[GRASS-SVN] r29921 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Feb 1 00:16:58 EST 2008
Author: cmbarton
Date: 2008-02-01 00:16:58 -0500 (Fri, 01 Feb 2008)
New Revision: 29921
grass/trunk/gui/wxpython/gui_modules/georect.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
Georectifier will now switch easily in and out of xy location. GCPs can be placed on xy map display. Code cleaned up.
Modified: grass/trunk/gui/wxpython/gui_modules/georect.py
--- grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-01 03:39:19 UTC (rev 29920)
+++ grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-01 05:16:58 UTC (rev 29921)
@@ -72,51 +72,16 @@
# global variables
global grassdatabase
-global curr_location
-global curr_mapset
-global xy_location
-global xy_mapset
global xy_group
global xy_map
global maptype
-xy_location = ''
-xy_mapset = ''
xy_group = ''
xy_map = ''
maptype = 'cell'
-class Georectify(object):
- Init class for georectifying. Launches startup dialog
- for setting georectifying parameters.
- def __init__(self,parent):
- self.parent = parent
- # launch the startup dialog
- dlg = GeorectStart(self.parent)
- dlg.CenterOnScreen()
- dlg.ShowModal()
- # If OK button pressed in decoration control dialog
-# if dlg.ShowModal() == wx.ID_OK:
-# # go on to GCP management
-# pass
- # starup dialog calls GCP which
- def StartUp(self):
- pass
class TitledPage(wiz.WizardPageSimple):
Class to make wizard pages. Generic methods to make
@@ -159,8 +124,8 @@
self.grassdatabase = p.ReadStdOutput()[0]
# read original environment settings
- self.orig_env = os.environ.copy()
- self.orig_gisrc = self.orig_env['GISRC']
+ #self.orig_env = os.environ.copy()
+ self.orig_gisrc = os.environ['GISRC']
f = open(self.orig_gisrc)
self.gisrc_dict = {}
try:
@@ -169,18 +134,8 @@
self.gisrc_dict[line.split(':')[0]] = line.split(':')[1].strip()
finally:
f.close()
- self.src_gisrc = '' #GISRC file for source location/mapset of map(s) to georectify
+ self.new_gisrc = '' #GISRC file for source location/mapset of map(s) to georectify
- cmdlist = ['g.gisenv', 'get=LOCATION_NAME']
- global curr_location
- p = gcmd.Command(cmdlist)
- curr_location = p.ReadStdOutput()[0]
- cmdlist = ['g.gisenv', 'get=MAPSET']
- global curr_mapset
- curr_mapset = p.ReadStdOutput()[0]
# define wizard pages
self.wizard = wiz.Wizard(parent, -1, "Setup for georectification")
self.startpage = LocationPage(self.wizard, self)
@@ -210,56 +165,63 @@
else:
wx.MessageBox("Georectifying setup canceled.")
- # start display showing xymap
- self.Map = render.Map() # instance of render.Map to be associated with display
- global maptype
- global xy_map
- if maptype == 'cell':
- rendertype = 'raster'
- cmdlist = ['d.rast', 'map=%s' % xy_map]
- elif maptype == 'vector':
- rendertype = 'vector'
- cmdlist = ['d.vect', 'map=%s' % xy_map]
- self.Map.AddLayer(type=rendertype, command=cmdlist,l_active=True,
- l_hidden=False, l_opacity=1, l_render=False)
- self.xy_mapdisp = mapdisp.MapFrame(self.parent, title="Set ground control points (GCPs)",
+ # start display showing xymap - need to put an if statement here
+ if success != False:
+ self.Map = render.Map() # instance of render.Map to be associated with display
+ global maptype
+ global xy_map
+ if maptype == 'cell':
+ rendertype = 'raster'
+ cmdlist = ['d.rast', 'map=%s' % xy_map]
+ elif maptype == 'vector':
+ rendertype = 'vector'
+ cmdlist = ['d.vect', 'map=%s' % xy_map]
+ self.Map.AddLayer(type=rendertype, command=cmdlist,l_active=True,
+ l_hidden=False, l_opacity=1, l_render=False)
+ self.xy_mapdisp = mapdisp.MapFrame(self.parent, title="Set ground control points (GCPs)",
pos=wx.DefaultPosition, size=(640,480),
style=wx.DEFAULT_FRAME_STYLE, toolbars=["georect"],
- Map=self.Map)
