[GRASS-SVN] r29929 - grass/trunk/vector/v.edit/cmd
svn_grass at osgeo.org
Sat Feb 2 12:09:11 EST 2008
Author: martinl
Date: 2008-02-02 12:09:11 -0500 (Sat, 02 Feb 2008)
New Revision: 29929
grass/trunk/vector/v.edit/cmd/args.c
grass/trunk/vector/v.edit/cmd/description.html
v.edit: manual page updated
Modified: grass/trunk/vector/v.edit/cmd/args.c
--- grass/trunk/vector/v.edit/cmd/args.c 2008-02-02 16:49:32 UTC (rev 29928)
+++ grass/trunk/vector/v.edit/cmd/args.c 2008-02-02 17:09:11 UTC (rev 29929)
@@ -171,7 +171,7 @@
params -> bmaps = G_define_standard_option(G_OPT_V_MAPS);
params -> bmaps -> key = "bgmap";
params -> bmaps -> required = NO;
- params -> bmaps -> description = _("Name of background vector map(s) snap to");
+ params -> bmaps -> description = _("Name of background vector map(s)");
params -> snap = G_define_option();
params -> snap -> key = "snap";
Modified: grass/trunk/vector/v.edit/cmd/description.html
--- grass/trunk/vector/v.edit/cmd/description.html 2008-02-02 16:49:32 UTC (rev 29928)
+++ grass/trunk/vector/v.edit/cmd/description.html 2008-02-02 17:09:11 UTC (rev 29929)
@@ -1,9 +1,7 @@
<h2>DESCRIPTION</h2>
-<p>
The module <em>v.edit</em> allows the user to edit a vector map
via command line interface.
-</p>
<p>
<em>v.edit</em> supports only "simple" vector features: points,
@@ -13,7 +11,6 @@
<p>
Provides editing features' geometry. Attribute data connected to the
vector map are not modified at all.
-</p>
<p>
Vector features can be selected either by internal <b>id</b>,
@@ -24,7 +21,6 @@
changed using threshold distance <b>thresh</b>. The options
are <em>orthogonal</em>, i.e. can be used in various combinations. For
example:
-</p>
<div class="code"><pre>
v.edit map=roads tool=select \
@@ -38,18 +34,15 @@
label='interstate'.
<h2>NOTES</h2>
-<p>
If no vector features are selected or the flag <b>-t</b> is
used, topology is not build at the end.
-</p>
<h2>USAGE</h2>
<h3>Feature selection</h3>
-<p>
Vector features can be selected in several ways:
-</p>
<ul>
<li><b>ids</b> - using internal (unique) feature id's</li>
<li><b>cats</b> - using category numbers</li>
@@ -57,13 +50,11 @@
box, size defined by <b>thresh</b>)</li>
<li><b>bbox</b> - using bounding box</li>
<li><b>polygon</b> - using polygon (at least 3 coordinate pairs have to be set)</li>
- <li><b>where</b> - using 'where' statement (attribute data)
+ <li><b>where</b> - using where statement (attribute data)
<li><b>query</b> - special query (e.g. minimal vector line length)
</ul>
-<p>
Additional parameters for vector feature specification are:
-</p>
<ul>
<li><b>layer</b> - layer number (currently used only
with <b>cats</b> or <b>where</b> option)</li>
@@ -75,7 +66,7 @@
<ul>
<li><b>create</b> - Create new (empty) vector map
- (see <a href="v.in.ascii.html">v.in.ascii</a>). Optionally vector
+ (see <em><a href="v.in.ascii.html">v.in.ascii</a></em>). Optionally vector
features (in GRASS ASCII standard format) can be read from
standard input (<b>input=-</b>) or from the text file given by
the <b>input</b> option.</li>
@@ -114,15 +105,17 @@
boundaries. The geometry of the merged vector lines can be
changed. If the second line from two selected lines is in opposite
direction to the first, it will be flipped. See also
- module <a href="v.build.polylines.html">v.build.polylines</a>.</li>
+ module <em><a href="v.build.polylines.html">v.build.polylines</a></em>.</li>
<li><b>break</b> - Split given vector line or boundary into two
lines on location given by <b>coords</b>. If <b>coords</b> not
given, breaks all selected lines at each intersection (based
- on <a href="v.clean.html">v.clean</a>, tool=break).</li>
+ on <em><a href="v.clean.html">v.clean</a></em>, tool=break).</li>
