[GRASS-SVN] r29988 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Feb 6 19:18:52 EST 2008
Author: cmbarton
Date: 2008-02-06 19:18:52 -0500 (Wed, 06 Feb 2008)
New Revision: 29988
grass/trunk/gui/wxpython/gui_modules/georect.py
Can now read and save a points file. Editor for GPCs. Automatic setting of target.
Modified: grass/trunk/gui/wxpython/gui_modules/georect.py
--- grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-06 23:29:18 UTC (rev 29987)
+++ grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-07 00:18:52 UTC (rev 29988)
@@ -37,7 +37,7 @@
import wx
import wx.aui
import wx.lib.filebrowsebutton as filebrowse
-from wx.lib.mixins.listctrl import CheckListCtrlMixin, ListCtrlAutoWidthMixin
+from wx.lib.mixins.listctrl import CheckListCtrlMixin, ListCtrlAutoWidthMixin, TextEditMixin
import wx.wizard as wiz
import wx.grid as gridlib
@@ -135,6 +135,10 @@
self.gisrc_dict[line.split(':')[0]] = line.split(':')[1].strip()
finally:
f.close()
+ self.currentlocation = self.gisrc_dict['LOCATION_NAME']
+ self.currentmapset = self.gisrc_dict['MAPSET']
self.new_gisrc = '' #GISRC file for source location/mapset of map(s) to georectify
# define wizard pages
@@ -168,7 +172,7 @@
wx.MessageBox("Georectifying setup canceled.")
self.Cleanup()
- # start display showing xymap - need to put an if statement here
+ # start display showing xymap
if success != False:
self.Map = render.Map() # instance of render.Map to be associated with display
@@ -214,11 +218,7 @@
self.gcpmgr.Update()
else:
self.Cleanup()
- def PrintCoord(self, coordtype, coord):
- print coord,coordtype
- self.gcpmgr.SetGCPData(coordtype, coord)
def SetSrcEnv(self, location, mapset):
"""Create environment to use for location and mapset
that are the source of the file(s) to georectify"""
@@ -239,22 +239,7 @@
elif grc == 'new':
os.environ["GISRC"] = str(self.new_gisrc)
def onWizFinished(self):
- global grassdatabase
- global xy_group
- global xy_map
- global maptype
- #print 'Current global variables'
- #print 'curr_location=',curr_location
- #print 'curr_mapset=',curr_mapset
- #print 'xy_location=',xy_location
- #print 'xy_mapset=',xy_mapset
- #print 'xy_group=',xy_group
- #print 'xy_map=',xy_map
- #print 'maptype=',maptype
return True
self.Cleanup()
@@ -388,6 +373,7 @@
self.grassdatabase = self.parent.grassdatabase
self.xylocation = ''
self.xymapset = ''
+ self.xygroup = ''
box = wx.BoxSizer(wx.HORIZONTAL)
label = wx.StaticText(self, -1, 'select group:',
@@ -417,17 +403,23 @@
def OnGroup(self, event):
global xy_group
- xy_group = event.GetString()
+ self.xygroup = event.GetString()
def OnMkGroup(self, event):
+ global maptype
self.parent.SwitchEnv('new')
- cmdlist = ['i.group']
- menuform.GUI().ParseCommand(cmdlist, parentframe=self.parent.parent)
+ if maptype == 'cell':
+ cmdlist = ['i.group']
+ menuform.GUI().ParseCommand(cmdlist, parentframe=self.parent.parent)
+ elif maptype == 'vector':
+ pass
+ # need a custom vector group creator
def onPageChanging(self,event=None):
global xy_group
- if event.GetDirection() and xy_group == '':
+ if event.GetDirection() and self.xygroup == '':
wx.MessageBox('You must select a valid image/map group in order to continue')
event.Veto()
return
@@ -442,7 +434,7 @@
# create a list of groups in selected mapset
tmplist = os.listdir(os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group'))
if tmplist == []:
wx.MessageBox('No map/imagery groups exist to georectify. You will need to create one')
else:
@@ -514,7 +506,21 @@
toolbar = self.__createToolBar()