+ Map=self.Map, gwiz=self, georect=True)
+ self.mapwin = self.xy_mapdisp.MapWindow
+ # set mouse characteristics
+ self.mapwin.mouse['box'] = 'point'
+ self.mapwin.zoomtype = 0
+ self.mapwin.pen = wx.Pen(colour='black', width=2, style=wx.SOLID)
+ self.mapwin.SetCursor(self.xy_mapdisp.cursors["cross"])
+ # draw selected xy map
+ self.xy_mapdisp.MapWindow.UpdateMap()
- # draw selected xy map
- self.xy_mapdisp.MapWindow.UpdateMap()
+ #show new display
+ self.xy_mapdisp.Show()
+ self.xy_mapdisp.Refresh()
+ self.xy_mapdisp.Update()
+ # start GCP form
+ self.gcpmgr = GCP(self.parent)
+ self.gcpmgr.Show()
+ self.gcpmgr.Refresh()
+ self.gcpmgr.Update()
- #show new display
- self.xy_mapdisp.Show()
- self.xy_mapdisp.Refresh()
- self.xy_mapdisp.Update()
- # start GCP form
- self.gcpmgr = GCP(self.parent)
- self.gcpmgr.Show()
- self.gcpmgr.Refresh()
- self.gcpmgr.Update()
self.Cleanup()
def SetSrcEnv(self, location, mapset):
"""Create environment to use for location and mapset
that are the source of the file(s) to georectify"""
- self.src_env = os.environ.copy()
self.gisrc_dict['LOCATION_NAME'] = location
self.gisrc_dict['MAPSET'] = mapset
- self.src_gisrc = utils.GetTempfile()
- f = open(self.src_gisrc, mode='w')
+ self.new_gisrc = utils.GetTempfile()
+ f = open(self.new_gisrc, mode='w')
for line in self.gisrc_dict.items():
f.write(line[0]+": "+line[1]+"\n")
f.close()
- self.src_env["GISRC"] = self.src_gisrc
def SwitchEnv(self, grc):
"""Switches between original working location/mapset and
@@ -267,34 +229,29 @@
if grc == 'original':
os.environ["GISRC"] = str(self.orig_gisrc)
- elif grc == 'source':
- os.environ["GISRC"] = str(self.src_gisrc)
+ elif grc == 'new':
+ os.environ["GISRC"] = str(self.new_gisrc)
def onWizFinished(self):
- global xy_location
- global xy_mapset
global xy_group
global xy_map
global maptype
- print 'Current global variables'
- print 'curr_location=',curr_location
- print 'curr_mapset=',curr_mapset
- print 'xy_location=',xy_location
- print 'xy_mapset=',xy_mapset
- print 'xy_group=',xy_group
- print 'xy_map=',xy_map
- print 'maptype=',maptype
+ #print 'Current global variables'
+ #print 'curr_location=',curr_location
+ #print 'curr_mapset=',curr_mapset
+ #print 'xy_location=',xy_location
+ #print 'xy_mapset=',xy_mapset
+ #print 'xy_group=',xy_group
+ #print 'xy_map=',xy_map
+ #print 'maptype=',maptype
return True
def Cleanup(self):
# return to current location and mapset
self.SwitchEnv('original')
self.wizard.Destroy()
@@ -374,10 +331,13 @@
"""Sets source location for map(s) to georectify"""
self.xylocation = event.GetString()
+ #create a list of valid mapsets
tmplist = os.listdir(os.path.join(self.grassdatabase,self.xylocation))
self.mapsetList = []
for item in tmplist:
- if os.path.isdir(os.path.join(self.grassdatabase,self.xylocation,item)):
+ if os.path.isdir(os.path.join(self.grassdatabase,self.xylocation,item)) and \
+ os.path.exists(os.path.join(self.grassdatabase,self.xylocation,item,'WIND')):
self.mapsetList.append(item)
self.cb_mapset.SetItems(self.mapsetList)
@@ -460,7 +420,7 @@
self.xylocation = self.parent.gisrc_dict['LOCATION_NAME']
self.xymapset = self.parent.gisrc_dict['MAPSET']
- print 'location/mapset =',self.xylocation,self.xymapset
+ # create a list of groups in selected mapset
tmplist = os.listdir(os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group'))
if event.GetDirection() and xy_group == '':
@@ -517,7 +477,7 @@
if event.GetDirection():
# switch to xy location if coming into the page from preceding
- self.parent.SwitchEnv('source')
+ self.parent.SwitchEnv('new')
self.selection.SetElementList(maptype)
else:
# switch back to current location if leaving the page
@@ -528,6 +488,7 @@
Manages ground control points for georectifying. Calculates RMS statics.
