[GRASS-SVN] r30035 - grass/trunk/visualization/nviz/scripts
Sat Feb 9 13:26:01 EST 2008
Author: cmbarton
Date: 2008-02-09 13:26:01 -0500 (Sat, 09 Feb 2008)
New Revision: 30035
   grass/trunk/visualization/nviz/scripts/flythrough.tcl
   grass/trunk/visualization/nviz/scripts/nviz2.2_script
   grass/trunk/visualization/nviz/scripts/panel_main.tcl
Further fix of fly-though and application of Maris Nartiss' patch
Modified: grass/trunk/visualization/nviz/scripts/flythrough.tcl
--- grass/trunk/visualization/nviz/scripts/flythrough.tcl	2008-02-09 17:59:40 UTC (rev 30034)
+++ grass/trunk/visualization/nviz/scripts/flythrough.tcl	2008-02-09 18:26:01 UTC (rev 30035)
@@ -50,7 +50,7 @@
 proc mkFlyButtons {BASE frame draw_lab draw_var1 draw_var2} {
-	global fly
+	global Nv_ fly draw_option
 	# Flythrough menus
 	set fly(EYE_RADIOBUTTON) $draw_var1
@@ -58,7 +58,7 @@
 	set fly(FLY_RADIOBUTTON) [radiobutton $BASE.$frame.b3 \
                  -variable draw_option -value 3 -text "fly"\
-				 -command "fly_change_mode 0" ]
+				 -command "set Nv_(FlyThrough) 1; fly_change_mode 0" ]
     set fly(FLY_MENUBUTTON) $BASE.$frame.flymenu
Modified: grass/trunk/visualization/nviz/scripts/nviz2.2_script
--- grass/trunk/visualization/nviz/scripts/nviz2.2_script	2008-02-09 17:59:40 UTC (rev 30034)
+++ grass/trunk/visualization/nviz/scripts/nviz2.2_script	2008-02-09 18:26:01 UTC (rev 30035)
@@ -720,15 +720,22 @@
 proc load_3dview { dummy } {
-	global Nv_
+	global XY Nv_ draw_option Nauto_draw
 	# Ask the user for a file name to load from
 	set file_name [create_map_browser .browse_3dview_file "3d.view" 1]
 	if {$file_name == -1} then return
+        appBusy
+        # Do not redraw automaticly display while loading state...
+        set oNauto_draw $Nauto_draw
+        set Nauto_draw 0
+        #do a quick draw to make sure display initialized
+        Nquick_draw
+        Nload_3dview $file_name
 	Nquick_draw
 	#Reset position GUI
@@ -736,10 +743,15 @@
 	#reset height
 	Nv_setEntry $Nv_(main_BASE).midf.height.f.entry	 $ht
 	Nv_floatscaleCallback $Nv_(main_BASE).midf.height e 2 null $ht
-	change_display 2
-	change_display 1
+	#change_display 2
+	#change_display 1
+        if { $draw_option == 1 } { change_display 0 } \
+        elseif { $draw_option == 0 } { change_display 1 }
 	Nquick_draw
+        appNotBusy
+        set Nauto_draw $oNauto_draw
 # Procedure to manually set canvas size
Modified: grass/trunk/visualization/nviz/scripts/panel_main.tcl
--- grass/trunk/visualization/nviz/scripts/panel_main.tcl	2008-02-09 17:59:40 UTC (rev 30034)
+++ grass/trunk/visualization/nviz/scripts/panel_main.tcl	2008-02-09 18:26:01 UTC (rev 30035)
@@ -174,11 +174,11 @@
 	set draw_var1 [radiobutton $BASE.midt.b1 -text "eye" \
 		-variable draw_option -value 0 -width 8 \
-		-command "set Nv_(FlyThrough) 0; change_display 1" ]
+		-command "change_display 1" ]
 	set draw_var2 [radiobutton $BASE.midt.b2 -text "center" \
 		-variable draw_option -value 1 -width 8 \
-		-command "set Nv_(FlyThrough) 0; change_display 0" ]
+		-command "change_display 0" ]
 	$draw_var1 select
 	help $BASE.midt.b1 balloon "Change view by moving eye position"
@@ -191,7 +191,7 @@
 		# original code
 		pack $draw_lab $draw_var1 $draw_var2 -side left -expand 0
-	help $BASE.midt.b3 balloon "Change view interactively in display"
+	help $BASE.midt.b3 balloon "Change view using mouse to control fly-through"
 	# make	position "widget"
 	set XY [Nv_mkXYScale $BASE.midf.pos puck XY_POS 125 125 105 105 update_eye_position]
@@ -414,6 +414,7 @@
 	return $W.zexag
 proc mk_hgt_slider {W} {
 	global Nv_
@@ -507,22 +508,17 @@
 	set h [lindex [Nget_real_position 1] 2]
 	set min [lindex [Nget_height] 1]
 	set max [lindex [Nget_height] 2]
+	set Nv_(FlyThrough) 0
 	if {$flag == 1} {
 		#draw eye position
 		inform "Set eye position"
 		set XY [Nv_mkXYScale $NAME puck XY_POS 125 125 105 105 update_eye_position]
-		update_height $h
-		reset_res
-		move_position
 	} elseif {$flag == 0} {
 		#draw center position
 		inform "Set center of view position"
 		set XY [Nv_mkXYScale $NAME cross XY_POS 125 125 109 109 update_center_position]
-		update_height $h
-		reset_res
-		move_position
 	if {$Nv_(FlyThrough) == 0} {
@@ -530,6 +526,10 @@
 	} else {
 		pack $XY -side left -before $Nv_(HEIGHT_SLIDER)
+	update_height $h
+	reset_res
+	move_position
 	if {$Nauto_draw == 1} {Ndraw_all}
