[GRASS-SVN] r29990 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Feb 7 00:28:45 EST 2008
Author: cmbarton
Date: 2008-02-07 00:28:44 -0500 (Thu, 07 Feb 2008)
New Revision: 29990
grass/trunk/gui/wxpython/gui_modules/georect.py
grass/trunk/gui/wxpython/gui_modules/menudata.py
Georectifier now works for wxgui. Still need to implement RMS error calculation.
Modified: grass/trunk/gui/wxpython/gui_modules/georect.py
--- grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-07 05:05:32 UTC (rev 29989)
+++ grass/trunk/gui/wxpython/gui_modules/georect.py 2008-02-07 05:28:44 UTC (rev 29990)
@@ -43,13 +43,6 @@
from threading import Thread
-try:
- import subprocess
-except:
- CompatPath = os.path.join( os.getenv("GISBASE"),"etc","wx")
- sys.path.append(CompatPath)
- from compat import subprocess
gmpath = os.path.join( os.getenv("GISBASE"),"etc","wx","gui_modules" )
sys.path.append(gmpath)
gmpath = os.path.join( os.getenv("GISBASE"),"etc","wx","icons" )
@@ -131,8 +124,9 @@
self.gisrc_dict = {}
try:
for line in f:
- line = line.strip('/n')
- self.gisrc_dict[line.split(':')[0]] = line.split(':')[1].strip()
+ if line != '':
+ line = line.strip(' \n')
+ self.gisrc_dict[line.split(':')[0]] = line.split(':')[1].strip()
finally:
f.close()
@@ -157,7 +151,8 @@
self.wizard.FitToPage(self.startpage)
-# self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+ #self.Bind(wx.EVT_CLOSE, self.Cleanup)
+ self.parent.Bind(wx.EVT_ACTIVATE, self.OnGLMFocus)
success = False
@@ -242,6 +237,10 @@
def onWizFinished(self):
return True
self.Cleanup()
+ def OnGLMFocus(self, event):
+ #self.SwitchEnv('original')
+ pass
def Cleanup(self):
# return to current location and mapset
@@ -374,7 +373,9 @@
self.xylocation = ''
self.xymapset = ''
self.xygroup = ''
+ self.extension = 'georect'+str(os.getpid())
box = wx.BoxSizer(wx.HORIZONTAL)
label = wx.StaticText(self, -1, 'select group:',
style=wx.ALIGN_RIGHT)
@@ -390,12 +391,21 @@
label = wx.StaticText(self, -1, 'Create group if none exists', style=wx.ALIGN_LEFT)
box.Add(label, 0, wx.ALIGN_LEFT|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
- self.btn_mkgroup = wx.Button(self, wx.ID_ANY, "Make group ...")
+ self.btn_mkgroup = wx.Button(self, wx.ID_ANY, "Create/edit group ...")
box.Add(self.btn_mkgroup, 0, wx.ALIGN_LEFT|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
self.sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
+ box = wx.BoxSizer(wx.HORIZONTAL)
+ label = wx.StaticText(self, -1, 'Extension for output maps:', style=wx.ALIGN_LEFT)
+ box.Add(label, 0, wx.ALIGN_LEFT|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
+ self.ext_txt = wx.wx.TextCtrl(self, -1, "", size=(150,-1))
+ self.ext_txt.SetValue(self.extension)
+ box.Add(self.ext_txt, 0, wx.ALIGN_LEFT|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
+ self.sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
self.Bind(wx.EVT_COMBOBOX, self.OnGroup, self.cb_group)
self.Bind(wx.EVT_BUTTON, self.OnMkGroup, self.btn_mkgroup)
+ self.Bind(wx.EVT_TEXT, self.OnExtension, self.ext_txt)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.onPageChanging)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnPageChanged)
self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
@@ -413,8 +423,12 @@
cmdlist = ['i.group']
menuform.GUI().ParseCommand(cmdlist, parentframe=self.parent.parent)
elif maptype == 'vector':
- pass
- # need a custom vector group creator
+ dlg = VectGroup(self, wx.ID_ANY, self.grassdatabase, self.xylocation, self.xymapset, self.xygroup)
+ if dlg.ShowModal() == wx.ID_OK:
+ dlg.MakeVGroup()
+ def OnExtension(self, event):
+ self.extension = event.GetString()
def onPageChanging(self,event=None):
global xy_group
@@ -424,8 +438,12 @@
event.Veto()
return
+ if event.GetDirection() and self.extension == '':
+ wx.MessageBox('You must enter an map name extension in order to continue')
+ event.Veto()
+ return
def OnPageChanged(self,event=None):
self.groupList = []
tmplist = []
self.xylocation = self.parent.gisrc_dict['LOCATION_NAME']
@@ -514,6 +532,7 @@
self.xylocation = self.grwiz.gisrc_dict['LOCATION_NAME']
self.xymapset = self.grwiz.gisrc_dict['MAPSET']
self.xygroup = self.grwiz.grouppage.xygroup
+ self.extension = self.grwiz.grouppage.extension
self.pointsfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'POINTS')
self.rgrpfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'REF')
