[GRASS-SVN] r29931 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Feb 2 12:23:52 EST 2008
Author: martinl
Date: 2008-02-02 12:23:52 -0500 (Sat, 02 Feb 2008)
New Revision: 29931
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxDialog: 'close on run' checkbox added. Layout cosmetics. Docs string doxygenized.
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-02-02 17:18:31 UTC (rev 29930)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-02-02 17:23:52 UTC (rev 29931)
@@ -1,5 +1,5 @@
#! /usr/bin/python
-""" Construct simple wx.Python GUI from a GRASS command interface description.
+"""Construct simple wx.Python GUI from a GRASS command interface description.
Classes:
* testSAXContentHandler
@@ -11,39 +11,38 @@
* GrassGUIApp
* GUI
-# Copyright (C) 2000-2007 by the GRASS Development Team
-# Author: Jan-Oliver Wagner <jan at intevation.de>
-# Improved by: Bernhard Reiter <bernhard at intevation.de>
-# Improved by: Michael Barton, Arizona State University
-# Improved by: Daniel Calvelo <dca.gis at gmail.com>
-# Improved by: Martin Landa <landa.martin at gmail.com>
-# This program is free software under the GPL (>=v2)
-# Read the file COPYING coming with GRASS for details.
+ Copyright (C) 2000-2007 by the GRASS Development Team
-# This program is just a coarse approach to
-# automatically build a GUI from a xml-based
-# GRASS user interface description.
-# You need to have Python 2.4, wxPython 2.8 and python-xml.
-# The XML stream is read from executing the command given in the
-# command line, thus you may call it for instance this way:
-# python <this file.py> r.basins.fill
-# Or you set an alias or wrap the call up in a nice
-# shell script, GUI environment ... please contribute your idea.
-# Updated to wxPython 2.8 syntax and contrib widgets.
-# Methods added to make it callable by gui.
-# Method added to automatically re-run with pythonw on a Mac.
-# TODO:
-# - verify option value types
-# - add tooltips
-# - use DOM instead of SAX
+ This program is free software under the GPL (>=v2)
+ Read the file COPYING coming with GRASS for details.
+ This program is just a coarse approach to
+ automatically build a GUI from a xml-based
+ GRASS user interface description.
+ You need to have Python 2.4, wxPython 2.8 and python-xml.
+ The XML stream is read from executing the command given in the
+ command line, thus you may call it for instance this way:
+ python <this file.py> r.basins.fill
+ Or you set an alias or wrap the call up in a nice
+ shell script, GUI environment ... please contribute your idea.
+ Updated to wxPython 2.8 syntax and contrib widgets.
+ Methods added to make it callable by gui.
+ Method added to automatically re-run with pythonw on a Mac.
+ at author Jan-Oliver Wagner <jan at intevation.de>
+Bernhard Reiter <bernhard at intevation.de>
+Michael Barton, Arizona State University
+Daniel Calvelo <dca.gis at gmail.com>
+Martin Landa <landa.martin at gmail.com>
+ at todo
+ - verify option value types
+ - use DOM instead of SAX
__version__ ="$Revision$"
@@ -591,7 +590,7 @@
type=wx.BITMAP_TYPE_PNG))
topsizer.Add (item=self.logo, proportion=0, border=3,
flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL)
- guisizer.Add (item=topsizer, proportion=0, flag=wx.ALIGN_BOTTOM | wx.EXPAND)
+ guisizer.Add (item=topsizer, proportion=0, flag=wx.EXPAND)
# notebooks
self.notebookpanel = cmdPanel (parent=self, task=self.task, standalone=self.standalone)
@@ -655,6 +654,15 @@
guisizer.Add(item=btnsizer, proportion=0, flag=wx.ALIGN_CENTER)
+ if self.get_dcmd is None:
+ # close dialog on run?
+ self.closebox = wx.CheckBox(parent=self,
+ label=_('Close dialog on run'), style = wx.NO_BORDER)
+ self.closebox.SetValue(True)
+ guisizer.Add(item=self.closebox, proportion=0,
+ flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
+ border=5)
self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
constrained_size = self.notebookpanel.GetSize()
@@ -720,7 +728,12 @@
# change page if needed
if self.notebookpanel.notebook.GetSelection() != self.notebookpanel.outpageid:
self.notebookpanel.notebook.SetSelection(self.notebookpanel.outpageid)
+ # close dialog?
