[GRASS-SVN] r29927 - grass/trunk/vector/v.extract
svn_grass at osgeo.org
Sat Feb 2 08:33:41 EST 2008
Author: martinl
Date: 2008-02-02 08:33:41 -0500 (Sat, 02 Feb 2008)
New Revision: 29927
grass/trunk/vector/v.extract/description.html
v.extract: manual page updated
Modified: grass/trunk/vector/v.extract/description.html
--- grass/trunk/vector/v.extract/description.html 2008-02-02 12:26:52 UTC (rev 29926)
+++ grass/trunk/vector/v.extract/description.html 2008-02-02 13:33:41 UTC (rev 29927)
@@ -7,6 +7,11 @@
Dissolving (optional) is based on the output categories. If 2 adjacent
areas have the same output category, the boundary is removed.
+<p>
+If <b>list</b>, <b>file</b> and <b>where</b> options are not
+specified, all features of given type and layer are
+extracted. Categories are not changed in that case.
<h2>NOTES</h2>
Only features with a category number will be extracted. So if you want to
@@ -34,7 +39,7 @@
produces a new vector map <b>soil_groupa</b> containing the areas from vector
<b>soils</b> which have categories <b>1 thru 4</b>. Any common boundaries are
dissolved, all areas in the new map will retain their original category
-numbers 1 thru 4, since <em>new</em> was set to -1.
+numbers 1 thru 4, since <b>new</b> was set to -1.
<h3>Extract all areas and assign the same category to all:</h3>
<div class="code"><pre>
@@ -108,15 +113,17 @@
<h2>SEE ALSO</h2>
-<em><a HREF="v.category.html">v.category</a></em>,
-<em><a HREF="v.dissolve.html">v.dissolve</a></em>,
-<em><a HREF="v.reclass.html">v.reclass</a></em>,
-<em><a HREF="sql.html">GRASS SQL interface</a></em>
+<em>
+<a HREF="v.category.html">v.category</a>,
+<a HREF="v.dissolve.html">v.dissolve</a>,
+<a HREF="v.reclass.html">v.reclass</a>,
+<a HREF="sql.html">GRASS SQL interface</a>
+</em>
<h2>AUTHORS</h2>
R.L. Glenn, USDA, SCS, NHQ-CGIS<br>
GRASS 6 port by Radim Blazek
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
