[GRASS-SVN] r29937 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Feb 3 02:45:59 EST 2008
Author: cmbarton
Date: 2008-02-03 02:45:59 -0500 (Sun, 03 Feb 2008)
New Revision: 29937
grass/trunk/gui/wxpython/gui_modules/georect.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
georectify (GCP) window and regular (map display) window now get GCPs marked with black crosses. Both also can access method in georect.
Modified: grass/trunk/gui/wxpython/gui_modules/georect.py
--- grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-03 07:41:50 UTC (rev 29936)
+++ grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-03 07:45:59 UTC (rev 29937)
@@ -162,8 +162,10 @@
pass
else:
wx.MessageBox("Georectifying setup canceled.")
+ self.Cleanup()
else:
+ self.Cleanup()
# start display showing xymap - need to put an if statement here
if success != False:
@@ -181,18 +183,19 @@
self.Map.AddLayer(type=rendertype, command=cmdlist,l_active=True,
l_hidden=False, l_opacity=1, l_render=False)
self.xy_mapdisp = mapdisp.MapFrame(self.parent, title="Set ground control points (GCPs)",
pos=wx.DefaultPosition, size=(640,480),
style=wx.DEFAULT_FRAME_STYLE, toolbars=["georect"],
- Map=self.Map, gwiz=self, gismgr=self.parent, georect=True)
+ Map=self.Map, gismgr=self.parent, georect=True)
self.mapwin = self.xy_mapdisp.MapWindow
# set mouse characteristics
self.mapwin.mouse['box'] = 'point'
+ self.mapwin.mouse["use"] == "pointer"
self.mapwin.zoomtype = 0
- self.mapwin.pen = wx.Pen(colour='black', width=2, style=wx.SOLID)
+ self.mapwin.pen = wx.Pen(colour='black', width=2, style=wx.SOLID)
self.mapwin.SetCursor(self.xy_mapdisp.cursors["cross"])
# draw selected xy map
@@ -208,8 +211,11 @@
self.gcpmgr.Show()
self.gcpmgr.Refresh()
self.gcpmgr.Update()
- self.Cleanup()
+ else:
+ self.Cleanup()
+ def PrintCoord(self, coord, coordtype):
+ print coord,coordtype
def SetSrcEnv(self, location, mapset):
"""Create environment to use for location and mapset
@@ -249,11 +255,13 @@
#print 'maptype=',maptype
return True
+ self.Cleanup()
def Cleanup(self):
# return to current location and mapset
self.SwitchEnv('original')
- self.parent.georect = False
+ self.parent.georectifying = False
+ self.xy_mapdisp.Destroy()
self.wizard.Destroy()
class LocationPage(TitledPage):
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-02-03 07:41:50 UTC (rev 29936)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-02-03 07:45:59 UTC (rev 29937)
@@ -858,6 +858,7 @@
elif event.Moving():
self.OnMouseMoving(event)
+ event.Skip()
def OnLeftDown(self, event):
@@ -1122,8 +1123,14 @@
self.DrawLines(pdc=self.pdcTmp)
except:
pass
- elif self.mouse["use"] == "pointer" and self.gismanager.georectifying:
+ elif self.mouse["use"] == "pointer" and self.parent.gismanager.georectifying:
self.SetCursor(self.parent.cursors["cross"])
+ coord = self.Pixel2Cell(self.mouse['end'])
+ if self.parent.georect:
+ coordtype = 'gcp'
+ else:
+ coordtype = 'mapcoord'
+ self.gismanager.gr.PrintCoord(coord, coordtype)
self.DrawCross(pdc=self.pdcTmp, coords=self.mouse['end'],
size=5)
@@ -2030,7 +2037,7 @@
pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],
tree=None, notebook=None, gismgr=None, page=None,
- Map=None, auimgr=None, gwiz=None, georect=False):
+ Map=None, auimgr=None, georect=False):
Main map display window with toolbars, statusbar and
DrawWindow
@@ -2049,7 +2056,6 @@
gismgr -- GIS Manager panel
page -- notebook page with layer tree
Map -- instance of render.Map
- gwiz -- ID of GeorectWizard
georect -- is window used by georectifier
@@ -2057,13 +2063,12 @@
wx.Frame.__init__(self, parent, id, title, pos, size, style)
- self.gismanager = gismgr # GIS Manager object
- self.Map = Map # instance of render.Map
- self.tree = tree # GIS Manager layer tree object
- self.page = page # Notebook page holding the layer tree
- self.layerbook = notebook # GIS Manager layer tree notebook
- self.georect = georect # Map display used for setting GCPs for georectifier
- self.gwiz = gwiz # Georectifier object
+ self.gismanager = gismgr # GIS Manager object
+ self.Map = Map # instance of render.Map
+ self.tree = tree # GIS Manager layer tree object
+ self.page = page # Notebook page holding the layer tree
+ self.layerbook = notebook # GIS Manager layer tree notebook
+ self.georect = georect # Map display used for setting GCPs for georectifier
self.parent = parent
@@ -2281,15 +2286,24 @@
def OnFocus(self, event):
- Change choicebook
- page to match display
+ Change choicebook page to match display.
+ Or set display for georectifying
if self.georect:
- if event.GetActive():
- self.gwiz.SwitchEnv('new')
- else:
- self.gwiz.SwitchEnv('original')
+ # display used to set GCPs in map to georectify
+ try:
+ if event.GetActive():
+ self.gismanager.gr.SwitchEnv('new')
+ else:
+ self.gismanager.gr.SwitchEnv('original')
+ except:
+ pass
+ elif self.gismanager.georectifying:
+ # in georectifying session; display used to get get geographic
+ # coordinates for GCPs
+ self.MapWindow.pen = wx.Pen(colour='black', width=2, style=wx.SOLID)
+ self.MapWindow.SetCursor(self.cursors["cross"])
else:
# change bookcontrol page to page associated with display
if self.page :
