[GRASS-SVN] r29977 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Feb 6 08:08:48 EST 2008
Author: martinl
Date: 2008-02-06 08:08:47 -0500 (Wed, 06 Feb 2008)
New Revision: 29977
grass/trunk/gui/wxpython/gui_modules/dbm.py
wxGUI: fix error when digitizing new feature (submit attribute data), #30
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-02-06 10:20:01 UTC (rev 29976)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-02-06 13:08:47 UTC (rev 29977)
@@ -2774,14 +2774,19 @@
except:
newvalue = self.FindWindowById(id).GetLabel()
+ if newvalue == '':
+ newvalue = None
if newvalue != value:
updatedColumns.append(name)
- if type != 'character':
- updatedValues.append(newvalue)
+ if newvalue is None:
+ updatedValues.append('NULL')
else:
- updatedValues.append("'" + newvalue + "'")
- if updateValues:
- columns[name]['values'][idx] = newvalue
+ if type != 'character':
+ updatedValues.append(newvalue)
+ else:
+ updatedValues.append("'" + newvalue + "'")
+ columns[name]['values'][idx] = newvalue
if self.action != "add" and len(updatedValues) == 0:
continue
@@ -2888,15 +2893,16 @@
# continue # nothing selected ...
if self.action == "add":
- if nselected <= 0 and cats.has_key(layer):
- table = self.mapDBInfo.layers[layer]["table"]
- columns = self.mapDBInfo.tables[table]
- for name in columns.keys():
- if name == "cat":
- for cat in cats[layer]:
- self.mapDBInfo.tables[table][name]['values'].append(cat)
- else:
- self.mapDBInfo.tables[table][name]['values'].append('')
+ if nselected <= 0:
+ if cats.has_key(layer):
+ table = self.mapDBInfo.layers[layer]["table"]
+ columns = self.mapDBInfo.tables[table]
+ for name in columns.keys():
+ if name == "cat":
+ for cat in cats[layer]:
+ self.mapDBInfo.tables[table][name]['values'].append(cat)
+ else:
+ self.mapDBInfo.tables[table][name]['values'].append(None)
else: # change status 'add' -> 'update'
self.action = "update"
@@ -2932,7 +2938,10 @@
# columns
vtype = columns[name]['type']
- value = str(columns[name]['values'][idx])
+ if columns[name]['values'][idx] is not None:
+ value = str(columns[name]['values'][idx])
+ else:
+ value = ''
if name.lower() == "cat":
box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
@@ -3129,7 +3138,10 @@
for line in selectCommand.ReadStdOutput():
name, value = line.split('|')
# casting ...
- value = self.tables[table][name]['ctype'] (value)
+ if value:
+ value = self.tables[table][name]['ctype'] (value)
+ else:
+ value = None
self.tables[table][name]['values'].append(value)
nselected = 1