+ self.parent = parent
self.grwiz = grwiz
+ self.grassdatabase = self.grwiz.grassdatabase
+ self.currentlocation = self.grwiz.currentlocation
+ self.currentmapset = self.grwiz.currentmapset
+ self.xylocation = self.grwiz.gisrc_dict['LOCATION_NAME']
+ self.xymapset = self.grwiz.gisrc_dict['MAPSET']
+ self.xygroup = self.grwiz.grouppage.xygroup
+ self.pointsfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'POINTS')
+ self.rgrpfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'REF')
+ self.vgrpfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'VREF')
+ self.targetfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'TARGET')
+ self.SetTarget(self.xygroup, self.currentlocation, self.currentmapset)
self.selected = 0 #gcp list item selected
self.mapcoordlist = [(0000000.00,0000000.00,'')] #list map coords and ID of map display they came from
@@ -530,30 +536,35 @@
self.sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
# initialize list control for GCP management
- self.list = CheckListCtrl(p)
- self.sizer.Add(self.list, 1, wx.GROW|wx.ALL, 5)
+ self.list = CheckListCtrl(p, -1, style=wx.LC_REPORT | wx.SUNKEN_BORDER | wx.LC_HRULES)
self.list.InsertColumn(0, 'use| X coord', width=120)
self.list.InsertColumn(1, 'Y coord')
self.list.InsertColumn(2, 'N coord')
self.list.InsertColumn(3, 'E coord')
self.list.InsertColumn(4, 'Forward error')
self.list.InsertColumn(5, 'Backward error')
- i = ('0000000.00','0000000.00','0000000.00','0000000.00','0000.00','0000.00')
- index = self.list.InsertStringItem(sys.maxint, i[0])
- self.list.SetStringItem(index, 1, i[1])
- self.list.SetStringItem(index, 2, i[2])
- self.list.SetStringItem(index, 3, i[3])
- self.list.SetStringItem(index, 4, i[4])
- self.list.SetStringItem(index, 5, i[5])
- self.list.CheckItem(0, True)
+ if os.path.isfile(self.pointsfile):
+ self.ReadGCPs()
+ self.ResizeColumns()
+ else:
+ # initialize a blank line in the GCP list
+ i = ('0000000.00','0000000.00','0000000.00','0000000.00','0000.00','0000.00')
+ index = self.list.InsertStringItem(sys.maxint, i[0])
+ self.list.SetStringItem(index, 1, i[1])
+ self.list.SetStringItem(index, 2, i[2])
+ self.list.SetStringItem(index, 3, i[3])
+ self.list.SetStringItem(index, 4, i[4])
+ self.list.SetStringItem(index, 5, i[5])
+ self.list.CheckItem(0, True)
+ self.sizer.Add(self.list, 1, wx.EXPAND|wx.ALL, 5)
p.SetSizer(self.sizer)
self.Bind(wx.EVT_RADIOBOX, self.OnGRMethod, self.rb_grmethod)
self.list.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
+ self.list.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
def __createToolBar(self):
"""Creates toolbar"""
@@ -562,7 +573,20 @@
for each in self.toolbarData():
self.addToolbarButton(toolbar, *each)
toolbar.Realize()
+ def ResizeColumns(self):
+ for i in range(6):
+ self.list.SetColumnWidth(i, wx.LIST_AUTOSIZE)
+ def SetTarget(self, tgroup, tlocation, tmapset):
+ sets rectification target to current location and mapset
+ self.grwiz.SwitchEnv('new')
+ cmdlist = ['i.target', 'group=%s' % tgroup, 'location=%s' % tlocation, 'mapset=%s' % tmapset]
+ gcmd.Command(cmd=cmdlist)
def addToolbarButton(self, toolbar, label, icon, help, handler):
"""Adds button to the given toolbar"""
@@ -586,20 +610,57 @@
def SaveGCPs(self, event):
+ make a POINTS file or save GCP coordinates to existing POINTS file
+ f = open(self.pointsfile, mode='w')
+ try:
+ f.write('# Ground Control Points File\n')
+ f.write("# \n")
+ f.write("# target location: "+self.currentlocation+'\n')
+ f.write("# target mapset: "+self.currentmapset+'\n')