<li><b>snap</b> - Snap vector features in given threshold. See
- also module <a href="v.clean.html">v.clean</a>.</li>
+ also module <em><a href="v.clean.html">v.clean</a></em>. Note that this
+ tool supports only snapping to nodes. Parameters <b>snap</b> and
+ <b>bgmap</b> are ignored.</li>
<li><b>connect</b> - Connect selected lines or boundaries, the
first given line is connected to the second one. The second line
@@ -159,75 +152,69 @@
<h2>EXAMPLES</h2>
<h3>Create new vector map</h3>
-<p>
Create new (empty) vector map:
-</p>
v.edit tool=create map=vectmap
</pre></div>
-<p>
Create new vector map and read data from file 'roads.txt':
-</p>
v.out.ascii in=roads format=standard > roads.txt;
v.edit tool=create map=vectmap input=roads.txt
</pre></div>
or alternatively
cat roads.txt | v.edit tool=create map=vectmap input=-
</pre></div>
<h3>Add new features to existing vector map</h3>
-<p>
Add point to the vector map (without header):
-</p>
echo "P 1 1
640794 214874
1 1" | v.edit -n tool=add map=vectmap
</pre></div>
-<p>
Add new features read from standard input:
-</p>
v.out.ascii in=railroads format=standard | v.edit tool=add map=vectmap
</pre></div>
<h3>Delete selected features from vector map layer</h3>
-<p>
Remove all vector features with category number 1 or 2:
-</p>
v.edit tool=delete map=roads cats=1,2
</pre></div>
-<p>
Remove all vector features except of those with category number 1 or 2
(reverse selection):
-</p>
v.edit -r tool=delete map=roads cats=1,2
</pre></div>
-<p>
Remove features with category 1 or 2 located on coordinates
600952.625,4926107 (bounding box based on the current 2D resolution):
-</p>
g.region -d;
v.edit tool=delete map=roads cats=1,2 coords=600952.625,4926107
</pre></div>
-<p>
Remove all features with category 1 and 2 covered by two bounding boxes
(center coordinates 592542.892,4924766.996 and 603389.062,4918292.187,
size 2000 map units):
-</p>
v.edit map=roads tool=delete \
coord=592542.892,4924766.996,603389.062,4918292.187 \
@@ -244,30 +231,24 @@
<h3>Move features</h3>
-<p>
Move feature (vector point) located on coordinates 602580,4918480 to
coordinates 603580,4919480:
-</p>
v.edit tool=move map=archsites coord=602580,4918480 th=1e-2 move=1000,1000
</pre></div>
-<p>
Move all features with category 1 1000 map units to the west and 1000
map units to the south. Moved features snap to nodes in threshold
distance 10 map units:
-</p>
v.edit tool=move map=roads cat=1 move=1000,-1000 snap=node thresh=10
</pre></div>
-<p>
Move all features defined by bounding box
601530,4921560,602520,4922310 (W,S,E,N) 1000 map units to the
east and 1000 map units to the north:
-</p>
v.edit tool=move map=roads bbox=601530,4921560,602520,4922310 move=-1000,1000
@@ -275,9 +256,7 @@
<h3>Flip direction of vector lines</h3>
-<p>
Flip direction of all vector lines:
-</p>
v.edit tool=flip map=streams cats=1-9999 type=line
@@ -294,6 +273,7 @@
</pre></div>
Delete layer/category 1/1, line id 1:
v.edit tool=catdel map=roads id=1 cats=5
</pre></div>
@@ -376,16 +356,14 @@
<h3>Select features and print their id's</h3>
-<p>
Print id's of selected features, e.g.:
-</p>
v.edit map=soils at PERMANENT tool=select \
bbox=595733.8125,4919781.75,598536.1875,4917396.75 --q
</pre></div>
-Example with <em>d.vect</em>:
+Example with <em><a href="d.vect.html">d.vect</a></em>:
d.erase;
@@ -441,7 +419,8 @@
<h2>AUTHOR</h2>
Original author: Wolf Bergenheim - independent developer<br>
-Various updates: Jachym Cepicky, Mendel University of Agriculture and Forestry in Brno, Czech Republic,<br>
+Various updates: Jachym Cepicky, Mendel University of Agriculture and Forestry in Brno, Czech Republic<br>
Martin Landa, FBK-irst (formerly ITC-irst), Trento, Italy
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
