[GRASS-SVN] r35021 - grass-addons/raster/mcda/r.mcda.electre
Thu Dec 25 05:00:26 EST 2008
Author: gianluca
Date: 2008-12-25 05:00:25 -0500 (Thu, 25 Dec 2008)
New Revision: 35021
   grass-addons/raster/mcda/r.mcda.electre/dominance.c
   grass-addons/raster/mcda/r.mcda.electre/main.c
r.mcda.electre: more efficient C code (with help by Glynn Clements and Moritx Lennert)
Modified: grass-addons/raster/mcda/r.mcda.electre/dominance.c
--- grass-addons/raster/mcda/r.mcda.electre/dominance.c	2008-12-23 20:43:23 UTC (rev 35020)
+++ grass-addons/raster/mcda/r.mcda.electre/dominance.c	2008-12-25 10:00:25 UTC (rev 35021)
@@ -6,7 +6,7 @@
 void build_weight_vect(int nrows, int ncols, int ncriteria, struct Option *weight, double *weight_vect);
-void build_dominance_matrix(int nrows, int ncols, int ncriteria, double *weight_vect, double **concordance_mat, double **discordance_mat, double ***decision_vol);
+void build_dominance_matrix(int nrows, int ncols, int ncriteria, double *weight_vect, double ***decision_vol);
@@ -44,60 +44,60 @@
-	int row1,col1,row2,col2;
-	int i,j,k,cont;
-	double row_sum_conc, col_sum_conc,row_sum_disc, col_sum_disc;
-	k=0;	/* make pairwise comparation and build concordance/discordance matrix*/
+void build_dominance_matrix(int nrows, int ncols, int ncriteria,double *weight_vect, double ***decision_vol)
+	int row1, col1, row2, col2;
+	int i, j, k, cont;
+	double *row_sum_conc = G_alloc_vector(nrows * ncols);
+	double *col_sum_conc = G_alloc_vector(nrows * ncols);
+	double *row_sum_disc = G_alloc_vector(nrows * ncols);
+	double *col_sum_disc = G_alloc_vector(nrows * ncols);
+	k = 0; 							/* make pairwise comparation and build concordance/discordance matrix */
 	for (row1 = 0; row1 < nrows; row1++)
 		G_percent(row1, nrows, 2);
-		for (col1 = 0; col1 < ncols; col1++)
+		for (col1 = 0; col1 < ncols; col1++)
-			j=0;
+			j = 0;
 			for (row2 = 0; row2 < nrows; row2++)
-				for (col2 = 0; col2 < ncols; col2++)
+				for (col2 = 0; col2 < ncols; col2++)
-					for(i=0;i<ncriteria;i++)
+					double conc = 0, disc = 0;
+					for (i = 0; i < ncriteria; i++)
-						if(decision_vol[row1][col1][i]>=decision_vol[row2][col2][i])
-							{concordance_mat[k][j]=concordance_mat[k][j]+weight_vect[i];}
-						if((decision_vol[row1][col1][i]-decision_vol[row2][col2][i])>concordance_mat[k][j])
-							{discordance_mat[k][j]=(decision_vol[row2][col2][i]-decision_vol[row1][col1][i]);}
+							double d = decision_vol[row1][col1][i] - decision_vol[row2][col2][i];
+							if (d >= 0)
+								conc += weight_vect[i];
+							if (d < disc) /*WARNING: if(d>conc)*//**/
+								disc = -d;
-					j++;/* increase rows index up to nrows*ncols*/
+					row_sum_conc[k] += conc;
+					col_sum_conc[j] += conc;
+					row_sum_disc[k] += disc;
+					col_sum_disc[j] += disc;
+					j++; /* increase rows index up to nrows*ncols */
-				k++; /* increase columns index up to nrows*ncols*/
+			k++; /* increase columns index up to nrows*ncols */
-		/*calculate concordance and discordance index and storage in decision_vol*/
-	cont=0;		/*variabile progressiva per riga/colonna della concordance_map*/
-	for(row1=0;row1<nrows;row1++)
+		/*calculate concordance and discordance index and storage in decision_vol */