+ f.write("#unrectified xy georectified east north 1=use gcp point\n")
+ f.write("#-------------- ----------------------- ---------------\n")
+ for index in range(self.list.GetItemCount()):
+ if self.list.IsChecked(index) == True:
+ check = "1"
+ else:
+ check = "0"
+ coord0 = self.list.GetItem(index, 0).GetText()
+ coord1 = self.list.GetItem(index, 1).GetText()
+ coord2 = self.list.GetItem(index, 2).GetText()
+ coord3 = self.list.GetItem(index, 3).GetText()
+ f.write(coord0+' '+coord1+' '+coord2+' '+coord3+' '+check+'\n')
+ finally:
+ f.close()
pass
def DeleteGCP(self, event):
+ deletes selected line in GCP list
self.list.DeleteItem(self.selected)
del self.mapcoordlist[self.selected]
def AddGCP(self, event):
+ appends a line to GCP list
self.list.Append(['0000000.00','0000000.00','0000000.00','0000000.00','0000.00','0000.00'])
index = self.list.GetItemCount() - 1
self.mapcoordlist.append((0000000.00,0000000.00,''))
self.list.CheckItem(index, True)
self.list.SetItemState(index, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
+ return index
- def SetGCPData(self, coordtype, coord, mapdisp):
+ def SetGCPData(self, coordtype, coord, mapdisp=None, check=True):
+ inserts coordinates into line in GCP list
index = self.selected
coord0 = str(coord[0])
coord1 = str(coord[1])
@@ -613,30 +674,82 @@
self.mapcoordlist[index] = (coord[0], coord[1], mapdisp)
if coordtype == 'rms':
self.list.SetStringItem(index, 4, coord0)
- self.list.SetStringItem(index, 5, coord1)
+ self.list.SetStringItem(index, 5, coord1)
+ self.list.CheckItem(index, check)
def ClearGCP(self, event):
+ sets all values in selected GCP line to 0
for i in range(6):
self.list.SetStringItem(index, i, '0000000.00')
self.mapcoordlist[index] = (0000000.00,0000000.00,'')
+ def ReadGCPs(self):
+ reads GCPs and georectified coordinates from POINTS file
+ f = open(self.pointsfile)
+ try:
+ for line in f:
+ if line[0] != '#':
+ line = line.strip('/n')
+ coords = line.split()
+ if coords[4] == '1':
+ check = True
+ else:
+ check = False
+ index = self.AddGCP(event=None)
+ for i in range(4):
+ self.list.SetStringItem(index, i, coords[i])
+ finally:
+ f.close()
+ self.list.RefreshItems(0, self.list.GetItemCount()-1)
def OnRMS(self, event):
+ calculates RMS error
pass
def OnGeorect(self, event):
+ georectifies map using i.rectify or v.transform
pass
def OnQuit(self, event):
self.Destroy()
- self.parent.Cleanup()
+ self.grwiz.Cleanup()
- def OnGRMethod(self, event):
- pass
def OnItemSelected(self, event):
self.selected = event.GetIndex()
+ def OnItemActivated(self, event):
+ when item double clicked, open editor for coordinate values; update values
+ coords = []
+ index = event.m_itemIndex
+ coords.append(self.list.GetItem(index, i).GetText())
+ dlg = EditGPC(self, -1, data=coords)
+ if dlg.ShowModal() == wx.ID_OK:
+ values = dlg.GetValues() # string
+ if values[i] != coords[i]:
+ self.list.SetStringItem(index, i, values[i])
def RefreshGCPMarks(self, event):
Update GCP and map coord maps and redraw
@@ -657,7 +770,6 @@
(self.list.GetItem(index, 2).GetText() != '0000000.00' and
self.list.GetItem(index, 3).GetText() != '0000000.00')
- print 'checked? ',index,self.list.IsChecked(index)
coord0 = float(self.list.GetItem(index, 0).GetText())
coord1 = float(self.list.GetItem(index, 1).GetText())
coord2 = float(self.list.GetItem(index, 2).GetText())
@@ -671,21 +783,103 @@
pxcoord2 = self.mapcoordlist[index][2].Cell2Pixel((coord2, coord3))
self.mapcoordlist[index][2].DrawCross(pdc=self.mapcoordlist[index][2].pdcTmp,