self.vgrpfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'VREF')
@@ -521,6 +540,7 @@
self.SetTarget(self.xygroup, self.currentlocation, self.currentmapset)
+ self.gr_order = 1 #polynomial order transformation for georectification
self.selected = 0 #gcp list item selected
self.mapcoordlist = [(0000000.00,0000000.00,'')] #list map coords and ID of map display they came from
@@ -547,8 +567,8 @@
if os.path.isfile(self.pointsfile):
self.ReadGCPs()
self.ResizeColumns()
- else:
- # initialize a blank line in the GCP list
+ elif self.list.self.list.GetItemCount() == 0:
+ # initialize 3 blank lines in the GCP list (minimum for georectification)
i = ('0000000.00','0000000.00','0000000.00','0000000.00','0000.00','0000.00')
index = self.list.InsertStringItem(sys.maxint, i[0])
self.list.SetStringItem(index, 1, i[1])
@@ -557,6 +577,8 @@
self.list.SetStringItem(index, 4, i[4])
self.list.SetStringItem(index, 5, i[5])
self.list.CheckItem(0, True)
+ self.AddGCP(None)
+ self.AddGCP(None)
self.sizer.Add(self.list, 1, wx.EXPAND|wx.ALL, 5)
@@ -565,6 +587,8 @@
self.Bind(wx.EVT_RADIOBOX, self.OnGRMethod, self.rb_grmethod)
self.list.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
self.list.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnItemActivated)
+ self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
+ self.Bind(wx.EVT_CLOSE, self.grwiz.Cleanup)
def __createToolBar(self):
"""Creates toolbar"""
@@ -574,6 +598,9 @@
self.addToolbarButton(toolbar, *each)
toolbar.Realize()
+ def OnFocus(self, event):
+ self.grwiz.SwitchEnv('new')
def ResizeColumns(self):
for i in range(6):
self.list.SetColumnWidth(i, wx.LIST_AUTOSIZE)
@@ -654,6 +681,7 @@
self.mapcoordlist.append((0000000.00,0000000.00,''))
self.list.CheckItem(index, True)
self.list.SetItemState(index, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
+ self.ResizeColumns()
return index
def SetGCPData(self, coordtype, coord, mapdisp=None, check=True):
@@ -696,8 +724,8 @@
f = open(self.pointsfile)
try:
for line in f:
- if line[0] != '#':
+ if line[0] != '#' and line !='':
coords = line.split()
if coords[4] == '1':
check = True
@@ -707,11 +735,10 @@
for i in range(4):
self.list.SetStringItem(index, i, coords[i])
self.list.CheckItem(index, check)
+ self.RefreshGCPMarks(None)
finally:
f.close()
- self.list.RefreshItems(0, self.list.GetItemCount()-1)
def OnRMS(self, event):
calculates RMS error
@@ -722,8 +749,53 @@
georectifies map using i.rectify or v.transform
+ global maptype
- pass
+ cmd_stdout = ''
+ cmd_stderr = ''
+ if maptype == 'cell':
+ cmdlist = ['i.rectify', '-ca', 'group=%s' % self.xygroup, 'extension=%s' % self.extension, 'order=%s' % self.gr_order]
+ p = gcmd.Command(cmd=cmdlist, stdout=cmd_stdout, stderr=cmd_stderr)
+ if p.returncode == 0:
+ wx.MessageBox("All maps were georectified successfully")
+ else:
+ wx.MessageBox(cmd_stderr+'\n'+cmd_stdout)
+ elif maptype == 'vector':
+ # loop through all vectors in VREF and move resulting vector to target location
+ f = open(self.vgrpfile)
+ vectlist = []
+ try:
+ for vect in f:
+ vect = vect.strip(' \n')
+ vectlist.append(vect)
+ finally:
+ f.close()
+ for vect in vectlist:
+ outname = vect+'_'+self.extension
+ cmdlist = ['v.transform', '--q', 'input=%s' % vect, 'output=%s' % outname, 'pointsfile=%s' % self.pointsfile]
+ #p = subprocess.Popen(cmdlist, stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
+ #cmd_stdout = p.stdout.read()
+ #cmd_stderr = p.stderr.read()
+ xyvpath = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'vector',outname)
+ vpath = os.path.join(self.grassdatabase,self.currentlocation,self.currentmapset,'vector',outname)
+ if os.path.isfile(vpath):
+ wx.MessageBox("%s already exists. Change extension name and georectify again" % outname)
+ else:
+ shutil.move(xyvpath, vpath)
+ else:
+ wx.MessageBox('For vector files with attribute tables, you will need to manually copy the tables to the new location')
+ else:
+ return
def OnQuit(self, event):
self.Destroy()
@@ -779,16 +851,17 @@
pxcoord1 = self.grwiz.mapwin.Cell2Pixel((coord0, coord1))
self.grwiz.mapwin.DrawCross(pdc=self.grwiz.mapwin.pdcTmp,
coords=pxcoord1, size=5)
- self.grwiz.SwitchEnv("original")
- pxcoord2 = self.mapcoordlist[index][2].Cell2Pixel((coord2, coord3))
- self.mapcoordlist[index][2].DrawCross(pdc=self.mapcoordlist[index][2].pdcTmp,
