[GRASS-SVN] r34959 - grass/trunk/scripts/v.dissolve
svn_grass at osgeo.org
Sat Dec 20 12:29:03 EST 2008
Author: martinl
Date: 2008-12-20 12:29:03 -0500 (Sat, 20 Dec 2008)
New Revision: 34959
grass/trunk/scripts/v.dissolve/v.dissolve.py
v.dissolve: don't run v.extract if v.reclass failed
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-12-20 17:07:13 UTC (rev 34958)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-12-20 17:29:03 UTC (rev 34959)
@@ -94,12 +94,11 @@
tmpfile = '%s_%s' % (output, tmp)
- grass.run_command('v.reclass', input = input, output = tmpfile,
- layer = layer, column = column)
+ if grass.run_command('v.reclass', input = input, output = tmpfile,
+ layer = layer, column = column) == 0:
+ grass.run_command('v.extract', flags = 'd', input = tmpfile,
+ output = output, type = 'area', layer = layer)
- grass.run_command('v.extract', flags = 'd', input = tmpfile,
- output = output, type = 'area', layer = layer)
# write cmd history:
grass.vector_history(output)