coords=pxcoord2, size=5)
+ def OnGRMethod(self, event):
+ sets transformation type for georectifying
+ pass
class CheckListCtrl(wx.ListCtrl, CheckListCtrlMixin, ListCtrlAutoWidthMixin):
- def __init__(self, parent):
- wx.ListCtrl.__init__(self, parent, -1, style=wx.LC_REPORT | wx.SUNKEN_BORDER)
+ def __init__(self, parent, ID=-1, pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=0):
+ wx.ListCtrl.__init__(self, parent, -ID, pos, size, style)
CheckListCtrlMixin.__init__(self)
ListCtrlAutoWidthMixin.__init__(self)
self.CheckList = [] # tracks whether list items are checked or not
- self.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
+ #self.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
- def OnItemActivated(self, event):
- self.ToggleItem(event.m_itemIndex)
# this is called by the base class when an item is checked/unchecked
def OnCheckItem(self, index, flag):
pass
+class EditGPC(wx.Dialog):
+ """Dialog for editing GPC line in list control"""
+ def __init__(self, parent, id, data,
+ style=wx.DEFAULT_DIALOG_STYLE):
+ dialog for editing GCP and map coordinates
+ wx.Dialog.__init__(self, parent, id, style=style)
+ self.btnCancel = wx.Button(self, wx.ID_CANCEL)
+ self.btnSubmit = wx.Button(self, wx.ID_OK)
+ self.btnSubmit.SetDefault()
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ # data area
+ #gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
+ #gridSizer.AddGrowableCol(4)
+ box = wx.BoxSizer(wx.HORIZONTAL)
+ xlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label='X:')
+ box.Add(xlabel, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT, border=5)
+ self.xcoord = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+ value=data[0], size=(150, -1))
+ box.Add(self.xcoord, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT| wx.LEFT, border=5)
+ ylabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label='Y:')
+ box.Add(ylabel, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
+ self.ycoord = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+ value=data[1], size=(150, -1))
+ box.Add(self.ycoord, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT| wx.LEFT | wx.RIGHT, border=5)
+ sizer.Add(box, flag=wx.ALL, border=3)
+ elabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label='E:')
+ box.Add(elabel, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
+ self.ecoord = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+ value=data[2], size=(150, -1))
+ box.Add(self.ecoord, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT| wx.LEFT, border=5)
+ nlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label='N:')
+ box.Add(nlabel, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
+ self.ncoord = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+ value=data[3], size=(150, -1))
+ box.Add(self.ncoord, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT| wx.LEFT | wx.RIGHT, border=5)
+ # buttons
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(self.btnCancel)
+ btnSizer.AddButton(self.btnSubmit)
+ btnSizer.Realize()
+ #sizer.Add(item=gridSizer, proportion=1,
+ # flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ sizer.Add(item=btnSizer, proportion=0,
+ flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ self.Layout()
+ def GetValues(self, columns=None):
+ """Return list of values (as string).
+ valuelist = []
+ valuelist.append(self.xcoord.GetValue())
+ valuelist.append(self.ycoord.GetValue())
+ valuelist.append(self.ecoord.GetValue())
+ valuelist.append(self.ncoord.GetValue())
+ return valuelist