Calls i.rectify or v.transform to georectify map.
def __init__(self,parent,id=-1,title="Create & manage ground control points"):
wx.Frame.__init__(self, parent, id , title, size=(500,400))
@@ -568,7 +529,6 @@
self.list.SetStringItem(index, 4, i[4])
self.list.SetStringItem(index, 5, i[5])
p.SetSizer(self.sizer)
self.Bind(wx.EVT_RADIOBOX, self.OnGRMethod, self.rb_grmethod)
@@ -631,7 +591,6 @@
def OnItemSelected(self, event):
self.selected = event.GetIndex()
class CheckListCtrl(wx.ListCtrl, CheckListCtrlMixin, ListCtrlAutoWidthMixin):
def __init__(self, parent):
wx.ListCtrl.__init__(self, parent, -1, style=wx.LC_REPORT | wx.SUNKEN_BORDER)
@@ -639,6 +598,9 @@
ListCtrlAutoWidthMixin.__init__(self)
+# These 2 grid classes are ones I tried to use instead of a list. Might want
+# to rethink this later
class GCPGrid(gridlib.Grid):
gridlib.Grid.__init__(self, parent, -1)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-02-01 03:39:19 UTC (rev 29920)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-02-01 05:16:58 UTC (rev 29921)
@@ -1103,6 +1103,10 @@
self.DrawLines(pdc=self.pdcTmp)
except:
pass
+ elif self.mouse["use"] == "pointer" and self.parent.grtoolbar:
+ print self.Pixel2Cell(self.mouse['end'])
+ self.DrawCross(pdc=self.pdcTmp, coords=self.mouse['end'],
+ size=5)
elif self.mouse["use"] == "pointer" and self.parent.digittoolbar:
# digitization tool active
@@ -1995,7 +1999,7 @@
pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
tree=None, notebook=None, gismgr=None, page=None,
- Map=None, auimgr=None):
+ Map=None, auimgr=None, gwiz=None, georect=False):
Main map display window with toolbars, statusbar and
DrawWindow
@@ -2014,6 +2018,8 @@
gismgr -- GIS Manager panel
page -- notebook page with layer tree
Map -- instance of render.Map
+ gwiz -- ID of GeorectWizard
+ georect -- is window used by georectifier
Debug.msg (1, "MapFrame.__init__(): size=%d,%d" % (size[0], size[1]))
@@ -2025,6 +2031,9 @@
self.tree = tree # GIS Manager layer tree object
self.page = page # Notebook page holding the layer tree
self.layerbook = notebook # GIS Manager layer tree notebook
+ self.georect = georect # Map display used for setting GCPs for georectifier
+ self.gwiz = gwiz # Georectifier object
+ self.parent = parent
# available cursors
@@ -2244,12 +2253,18 @@
Change choicebook
page to match display
- # change bookcontrol page to page associated with display
- if self.page :
- pgnum = self.layerbook.GetPageIndex(self.page)
- if pgnum > -1:
- self.layerbook.SetSelection(pgnum)
+ if self.georect:
+ if event.GetActive():
+ self.gwiz.SwitchEnv('new')
+ else:
+ self.gwiz.SwitchEnv('original')
+ else:
+ # change bookcontrol page to page associated with display
+ if self.page :
+ pgnum = self.layerbook.GetPageIndex(self.page)
+ if pgnum > -1:
+ self.layerbook.SetSelection(pgnum)
event.Skip()
def OnMotion(self, event):
@@ -2304,6 +2319,8 @@
self.MapWindow.mouse['box'] = 'point'
else: # moveLine, deleteLine
self.MapWindow.mouse['box'] = 'box'
+ elif self.grtoolbar:
+ self.MapWindow.SetCursor(self.cursors["cross"])
else:
self.MapWindow.SetCursor(self.cursors["default"])
