[GRASS-SVN] r35070 -
grass/branches/develbranch_6/visualization/nviz/scripts
svn_grass at osgeo.org
Sun Dec 28 02:30:39 EST 2008
Author: cmbarton
Date: 2008-12-28 02:30:38 -0500 (Sun, 28 Dec 2008)
New Revision: 35070
grass/branches/develbranch_6/visualization/nviz/scripts/nviz2.2_script
Fixed bug in nviz startup (preventing menu panel from initially showing). Fixed bug in hiding and showing panels. Minor cosmetics
Modified: grass/branches/develbranch_6/visualization/nviz/scripts/nviz2.2_script
--- grass/branches/develbranch_6/visualization/nviz/scripts/nviz2.2_script 2008-12-28 07:28:26 UTC (rev 35069)
+++ grass/branches/develbranch_6/visualization/nviz/scripts/nviz2.2_script 2008-12-28 07:30:38 UTC (rev 35070)
@@ -63,7 +63,7 @@
set Nv_(TOP) ".middle.draw"
set Nv_(APP) "."
set Nv_(P_AREA) ".middle.panelarea.panels"
-set Nv_(PAREA) ".middle.panelarea"
+set Nv_(PAREA) ".middle.panelarea"
set Nv_(AREA) ".top"
set Nv_(CALLED_SET_FOCUS) no
set Nv_(CurrSurf) 0
@@ -71,6 +71,7 @@
set Nv_(CurrSite) 0
set Nv_(CurrSdiff) 0
set Nv_(CurrVol) 0
+set Nv_(hidemenus) 1
# Some quick code to initialize the CurrSurf, CurrVect and CurrSite variables
set temp [Nget_surf_list]
@@ -185,37 +186,32 @@
-# Procedure to hide menus
+# Procedure to hide or reveal panels
-proc hide_menus {} {
- global Nv_ bit_map_path
+proc hide_menus { } {
+ global Nv_
+ global bit_map_path
+ if {$Nv_(hidemenus) == "1" } {
+ set Nv_(hidemenus) 0
+ $Nv_(PAREA).canvas configure -width 0
+ $Nv_(PAREA).f1.b1 configure -bitmap @$bit_map_path/right \
+ -width 12 -height 18 -command "hide_menus"
+ help $Nv_(PAREA).f1.b1 balloon "Show Panels"
+ #$Nv_(AREA).menu.config.m entryconfigure 1 -label "Show Panels" -command "show_menus"
+ } else {
+ set Nv_(hidemenus) 1
+ $Nv_(PAREA).canvas configure -width [winfo width $Nv_(P_AREA)]
+ $Nv_(PAREA).f1.b1 configure -bitmap @$bit_map_path/left \
+ help $Nv_(PAREA).f1.b1 balloon "Hide Panels"
+ #$Nv_(AREA).menu.config.m entryconfigure 1 -label "Hide Panels" -command "hide_menus"
+ update
- $Nv_(PAREA).canvas configure -width 0
- $Nv_(PAREA).f1.b1 configure -bitmap @$bit_map_path/right \
- -width 8 -height 12 -command "show_menus"
- help $Nv_(PAREA).f1.b1 balloon "Show Panels"
- $Nv_(AREA).menu.config.m entryconfigure 1 -label "Show Panels" -command "show_menus"
-# Procedure to reveal menus
-proc show_menus {} {
- $Nv_(PAREA).canvas configure -width [winfo width $Nv_(P_AREA)]
- $Nv_(PAREA).f1.b1 configure -bitmap @$bit_map_path/left \
- -width 8 -height 12 -command "hide_menus"
- help $Nv_(PAREA).f1.b1 balloon "Hide Panels"
- $Nv_(AREA).menu.config.m entryconfigure 1 -label "Hide Panels" -command "hide_menus"
# add key bindings so that menu shortcut keys can be used
@@ -238,7 +234,7 @@
wm sizefrom . user
#Use three base frames
- frame .top -relief flat -bd 0
+ frame $Nv_(AREA) -relief flat -bd 0
frame .middle -relief flat -bd 0
frame .bottom -relief flat -bd 0
@@ -258,8 +254,8 @@
pack $Nv_(PAREA) -side left -fill y -expand no
#togl canvas
- frame .middle.draw -relief groove -bd 2
- pack .middle.draw -side left -fill both -expand yes
+ frame $Nv_(TOP) -relief groove -bd 2
+ pack $Nv_(TOP) -side left -fill both -expand yes
entry .bottom.entry -relief sunken -state disabled \
-background #FFFFFF -textvariable Nv_(text)
@@ -267,29 +263,29 @@
set cwidth [exec $src_boot/bin/g.gisenv X3D_WIDTH]
set cheight [exec $src_boot/bin/g.gisenv X3D_HEIGHT]
if {$cwidth > 0 && $cheight > 0} {
- togl .middle.draw.canvas -rgba true -double true -depth true \
+ togl $Nv_(TOP).canvas -rgba true -double true -depth true \
-width $cwidth -height $cheight
- pack .middle.draw.canvas -side top -expand no
+ pack $Nv_(TOP).canvas -side top -expand no
} elseif {$cwidth == "" && $cheight > 0} {
-height $cheight
- pack .middle.draw.canvas -side top -fill x -expand yes
+ pack $Nv_(TOP).canvas -side top -fill x -expand yes
} elseif {$cheight == "" && $cwidth > 0} {
-width $cwidth
- pack .middle.draw.canvas -side top -fill y -expand yes
+ pack $Nv_(TOP).canvas -side top -fill y -expand yes
} else {
#nothing set
set constrained 1
- pack .middle.draw.canvas -side top -fill both -expand yes
+ pack $Nv_(TOP).canvas -side top -fill both -expand yes
- bind .middle.draw.canvas <Expose> {Nv_expose %W}
- bind .middle.draw.canvas <Configure> {set Nv_(height) %h}
- set tags [bindtags .middle.draw.canvas]
+ bind $Nv_(TOP).canvas <Expose> {Nv_expose %W}
