[GRASS-SVN] r35005 - in
grass/branches/develbranch_6/visualization/nviz: . html
svn_grass at osgeo.org
Tue Dec 23 06:30:24 EST 2008
Author: pkelly
Date: 2008-12-23 06:30:24 -0500 (Tue, 23 Dec 2008)
New Revision: 35005
grass/branches/develbranch_6/visualization/nviz/Makefile
grass/branches/develbranch_6/visualization/nviz/html/Makefile
Don't use find -L in an Msys build as the -L option isn't recognised
Modified: grass/branches/develbranch_6/visualization/nviz/Makefile
--- grass/branches/develbranch_6/visualization/nviz/Makefile 2008-12-23 11:27:23 UTC (rev 35004)
+++ grass/branches/develbranch_6/visualization/nviz/Makefile 2008-12-23 11:30:24 UTC (rev 35005)
@@ -9,6 +9,12 @@
PROG=nviz
INSTALL_DIR=$(GISBASE)/etc/$(NV_VER)
+ifneq ($(strip $(MINGW)),)
+ FIND = find
+else
+ FIND = find -L
+endif
SCRIPTS := \
scripts/script_get_line \
scripts/script_play \
@@ -37,7 +43,7 @@
for file in $(SCRIPTS) ; do $(INSTALL) $$file $(INSTALL_DIR)/scripts ; done
-$(MKDIR) $(INSTALL_DIR)/bitmaps
-$(MKDIR) $(INSTALL_DIR)/bitmaps/flythrough
- find -L bitmaps -path '*/.svn' -prune -o -type f -print | \
+ $(FIND) bitmaps -path '*/.svn' -prune -o -type f -print | \
while read file ; do $(INSTALL_DATA) $$file $(INSTALL_DIR)/$$file ; done
docs:
Modified: grass/branches/develbranch_6/visualization/nviz/html/Makefile
--- grass/branches/develbranch_6/visualization/nviz/html/Makefile 2008-12-23 11:27:23 UTC (rev 35004)
+++ grass/branches/develbranch_6/visualization/nviz/html/Makefile 2008-12-23 11:30:24 UTC (rev 35005)
@@ -5,6 +5,12 @@
GRASS_NVIZ_DOCS=$(GISBASE)/docs/html/nviz
+ FIND = find
+else
+ FIND = find -L
+endif
default:
-$(MKDIR) $(GISBASE)/docs
-$(MKDIR) $(GISBASE)/docs/html
@@ -14,5 +20,5 @@
-$(MKDIR) $(GRASS_NVIZ_DOCS)/nvimg
-$(MKDIR) $(GRASS_NVIZ_DOCS)/nvimg/panel
-$(MKDIR) $(GRASS_NVIZ_DOCS)/nvimg/work
- find -L . -type f \( -name '*.html' -o -name '*.png' -o -name '*.gif' \) -print | \
+ $(FIND) . -type f \( -name '*.html' -o -name '*.png' -o -name '*.gif' \) -print | \
while read file ; do $(INSTALL_DATA) $$file $(GRASS_NVIZ_DOCS)/$$file ; done