+ if self.closebox.IsChecked():
+ self.Close()
def OnCopy(self, event):
"""Copy the command"""
cmddata = wx.TextDataObject()
@@ -856,7 +869,8 @@
chk.SetValue( f['value'] )
chk.SetFont(wx.Font(pointSize=fontsize, family=wx.FONTFAMILY_DEFAULT,
style=wx.NORMAL, weight=text_style))
- which_sizer.Add( item=chk, proportion=0, flag=wx.EXPAND | wx.TOP | wx.LEFT, border=5)
+ which_sizer.Add( item=chk, proportion=0,
+ flag=wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border=5)
f['wxId'] = chk.GetId()
chk.Bind(wx.EVT_CHECKBOX, self.OnSetValue)
if f['name'] in ('verbose', 'quiet'):
@@ -910,17 +924,20 @@
for val in valuelist:
chkbox = wx.CheckBox( parent=which_panel, label = text_beautify(val) )
p[ 'wxId' ].append( chkbox.GetId() )
- if isDefault.has_key(val): chkbox.SetValue( True )
- hSizer.Add( item=chkbox, proportion=0, flag=wx.ADJUST_MINSIZE | wx.ALL, border=1 )
+ if isDefault.has_key(val):
+ chkbox.SetValue( True )
+ hSizer.Add( item=chkbox, proportion=0,
+ flag=wx.ADJUST_MINSIZE | wx.ALL, border=1 )
chkbox.Bind(wx.EVT_CHECKBOX, self.OnCheckBoxMulti)
- which_sizer.Add( item=hSizer, proportion=0, flag=wx.ADJUST_MINSIZE | wx.ALL, border=5 )
+ which_sizer.Add( item=hSizer, proportion=0,
+ flag=wx.EXPAND | wx.TOP | wx.RIGHT | wx.LEFT, border=5 )
else:
if len(valuelist) == 1: # -> textctrl
txt = wx.StaticText(parent=which_panel,
label = _('%s. Valid range=%s') % \
(title, str(valuelist).strip("[]'") + ':' ) )
which_sizer.Add(item=txt, proportion=0,
- flag=wx.ADJUST_MINSIZE | wx.TOP | wx.LEFT, border=5)
+ flag=wx.ADJUST_MINSIZE | wx.TOP | wx.RIGHT | wx.LEFT, border=5)
if p.get('type','') == 'integer' and \
p.get('multiple','no') == 'no':
@@ -930,7 +947,7 @@
except ValueError:
minValue = -1e6
maxValue = 1e6
- txt2 = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY, size=(50, -1),
+ txt2 = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY, size=(300, -1),
min=minValue, max=maxValue)
else:
txt2 = wx.TextCtrl(parent=which_panel, value = p.get('default',''),
@@ -946,7 +963,7 @@
# list of values (combo)
txt = wx.StaticText(parent=which_panel, label = title + ':' )
cb = wx.ComboBox(parent=which_panel, id=wx.ID_ANY, value=p.get('default',''),
size=wx.Size(STRING_ENTRY_WIDTH, -1),
choices=valuelist, style=wx.CB_DROPDOWN)
@@ -964,7 +981,8 @@
and p.get('prompt','') != 'color'):
- which_sizer.Add(item=txt, proportion=0, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=5)
+ which_sizer.Add(item=txt, proportion=0,
+ flag=wx.RIGHT | wx.LEFT | wx.TOP | wx.EXPAND, border=5)
txt3 = wx.TextCtrl(parent=which_panel, value = p.get('default',''),
size = (STRING_ENTRY_WIDTH, ENTRY_HEIGHT))
@@ -979,7 +997,7 @@
if p.get('type','string') == 'string' and p.get('gisprompt',False) == True:
txt = wx.StaticText(parent=which_panel, label = title + ':')
+ flag=wx.ADJUST_MINSIZE | wx.RIGHT | wx.LEFT | wx.TOP, border=5)
# element selection tree combobox (maps, icons, regions, etc.)
if p.get('prompt','') != 'color' and p.get('element', '') != 'file':
selection = gselect.Select(parent=which_panel, id=wx.ID_ANY, size=(300,-1),
@@ -987,7 +1005,8 @@
if p.get('value','') != '':
selection.SetValue(p['value']) # parameter previously set
- which_sizer.Add(item=selection, proportion=0, flag=wx.ADJUST_MINSIZE| wx.BOTTOM | wx.LEFT, border=5)
+ which_sizer.Add(item=selection, proportion=0,
+ flag=wx.ADJUST_MINSIZE| wx.BOTTOM | wx.LEFT, border=5)
# A select.Select is a combobox with two children: a textctl and a popupwindow;
# we target the textctl here
p['wxId'] = selection.GetChildren()[0].GetId()
@@ -1009,7 +1028,8 @@
btn_colour = csel.ColourSelect(parent=which_panel, id=wx.ID_ANY,
label=label_color, colour=default_color,
pos=wx.DefaultPosition, size=(150,-1) )
- this_sizer.Add(item=btn_colour, proportion=0, flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
+ this_sizer.Add(item=btn_colour, proportion=0,
+ flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
# For color selectors, this is a two-member array, holding the IDs of
# the selector proper and either a "transparent" button or None
p['wxId'] = [btn_colour.GetId(),]
@@ -1021,7 +1041,8 @@
else:
none_check.SetValue(False)
none_check.SetFont( wx.Font( fontsize, wx.FONTFAMILY_DEFAULT, wx.NORMAL, text_style, 0, ''))
- this_sizer.Add(none_check, 0, wx.ADJUST_MINSIZE| wx.ALL, 5)
+ this_sizer.Add(item=none_check, proportion=0,
+ flag=wx.ADJUST_MINSIZE | wx.LEFT | wx.RIGHT | wx.TOP, border=5)
which_sizer.Add( this_sizer )
none_check.Bind(wx.EVT_CHECKBOX, self.OnColorChange)
p['wxId'].append( none_check.GetId() )
@@ -1039,7 +1060,7 @@
fbb.SetValue(p['value']) # parameter previously set
which_sizer.Add(item=fbb, proportion=0,
- flag=wx.ADJUST_MINSIZE | wx.LEFT | wx.TOP, border=-3)
+ flag=wx.ADJUST_MINSIZE | wx.LEFT | wx.TOP | wx.RIGHT, border=-3)
# A file browse button is a combobox with two children:
# a textctl and a button;
# we have to target the button here
