[GRASS-SVN] r35111 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Dec 29 23:11:47 EST 2008
Author: cmbarton
Date: 2008-12-29 23:11:47 -0500 (Mon, 29 Dec 2008)
New Revision: 35111
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/profile.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
Fixing bugs in profile module (hanging/crashing with many transect nodes, and nodes off map) and making interface a little more robust (including better enforcement of proper profiling steps: 1) choose map to profile, 2) draw transect, 3) create profile)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-12-30 04:09:08 UTC (rev 35110)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-12-30 04:11:47 UTC (rev 35111)
@@ -3734,6 +3734,9 @@
id=wx.ID_ANY, pos=wx.DefaultPosition, size=(700,300),
style=wx.DEFAULT_FRAME_STYLE, rasterList=raster)
self.profile.Show()
+ # Open raster select dialog to make sure that a raster (and the desired raster)
+ # is selected to be profiled
+ self.profile.OnSelectRaster(None)
def FormatDist(self, dist):
"""Format length numbers and units in a nice way,
Modified: grass/trunk/gui/wxpython/gui_modules/profile.py
--- grass/trunk/gui/wxpython/gui_modules/profile.py 2008-12-30 04:09:08 UTC (rev 35110)
+++ grass/trunk/gui/wxpython/gui_modules/profile.py 2008-12-30 04:11:47 UTC (rev 35111)
@@ -55,6 +55,7 @@
from debug import Debug as Debug
from icon import Icons as Icons
from preferences import globalSettings as UserSettings
+import grass
class ProfileFrame(wx.Frame):
@@ -250,11 +251,12 @@
# create list of coordinate points for r.profile
dist = 0
cumdist = 0
self.coordstr = ''
lasteast = lastnorth = None
if len(self.mapwin.polycoords) > 0:
for point in self.mapwin.polycoords:
# build string of coordinate points for r.profile
@@ -272,13 +274,13 @@
# create datalist for each raster map
for r in self.raster.itervalues():
if r['name'] == '':
continue
r['datalist'] = self.CreateDatalist(r['name'], self.coordstr)
r['plegend'] = _('Profile of %s') % r['name']
p = gcmd.Command(['r.info',
'map=%s' % r['name'],
'-u',
@@ -295,6 +297,7 @@
self.ylabel = ''
i = 0
if r['name'] == '':
continue
@@ -309,6 +312,7 @@
# create list of coordinates for transect segment markers
# get value of raster cell at coordinate point
@@ -400,16 +404,18 @@
Build a list of distance, value pairs for points along transect
datalist = []
+ import subprocess
try:
- cmdlist = ['r.profile',
- 'input=%s' % raster,
- 'profile=%s' % coords,
- 'null=nan',
- '--quiet']
- p = gcmd.Command(cmdlist)
- for outline in p.ReadStdOutput():
+ p = grass.read_command("r.profile",
+ input=raster,
+ profile=coords,
+ null="nan",
+ quiet=True
+ for outline in p.strip().split('\n'):
dist, elev = outline.split(' ')
- datalist.append((dist,elev))
+ if elev != 'nan': datalist.append((dist,elev))
return datalist
except gcmd.CmdError, e:
@@ -424,7 +430,7 @@
segments, these are drawn as points. Profile transect is drawn, using
methods in mapdisp.py
if len(self.mapwin.polycoords) == 0 or self.raster[0]['name'] == '':
dlg = wx.MessageDialog(parent=self,
message=_('You must draw a transect to profile in the map display window.'),
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-12-30 04:09:08 UTC (rev 35110)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-12-30 04:11:47 UTC (rev 35111)
@@ -1245,12 +1245,12 @@
# tool, label, bitmap, kind, shortHelp, longHelp, handler
return (
+ (self.addraster, 'raster', Icons["addrast"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["addrast"].GetLabel(), Icons["addrast"].GetDesc(),
+ self.parent.OnSelectRaster),
(self.transect, 'transect', Icons["transect"].GetBitmap(),
wx.ITEM_NORMAL, Icons["transect"].GetLabel(), Icons["transect"].GetDesc(),
self.parent.OnDrawTransect),
- (self.addraster, 'raster', Icons["addrast"].GetBitmap(),
- wx.ITEM_NORMAL, Icons["addrast"].GetLabel(), Icons["addrast"].GetDesc(),
- self.parent.OnSelectRaster),
(self.draw, 'profiledraw', Icons["profiledraw"].GetBitmap(),
wx.ITEM_NORMAL, Icons["profiledraw"].GetLabel(), Icons["profiledraw"].GetDesc(),
self.parent.OnCreateProfile),
