column]
except KeyError:
grass.fatal('Column <%s> not found' % column)