+ bind $Nv_(TOP).canvas <Configure> {set Nv_(height) %h}
+ set tags [bindtags $Nv_(TOP).canvas]
# the Togl widget can't be redrawn until the main panel has been created
# update
@@ -300,7 +296,7 @@
#Moved the following packing here to satisfy some TCL versions
#Prevents minimized GUI
#top frame for menubar
- pack .top -side top -fill x -expand no
+ pack $Nv_(AREA) -side top -fill x -expand no
#middle frame for menus and togl canvas
pack .middle -side top -fill both -expand yes
#botom frame for statusbar
@@ -318,8 +314,9 @@
scrollbar $Nv_(PAREA).f1.scrolly -command "$Nv_(PAREA).canvas yview"
bind all <MouseWheel> {$Nv_(PAREA).canvas yview scroll [expr -1 * %D] units}
button $Nv_(PAREA).f1.b1 -bitmap @$bit_map_path/left \
frame $Nv_(P_AREA) -relief flat
@@ -460,8 +457,12 @@
# DEBUG
if {$DEBUG} {puts "menubar made"}
- focus $Nv_(AREA).menu
+ raise .bottom
+ raise .middle
+ raise $Nv_(AREA)
+ focus -force $Nv_(AREA).menu
return $BASE
@@ -673,7 +674,7 @@
if {$DEBUG} {puts "Nv_mkConfigMenu 1"}
set j 0
- $P.m add command -label "Hide Panels" -command hide_menus
+ $P.m add command -label "Hide Panels" -command "hide_menus"
$P.m add separator
foreach i $Nv_(config) {
@@ -706,15 +707,13 @@
global Nv_
global BGColor
-# if [$W islinked] then {
if {$Nv_(First)} then {
init_graphics
set Nv_(First) 0
} else {
- Nbackground $BGColor
+ Nbackground $BGColor
Nquick_draw
proc save_3dview { dummy } {
@@ -811,10 +810,10 @@
button .canvas_size.f2.b1 -text "Close" \
-command {
if {$constrained} {
- pack $Nv_(TOP).canvas -side top -fill both -expand yes
} else {
- $Nv_(TOP).canvas configure -width $cwidth -height $cheight
- pack $Nv_(TOP).canvas -side top -expand no -fill none
+ $Nv_(TOP).canvas configure -width $cwidth -height $cheight
+ pack $Nv_(TOP).canvas -side top -expand no -fill none
#Need Nset_viewport to make sure reshape is called
Nset_viewport $cwidth $cheight
@@ -892,13 +891,13 @@
# Go through each of the panels one at a time and force them to open
# This should update them all so they display correctly
- Nv_openPanel $i
- update
+ Nv_openPanel $i
+ update
foreach i $Nv_(panels) {
- Nv_openPanel $i
- update
+ Nv_openPanel $i
+ update
Nv_closeAllPanels
@@ -923,32 +922,32 @@
set tmp_list $Nv_(panels)
lappend tmp_list main
- set cmd_name "Nviz_$i"
- append cmd_name "_reset"
- if {[catch {$cmd_name} error_code] != 0} then {
- puts "Diagnostic: $error_code -- Reset procedure for panel $i may not be defined"
+ set cmd_name "Nviz_$i"
+ append cmd_name "_reset"
+ if {[catch {$cmd_name} error_code] != 0} then {
+ puts "Diagnostic: $error_code -- Reset procedure for panel $i may not be defined"
- Nv_openPanel $i
- update
+ Nv_openPanel $i
+ update
- Nv_openPanel $i
- update
+ Nv_openPanel $i
+ update
Nv_closeAllPanels
@@ -968,31 +967,31 @@
foreach i $tmp_list {
- Nv_openPanel $i
- update
+ Nv_openPanel $i
+ update
- Nv_openPanel $i
- update
+ Nv_openPanel $i
+ update
Nv_closeAllPanels
@@ -1010,12 +1009,12 @@
# append ".nviz" extension to the filename if it doesn't already have one
if { [string compare [file extension $new_file] ".nviz"] != 0 } then {
- append new_file ".nviz"
+ append new_file ".nviz"
if {[catch {set file_hook [open $new_file w]} error_code] != 0} then {
- display_error "While opening file: $error_code"
- return
+ display_error "While opening file: $error_code"
+ return
# Show that we are busy
@@ -1024,11 +1023,11 @@
# Now call each of the panels one at a time and pass the
# file hook so that each panel can write out its state
foreach i $Nv_(panelstate) {
- append cmd_name "_save"
- if {[catch {$cmd_name $file_hook} error_code] != 0} then {
- puts "Diagnostic: $error_code -- Save procedure for panel $i may not be defined"
+ append cmd_name "_save"
+ if {[catch {$cmd_name $file_hook} error_code] != 0} then {
+ puts "Diagnostic: $error_code -- Save procedure for panel $i may not be defined"
# Finally, close the file and exit
@@ -1050,7 +1049,7 @@
Nset_cancel_func update
# and start the ball rolling...
-Nv_makeGUI .top
+Nv_makeGUI $Nv_(AREA)
# Center the view on initialization
look_center
@@ -1078,13 +1077,12 @@
# Automatically load state file from command line
if {[catch {set NvizLoadState}] == 0} then {
+ global Nv_
-global Nv_
+ appBusy
+ load_state_aux $NvizLoadState
-appBusy
-load_state_aux $NvizLoadState
-appNotBusy
+ appNotBusy
if {$DEBUG} {puts "Finished loading, call draw all"}
