[GRASS-SVN] r30046 - grass/trunk/scripts/r.in.srtm
svn_grass at osgeo.org
Sat Feb 9 22:30:45 EST 2008
Author: hamish
Date: 2008-02-09 22:30:45 -0500 (Sat, 09 Feb 2008)
New Revision: 30046
grass/trunk/scripts/r.in.srtm/r.in.srtm
remove 'file' test, replace with 'unzip -t'. Bug #39
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm
--- grass/trunk/scripts/r.in.srtm/r.in.srtm 2008-02-10 01:14:11 UTC (rev 30045)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm 2008-02-10 03:30:45 UTC (rev 30046)
@@ -128,13 +128,17 @@
if [ -f "$FILE.hgt.zip" ] ; then
#### check if we have unzip
- if [ ! -x "`which unzip`" ] || [ ! -x "`which file`" ] ; then
- g.message -e "\"unzip\" and \"file\" are required, please install them first"
+ if [ ! -x "`which unzip`" ] ; then
+ g.message -e "The \"unzip\" program is required, please install it first"
exit 1
fi
# really a ZIP file?
- if [ "`file -ib "$FILE.hgt.zip"`" != "application/x-zip" ] ; then
+ # make it quiet in a safe way (just in case -qq isn't portable)
+ UNZIP=-qq
+ export UNZIP
+ unzip -t "$FILE.hgt.zip"
+ if [ $? -ne 0 ] ; then
g.message -e "'$FILE.hgt.zip' does not appear to be a valid zip file."
exit 1
fi