+	cont = 0; /*variabile progressiva per riga/colonna della concordance_map */
+	for (row1 = 0; row1 < nrows; row1++) {
-		for(col1=0;col1<ncols;col1++)
-			row_sum_conc=col_sum_conc=row_sum_disc=col_sum_disc=0;
-			 /* da un valore incrementale ad ogni ciclo per progredire nella concordance_mat */
-			for(i=0;i<nrows*ncols;i++)
-				/*concordance index */
-				row_sum_conc=row_sum_conc+concordance_mat[cont][i];
-				col_sum_conc=row_sum_conc+concordance_mat[i][cont];
-				/*discordance index */
-				row_sum_disc=row_sum_disc+discordance_mat[cont][i];
-				col_sum_disc=row_sum_disc+discordance_mat[i][cont];
-			cont++;
-			decision_vol[row1][col1][ncriteria]=row_sum_conc-col_sum_conc;/*fill matrix with concordance index for each DCELL*/
-			decision_vol[row1][col1][ncriteria+1]=row_sum_disc-col_sum_disc;/*fill matrix with discordance index for each DCELL*/
+		for (col1 = 0; col1 < ncols; col1++) {
+							/*fill matrix with concordance index for each DCELL */
+							decision_vol[row1][col1][ncriteria] = row_sum_conc[cont] - col_sum_conc[cont];
+							/*fill matrix with discordance index for each DCELL */
+							decision_vol[row1][col1][ncriteria + 1] = row_sum_disc[cont] - col_sum_disc[cont];
+							cont++;
Modified: grass-addons/raster/mcda/r.mcda.electre/main.c
--- grass-addons/raster/mcda/r.mcda.electre/main.c	2008-12-23 20:43:23 UTC (rev 35020)
+++ grass-addons/raster/mcda/r.mcda.electre/main.c	2008-12-25 10:00:25 UTC (rev 35021)
@@ -31,7 +31,7 @@
     int nrows, ncols;
     int row1, row2, col1, col2;
     int outfd_concordance, outfd_discordance;		/* output file descriptor */
-	double *weight_vect, **concordance_mat, **discordance_mat, ***decision_vol;/* vector and matrix */
+	double *weight_vect, ***decision_vol;/* vector and matrix */
     struct History history;	/* holds meta-data (title, comments,..) */
@@ -88,7 +88,7 @@
 	exit(EXIT_FAILURE);
-	G_message("start: %s",G_date()); /*write calculation start time*/
+	G_message("Start: %s",G_date()); /*write calculation start time*/
 	/* number of file (=criteria) */
     while (criteria->answers[ncriteria]!=NULL)
@@ -137,11 +137,8 @@
 	/*values = G_malloc(ncriteria * sizeof(DCELL));*/
 	nrows = G_window_rows();
-    ncols = G_window_cols();
+        ncols = G_window_cols();
-	concordance_mat=G_alloc_matrix((nrows*ncols),(nrows*ncols)); /* dinamicaly allocation memory and set value=0 */
-	discordance_mat=G_alloc_matrix((nrows*ncols),(nrows*ncols));
 	/*memory allocation for-three dimensional matrix*/
 	decision_vol=G_malloc(nrows * sizeof(double*));
 	for (i=0; i<nrows; ++i)
@@ -182,9 +179,8 @@
-	G_message("build matrix: %s",G_date());
-	build_dominance_matrix(nrows,ncols,ncriteria,weight_vect,concordance_mat,discordance_mat, decision_vol); /*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index*/
+	build_dominance_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index*/
 	for(row1 = 0; row1 < nrows; row1++)
@@ -202,7 +198,7 @@
-	G_message("end: %s",G_date());
+	G_message("End: %s",G_date());
     /* memory cleanup */
 	for (i = 0; i<ncriteria; i++)
@@ -210,8 +206,6 @@
     G_free(outrast_concordance);
 	G_free(outrast_discordance);
-	G_free_matrix(concordance_mat);
-	G_free_matrix(discordance_mat);
 	G_free(decision_vol);