+ if self.mapcoordlist != [] and self.mapcoordlist[index][2] != '':
+ self.grwiz.SwitchEnv("original")
+ pxcoord2 = self.mapcoordlist[index][2].Cell2Pixel((coord2, coord3))
+ self.mapcoordlist[index][2].DrawCross(pdc=self.mapcoordlist[index][2].pdcTmp,
coords=pxcoord2, size=5)
def OnGRMethod(self, event):
sets transformation type for georectifying
- pass
+ self.gr_order = event.GetInt() + 1
class CheckListCtrl(wx.ListCtrl, CheckListCtrlMixin, ListCtrlAutoWidthMixin):
@@ -805,15 +878,105 @@
def OnCheckItem(self, index, flag):
pass
+class VectGroup(wx.Dialog):
+ dialog to create a vector group (VREF file) for georectifying
+ def __init__(self, parent, id, grassdb, location, mapset, group,
+ style=wx.DEFAULT_DIALOG_STYLE):
+ wx.Dialog.__init__(self, parent, id, style=style)
+ self.grassdatabase = grassdb
+ self.xylocation = location
+ self.xymapset = mapset
+ self.xygroup = group
+ # get list of valid vector directories
+ vectlist = os.listdir(os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'vector'))
+ for dir in vectlist:
+ if os.path.isfile(os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'vector',dir,'coor')):
+ pass
+ else:
+ vectlist.remove(dir)
+ self.vgrouplist = []
+ self.vgrpfile = os.path.join(self.grassdatabase,self.xylocation,self.xymapset,'group',self.xygroup,'VREF')
+ if os.path.isfile(self.vgrpfile):
+ try:
+ for line in f:
+ if line != '':
+ self.vgrouplist.append(line.strip(' \n'))
+ finally:
+ f.close()
+ self.btnCancel = wx.Button(self, wx.ID_CANCEL)
+ self.btnSubmit = wx.Button(self, wx.ID_OK)
+ self.btnSubmit.SetDefault()
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ label = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label='Select vector map(s) to add to group:')
+ box.Add(label, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT, border=5)
+ self.addmap = wx.CheckListBox(self, -1, wx.DefaultPosition, wx.DefaultSize, vectlist)
+ box.Add(self.addmap, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
+ sizer.Add(box, flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
+ label='Select vector map(s) to remove from group:')
+ self.remmap = wx.CheckListBox(self, -1, wx.DefaultPosition, wx.DefaultSize, self.vgrouplist)
+ box.Add(self.remmap, flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT| wx.LEFT, border=5)
+ # buttons
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(self.btnCancel)
+ btnSizer.AddButton(self.btnSubmit)
+ btnSizer.Realize()
+ sizer.Add(item=btnSizer, proportion=0,
+ flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ self.Layout()
+ self.Bind(wx.EVT_CHECKLISTBOX, self.AddVect, self.addmap)
+ self.Bind(wx.EVT_CHECKLISTBOX, self.RemoveVect, self.remmap)
+ def AddVect(self, event):
+ index = event.GetSelection()
+ label = self.addmap.GetString(index)
+ if self.addmap.IsChecked(index):
+ self.vgrouplist.append(label)
+ self.addmap.SetSelection(index) # so that (un)checking also selects (moves the highlight)
+ event.Skip()
+ def RemoveVect(self, event):
+ label = self.remmap.GetString(index)
+ if self.remmap.IsChecked(index):
+ self.vgrouplist.remove(label)
+ self.remmap.SetSelection(index) # so that (un)checking also selects (moves the highlight)
+ event.Skip()
+ def MakeVGroup(self):
+ f = open(self.vgrpfile, mode='w')
+ for vect in self.vgrouplist:
+ f.write(vect+'\n')
class EditGPC(wx.Dialog):
- """Dialog for editing GPC line in list control"""
+ """Dialog for editing GPC and map coordinates in list control"""
def __init__(self, parent, id, data,
- dialog for editing GCP and map coordinates
@@ -821,10 +984,6 @@
- # data area
- #gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
- #gridSizer.AddGrowableCol(4)
xlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
@@ -862,9 +1021,6 @@
btnSizer.Realize()
- #sizer.Add(item=gridSizer, proportion=1,
- # flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-02-07 05:05:32 UTC (rev 29989)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-02-07 05:28:44 UTC (rev 29990)
@@ -131,7 +131,7 @@
("Volume to raster series", "Convert raster to vector map", "self.OnMenuCmd", "r3.to.rast"),
- ("Georectify (not functional)", "Georectify raster and vector maps", "self.OnGeorectify", ""),
+ ("Georectify", "Georectify raster and vector maps", "self.OnGeorectify", ""),
("NViz (requires TclTk)", "N-Dimensional visualization of maps and volumes", "self.OnMenuCmd", "nviz"),
