[GRASS-SVN] r35042 - grass/branches/releasebranch_6_4/display/d.vect
Fri Dec 26 11:36:17 EST 2008
Author: martinl
Date: 2008-12-26 11:36:17 -0500 (Fri, 26 Dec 2008)
New Revision: 35042
   grass/branches/releasebranch_6_4/display/d.vect/main.c
   grass/branches/releasebranch_6_4/display/d.vect/plot1.c
d.vect: fix bug for vector maps open at level 1
      message standardization
      (merge from devbr6, r35040)
Modified: grass/branches/releasebranch_6_4/display/d.vect/main.c
--- grass/branches/releasebranch_6_4/display/d.vect/main.c	2008-12-26 16:35:31 UTC (rev 35041)
+++ grass/branches/releasebranch_6_4/display/d.vect/main.c	2008-12-26 16:36:17 UTC (rev 35042)
@@ -463,13 +463,13 @@
 	has_fcolor = 0;
     else if (ret == 0) {	/* error */
-	G_fatal_error(_("Unknown color: [%s]"), fcolor_opt->answer);
+	G_fatal_error(_("Unknown color: '%s'"), fcolor_opt->answer);
     size = atoi(size_opt->answer);
     Symb = S_read(icon_opt->answer);
     if (Symb == NULL)
-	G_warning(_("Cannot read symbol, cannot display points"));
+	G_warning(_("Unable to read symbol, unable todisplay points"));
     else
 	S_stroke(Symb, size, 0.0, 0);
@@ -676,12 +676,12 @@
 		    D_line_width(default_width);
 	    else
-		G_warning(_("Cannot display areas, topology not available"));
+		G_warning(_("Unable to display areas, topology not available"));
 	if (display & DISP_SHAPE) {
 	    if (id_flag->answer && level < 2) {
-		G_warning(_("Cannot display lines by id, topology not available"));
+		G_warning(_("Unable to display lines by id, topology not available"));
 	    else {
 		stat = plot1(&Map, type, area, Clist,
@@ -723,7 +723,7 @@
 	    if (level >= 2)
 		stat = topo(&Map, type, area, &lattr);
 	    else
-		G_warning(_("Cannot display topology, not available"));
+		G_warning(_("Unable to display topology, not available"));
Modified: grass/branches/releasebranch_6_4/display/d.vect/plot1.c
--- grass/branches/releasebranch_6_4/display/d.vect/plot1.c	2008-12-26 16:35:31 UTC (rev 35041)
+++ grass/branches/releasebranch_6_4/display/d.vect/plot1.c	2008-12-26 16:36:17 UTC (rev 35042)
@@ -280,8 +280,8 @@
     line = 0;
     while (1) {
+	line++;
 	if (Vect_level(Map) >= 2) {
-	    line++;
 	    if (line > nlines)
 		break;
 	    if (!Vect_line_alive(Map, line))
@@ -290,11 +290,10 @@
 	else {
 	    ltype = Vect_read_next_line(Map, Points, Cats);
-	    switch (ltype) {
-	    case -1:
-		G_warning(_("Unable to read vector map"));
-		return -1;
-	    case -2:		/* EOF */
+	    if (ltype == -1) {
+		G_fatal_error(_("Unable to read vector map"));
+	    else if (ltype == -2) { /* EOF */
 		break;
@@ -355,12 +354,11 @@
 	if (table_colors_flag) {
 	    /* only first category */
-	    cat = Vect_get_line_cat(Map, line,
-				    (Clist->field > 0 ? Clist->field :
-				     (Cats->n_cats >
-				      0 ? Cats->field[0] : 1)));
+	    Vect_cat_get(Cats,
+			 (Clist->field > 0 ? Clist->field :
+			  (Cats->n_cats >
+			   0 ? Cats->field[0] : 1)), &cat);
 	    if (cat >= 0) {
 		G_debug(3, "display element %d, cat %d", line, cat);
@@ -410,7 +408,7 @@
 	if (cats_color_flag) {
 	    custom_rgb = FALSE;
 	    if (Clist->field > 0) {
-		cat = Vect_get_line_cat(Map, line, Clist->field);
+		Vect_cat_get(Cats, Clist->field, &cat);
 		if (cat >= 0) {
 		    /* fetch color number from category */
@@ -441,13 +439,12 @@
 	if (nrec_width) {
-				     (Cats->n_cats >
+			  (Cats->n_cats >
 	    if (cat >= 0) {
