[GRASS-SVN] r35035 - in grass/branches/releasebranch_6_4/gui/wxpython: . gui_modules
Fri Dec 26 10:59:56 EST 2008
Author: martinl
Date: 2008-12-26 10:59:56 -0500 (Fri, 26 Dec 2008)
New Revision: 35035
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/nviz_tools.py
   grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
wxGUI: various fixes
      vdigit: fix left mouse button click when moving vertex/line
      sort columns in ColumnSelect
      (merge from devbr6, r35033)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2008-12-26 15:59:03 UTC (rev 35034)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2008-12-26 15:59:56 UTC (rev 35035)
@@ -553,10 +553,13 @@
         try:
             table = dbInfo.layers[int(layer)]['table']
             columnchoices = dbInfo.tables[table]
+            columns = len(columnchoices.keys()) * ['']
+            for key, val in columnchoices.iteritems():
+                columns[val['index']] = key
         except (KeyError, ValueError):
-            columnchoices = {}
-        self.SetItems(columnchoices.keys())
+            columns = []
+        self.SetItems(columns)
         self.SetValue('')
 class DbColumnSelect(wx.ComboBox):
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py	2008-12-26 15:59:03 UTC (rev 35034)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py	2008-12-26 15:59:56 UTC (rev 35035)
@@ -741,7 +741,7 @@
                 item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
             except TypeError:
                 item = None
             if item and self.tree.IsItemChecked(item):
                 self.parent.digit.driver.DrawMap()
@@ -1087,12 +1087,14 @@
             move = (current[0] - previous[0],
                     current[1] - previous[1])
+            digitToolbar = self.parent.toolbars['vdigit']
             # dragging or drawing box with left button
             if self.mouse['use'] == 'pan':
                 self.DragMap(move)
             # dragging decoration overlay item
-            elif (self.mouse['use'] == 'pointer' and not self.parent.toolbars['vdigit']) and \
+            elif (self.mouse['use'] == 'pointer' and not digitToolbar) and \
                     self.dragid != None and \
                     self.dragid != 99:
                 self.DragItem(self.dragid, event)
@@ -1100,7 +1102,11 @@
             # dragging anything else - rubber band box or line
             else:
                 self.mouse['end'] = event.GetPositionTuple()[:]
-                if event.LeftIsDown():
+                digitClass = self.parent.digit
+                if event.LeftIsDown() and not \
+                        (digitToolbar and \
+                             digitToolbar.GetAction() in ("moveLine",) and \
+                             digitClass.driver.GetSelected() > 0):
                     # draw box only when left mouse button is pressed
                     self.MouseDraw(pdc=self.pdcTmp)
@@ -1439,11 +1445,11 @@
             if hasattr(self, "vdigitMove"):
                 if len(digitClass.driver.GetSelected()) == 0:
                     self.vdigitMove['begin'] = pos1 # left down
-                else:
-                    dx = pos2[0] - pos1[0] ### ???
-                    dy = pos2[1] - pos1[1]
-                    self.vdigitMove = (self.vdigitMove['begin'][0] + dx,
-                                       self.vdigitMove['begin'][1] + dy)
+                ### else:
+                ###    dx = pos2[0] - pos1[0] ### ???
