[GRASS-SVN] r34968 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sun Dec 21 07:07:03 EST 2008
Author: martinl
Date: 2008-12-21 07:07:03 -0500 (Sun, 21 Dec 2008)
New Revision: 34968
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: quering disables vector transparency (trac #304)
(merge from devbr6, r34967)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-12-21 12:03:33 UTC (rev 34967)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-12-21 12:07:03 UTC (rev 34968)
@@ -419,17 +419,30 @@
GRASS Attribute manager main window
- def __init__(self, parent, id, title, vectmap,
+ def __init__(self, parent, id=wx.ID_ANY,
size = wx.DefaultSize, style = wx.DEFAULT_FRAME_STYLE,
- pointdata=None, log=None):
+ title=None, vectorName=None, item=None, log=None):
- self.vectmap = vectmap
- self.pointdata = pointdata
- self.parent = parent # GMFrame
- self.cmdLog = log # self.parent.goutput
+ self.vectorName = vectorName
+ self.parent = parent # GMFrame
+ self.treeItem = item # item in layer tree
+ if self.parent and self.parent.GetName() == "LayerManager" and \
+ self.treeItem and not self.vectorName:
+ maptree = self.parent.curr_page.maptree
+ name = maptree.GetPyData(self.treeItem)[0]['maplayer'].GetName()
+ self.vectorName = name
+ self.cmdLog = log # self.parent.goutput
- wx.Frame.__init__(self, parent, id, title, style=style)
+ wx.Frame.__init__(self, parent, id, style=style)
+ # title
+ if not title:
+ self.SetTitle("%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
+ self.vectorName))
+ else:
+ self.SetTitle(title)
# icon
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
@@ -440,15 +453,7 @@
self.mapdisplay = self.parent.curr_page.maptree.mapdisplay
except:
self.map = self.mapdisplay = None
- if pointdata:
- self.icon = pointdata[0]
- self.pointsize = pointdata[1]
- else:
- self.icon = None
- self.pointsize = None
# status bar log class
self.log = Log(self) # -> statusbar
@@ -456,14 +461,14 @@
self.qlayer = None
# -> layers / tables description
- self.mapDBInfo = VectorDBInfo(self.vectmap)
+ self.mapDBInfo = VectorDBInfo(self.vectorName)
if len(self.mapDBInfo.layers.keys()) == 0:
wx.MessageBox(parent=self.parent,
message=_("Database connection for vector map <%s> "
"is not defined in DB file. "
"You can define new connection in "
- "'Manage layers' tab.") % self.vectmap,
+ "'Manage layers' tab.") % self.vectorName,
caption=_("Attribute Table Manager"),
style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
@@ -1091,7 +1096,7 @@
digitToolbar = self.mapdisplay.toolbars['vdigit']
if digitToolbar and digitToolbar.GetLayer() and \
- digitToolbar.GetLayer().GetName() == self.vectmap:
+ digitToolbar.GetLayer().GetName() == self.vectorName:
self.mapdisplay.digit.driver.SetSelected(cats, field=self.layer)
if zoom:
@@ -1100,7 +1105,14 @@
update=True)
else:
# add map layer with higlighted vector features
- self.AddQueryMapLayer()
+ self.AddQueryMapLayer() # -> self.qlayer
+ # set opacity based on queried layer
+ self.treeItem:
+ opacity = maptree.GetPyData(self.treeItem)[0]['maplayer'].GetOpacity(float=True)
+ self.qlayer.SetOpacity(opacity)
if zoom:
keyColumn = self.mapDBInfo.layers[self.layer]['key']
where = ''
@@ -1434,7 +1446,7 @@
list.SetItemText(item, nameTo)
self.listOfCommands.append(['v.db.renamecol',
- 'map=%s' % self.vectmap,
+ 'map=%s' % self.vectorName,
'layer=%d' % self.layer,
'column=%s,%s' % (name, nameTo)])
else:
@@ -1484,7 +1496,7 @@
item = list.GetFirstSelected()
while item != -1:
self.listOfCommands.append(['v.db.dropcol',
'column=%s' % list.GetItemText(item)])
list.DeleteItem(item)
@@ -1506,7 +1518,7 @@
cols = self.mapDBInfo.GetColumns(table)
for col in cols:
self.listOfCommands = [['v.db.dropcol',
'column=%s' % col]]
self.FindWindowById(self.layerPage[self.layer]['tableData']).DeleteAllItems()
@@ -1568,7 +1580,7 @@
if type == 'varchar':
type += ' (%d)' % length
self.listOfCommands.append(['v.db.addcol',
'columns=%s %s' % (name, type)])
@@ -1649,7 +1661,7 @@
' '.join(cmd))
gcmd.Command(cmd)
table = self.mapDBInfo.layers[self.layer]['table']
# update table description
@@ -1853,7 +1865,7 @@
"""SQL Builder button pressed"""
self.builder = sqlbuilder.SQLFrame(parent=self, id=wx.ID_ANY,
title=_("SQL Builder"),
- vectmap=self.vectmap)
+ vectorName=self.vectorName)
def OnTextEnter(self, event):
pass
@@ -1884,7 +1896,7 @@
gdialogs.CreateNewVector(parent=self, title=_('Extract selected features'),
log=self.cmdLog,
cmdDef=(["v.extract",
- "input=%s" % self.vectmap,
+ "input=%s" % self.vectorName,
"list=%s" % utils.ListOfCatsToRange(cats)],
"output"))
def OnDeleteSelected(self, event):
@@ -1902,13 +1914,13 @@
if self.OnDataItemDelete(None):
self.mapdisplay.digit.driver.SetSelected(map(int, cats), field=self.layer)
self.mapdisplay.digit.DeleteSelectedLines()
else:
gcmd.Command(['v.edit',
'--q',
'tool=delete',
'cats=%s' % utils.ListOfCatsToRange(cats)])
@@ -1928,10 +1940,12 @@
self.qlayer = None
if self.qlayer:
- self.qlayer.SetCmd(self.mapdisplay.AddTmpVectorMapLayer(self.vectmap, cats, addLayer=False))
+ self.qlayer.SetCmd(self.mapdisplay.AddTmpVectorMapLayer(self.vectorName, cats, addLayer=False))
else:
- self.qlayer = self.mapdisplay.AddTmpVectorMapLayer(self.vectmap, cats)
+ self.qlayer = self.mapdisplay.AddTmpVectorMapLayer(self.vectorName, cats)
+ return self.qlayer
def UpdateDialog(self, layer):
"""Updates dialog layout for given layer"""
@@ -1949,7 +1963,7 @@
self.notebook.SetSelection(2)
# fetch fresh db info
# add new page
@@ -3565,7 +3579,7 @@
f = AttributeManager(parent=None, id=wx.ID_ANY,
title="%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
argv[1]),
- size=(900,600), vectmap=argv[1])
+ size=(900,600), vectorName=argv[1])
f.Show()
app.MainLoop()
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-12-21 12:03:33 UTC (rev 34967)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-12-21 12:07:03 UTC (rev 34968)
@@ -3517,8 +3517,12 @@
useId=False,
addLayer=False))
else:
- self.AddTmpVectorMapLayer(mapName, cats, useId=False)
+ qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId=False)
+ opacity = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetOpacity(float=True)
+ qlayer.SetOpacity(opacity)
self.MapWindow.UpdateMap(render=False, renderVector=False)
if not self.dialogs['attributes'].IsShown():
self.dialogs['attributes'].Show()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-12-21 12:03:33 UTC (rev 34967)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-12-21 12:07:03 UTC (rev 34968)
@@ -1117,7 +1117,6 @@
return
size = icon = None
- mapname = utils.GetLayerNameFromCmd(dcmd)
for option in dcmd:
if option.find('size') > -1:
@@ -1132,10 +1131,8 @@
wx.Yield()
self.dbmanager = dbm.AttributeManager(parent=self, id=wx.ID_ANY,
- title="%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
- mapname),
- size=wx.Size(500,300), vectmap=mapname,
- pointdata=pointdata, log=self.goutput)
+ size=wx.Size(500, 300),
+ item=layer, log=self.goutput)
busy.Destroy()