+                ###    dy = pos2[1] - pos1[1]
+                ###    self.vdigitMove = (self.vdigitMove['begin'][0] + dx,
+                ###                       self.vdigitMove['begin'][1] + dy)
                 # eliminate initial mouse moving efect
                 self.mouse['begin'] = self.mouse['end']
@@ -1531,7 +1537,7 @@
                             if digitClass.driver.SelectLineByPoint(pos1,
        digitClass.GetSelectType()) is not None:
                                 nselected = 1
                 if nselected > 0:
                     if digitToolbar.GetAction() in ["moveLine", "moveVertex"]:
                         # get pseudoDC id of objects which should be redrawn
@@ -1569,7 +1575,10 @@
                         self.UpdateMap(render=False)
                 else: # no vector object found
-                    self.UpdateMap(render=False, renderVector=False)
+                    if not (digitToolbar.GetAction() in ["moveLine", "moveVertex"] and \
+                                len(self.vdigitMove['id']) > 0):
+                        # avoid left-click when features are already selected
+                        self.UpdateMap(render=False, renderVector=False)
             elif digitToolbar.GetAction() in ["splitLine", "addVertex", "removeVertex"]:
                 pointOnLine = digitClass.driver.SelectLineByPoint(pos1,
@@ -2031,7 +2040,7 @@
                                 x, y = self.Pixel2Cell(self.pdcTmp.GetIdBounds(self.vdigitMove['id'][2])[0:2])
                                 self.pdcTmp.RemoveId(self.vdigitMove['id'][2]-1)
                                 self.polycoords.append((x, y))
                             self.ClearLines(pdc=self.pdcTmp)
                             self.DrawLines(pdc=self.pdcTmp)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/nviz_tools.py	2008-12-26 15:59:03 UTC (rev 35034)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/nviz_tools.py	2008-12-26 15:59:56 UTC (rev 35035)
@@ -2415,27 +2415,24 @@
     def UpdateVectorPage(self, layer, data):
         vInfo = gcmd.Command(['v.info',
+                              '-t',
                               'map=%s' % layer.name])
         npoints = nprimitives = 0
         for line in vInfo.ReadStdOutput():
-            if 'Map is 3D' in line:
-                mapIs3D = line.replace('|', '').split(':')[1].strip()
-                if mapIs3D == 'Yes':
-                    mapIs3D = 1
-                else:
-                    mapIs3D = 0
-            elif 'Number of points' in line:
-                npoints = int(line.replace('|', '').split(':')[1].strip().split(' ')[0])
+            key, value = line.split('=')
+            if key == 'map3d':
+                mapIs3D = int(value)
+            elif key == 'points':
+                npoints = int(value)
                 nprimitives = npoints
-            elif 'Number of lines' in line:
-                nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0])
-            elif 'Number of boundaries' in line:
-                nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0]) # boundaries
-                nprimitives += int(line.replace('|', '').split(':')[2].strip()) # faces
-            elif 'Number of centroids' in line:
-                nprimitives += int(line.replace('|', '').split(':')[1].strip().split(' ')[0]) # centroids
-                nprimitives += int(line.replace('|', '').split(':')[2].strip()) # kernels
+            elif key in ('lines',
+                         'boundaries',
+                         'centroids',
+                         'faces',
+                         'kernels'):
+                nprimitives += int(value)
         if mapIs3D:
             desc = _("Vector map <%s> is 3D") % layer.name
             enable = False
Modified: grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py	2008-12-26 15:59:03 UTC (rev 35034)
+++ grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py	2008-12-26 15:59:56 UTC (rev 35035)
@@ -291,8 +291,10 @@
         #create main notebook widget
         nbStyle = FN.FNB_FANCY_TABS | \
-                    FN.FNB_BOTTOM | \
-                    FN.FNB_NO_NAV_BUTTONS
+            FN.FNB_BOTTOM | \
+            FN.FNB_NO_NAV_BUTTONS | \
+            FN.FNB_NO_X_BUTTON
         self.notebook = FN.FlatNotebook(parent=self, id=wx.ID_ANY, style=nbStyle)
         #self.notebook = wx.aui.AuiNotebook(parent=self, id=wx.ID_ANY, style=wx.aui.AUI_NB_BOTTOM)
@@ -517,7 +519,7 @@
         authorsFile = open(os.path.join(os.getenv("GISBASE"), "AUTHORS"), 'r')
         info.SetDevelopers([unicode(''.join(authorsFile.readlines()), "utf-8")])
         authorsFile.close()
         wx.AboutBox(info)
     def OnWorkspace(self, event):
@@ -1432,16 +1434,16 @@
                 name = str(self.curr_page.maptree.GetItemText(item))
                 idx = name.find('(opacity')
                 if idx > -1:
-                    layerName += '<' + name[:idx].strip(' ') + '>, '
+                    layerName += '<' + name[:idx].strip(' ') + '>,\n'
                 else:
-                    layerName += '<' + name + '>, '
-            layerName = layerName.rstrip(', ')
+                    layerName += '<' + name + '>,\n'
+            layerName = layerName.rstrip(',\n')
-            if layerName:
-                message = _("Do you want to remove map layer %s "
+            if len(layerName) > 2: # <>
+                message = _("Do you want to remove map layer(s)\n%s\n"
                             "from layer tree?") % layerName
             else:
-                message = _("Do you want to remove selected map layer "
+                message = _("Do you want to remove selected map layer(s) "
                             "from layer tree?")
             dlg = wx.MessageDialog (parent=self, message=message,
