[GRASS-SVN] r30049 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Feb 10 02:57:28 EST 2008
Author: cmbarton
Date: 2008-02-10 02:57:28 -0500 (Sun, 10 Feb 2008)
New Revision: 30049
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
Modified gselect and menuform to allow for multiple map or other GIS element entry when 'multiple = yes' in interface-description. Note: maintaining '@mapset' is crashing wxPython. This may be in g.parser, as it doesn't seem to be in menuform.
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-02-10 07:41:58 UTC (rev 30048)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-02-10 07:57:28 UTC (rev 30049)
@@ -31,8 +31,8 @@
pos=wx.DefaultPosition, size=(-1,-1), type='cell',
style=wx.DEFAULT_DIALOG_STYLE|wx.RESIZE_BORDER):
- A dialog box for the GIS element selector control so that it can be launched f
- rom a button or other control.
+ A dialog box for the GIS element selector control so that it can be launched
+ from a button or other control.
wx.Dialog.__init__(self, parent, id, title, pos, size, style)
@@ -41,10 +41,8 @@
sizer = wx.BoxSizer(wx.VERTICAL)
- box = wx.BoxSizer(wx.HORIZONTAL)
self.selection = Select(self, id=wx.ID_ANY, size=(300,-1),type=type)
- box.Add(self.selection, 0, wx.ALIGN_CENTER|wx.ALL, 5)
- sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
+ sizer.Add(self.selection, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
line = wx.StaticLine(self, -1, size=(20,-1), style=wx.LI_HORIZONTAL)
sizer.Add(line, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.RIGHT|wx.TOP, 5)
@@ -63,6 +61,11 @@
self.SetSizer(sizer)
sizer.Fit(self)
+ self.Layout()
+ def ElementName(self):
+ element = self.selection.GetValue()
+ return element
class Select(wx.combo.ComboCtrl):
def __init__(self, parent, id, size, type):
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-02-10 07:41:58 UTC (rev 30048)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-02-10 07:57:28 UTC (rev 30049)
@@ -55,6 +55,7 @@
import wx.lib.flatnotebook as FN
import wx.lib.colourselect as csel
import wx.lib.filebrowsebutton as filebrowse
+from wx.lib.expando import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
import wx.html
# Do the python 2.0 standard xml thing and map it on the old names
@@ -823,6 +824,8 @@
self.notebook = FN.FlatNotebook( self, id=wx.ID_ANY, style=nbStyle)
self.notebook.SetTabAreaColour(globalvar.FNPageColor)
self.notebook.Bind( FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChange )
+ self.selecttxt = '' # special text control to receive multiple GIS element selections
+ self.element = '' # GIS element to select in multi-selection control
tab = {}
tabsizer = {}
for section in sections:
@@ -1000,17 +1003,34 @@
flag=wx.ADJUST_MINSIZE | wx.RIGHT | wx.LEFT | wx.TOP, border=5)
# element selection tree combobox (maps, icons, regions, etc.)
if p.get('prompt','') != 'color' and p.get('element', '') != 'file':
- selection = gselect.Select(parent=which_panel, id=wx.ID_ANY, size=(300,-1),
- type=p.get('element','') )
- if p.get('value','') != '':
- selection.SetValue(p['value']) # parameter previously set
+ self.element = ''
+ if p.get('multiple','no') == 'no':
+ selection = gselect.Select(parent=which_panel, id=wx.ID_ANY, size=(300,-1),
+ type=p.get('element','') )
+ if p.get('value','') != '':
+ selection.SetValue(p['value']) # parameter previously set
- which_sizer.Add(item=selection, proportion=0,
- flag=wx.ADJUST_MINSIZE| wx.BOTTOM | wx.LEFT, border=5)
- # A select.Select is a combobox with two children: a textctl and a popupwindow;
- # we target the textctl here
- p['wxId'] = selection.GetChildren()[0].GetId()
- selection.Bind(wx.EVT_TEXT, self.OnSetValue)
+ which_sizer.Add(item=selection, proportion=0,
+ flag=wx.ADJUST_MINSIZE| wx.BOTTOM | wx.LEFT, border=5)
+ # A select.Select is a combobox with two children: a textctl and a popupwindow;
+ # we target the textctl here
+ p['wxId'] = selection.GetChildren()[0].GetId()
+ selection.Bind(wx.EVT_TEXT, self.OnSetValue)
+ else:
+ btn4 = wx.Button(parent=which_panel, id=wx.ID_ANY, label='Select...')
+ self.element = p.get('element','')
+ self.selecttxt = ExpandoTextCtrl(parent=which_panel, id=wx.ID_ANY, value = p.get('default',''),
+ size = (300, -1))
+ self.selecttxt.SetValue(p['value']) # parameter previously set
+ box = wx.BoxSizer(wx.HORIZONTAL)
+ box.Add(item=btn4, proportion=0, flag=wx.LEFT, border=2)
+ box.Add(item=self.selecttxt, proportion=0, flag=wx.LEFT | wx.RIGHT, border=5)
+ which_sizer.Add(item=box, proportion=0, flag=wx.BOTTOM | wx.LEFT, border=5)
+ p['wxId'] = self.selecttxt.GetId()
+ btn4.Bind(wx.EVT_BUTTON, self.OnSelectButton)
+ self.selecttxt.Bind(EVT_ETC_LAYOUT_NEEDED, self.OnRefit)
+ self.selecttxt.Bind(wx.EVT_TEXT, self.OnSetValue)
# color entry
elif p.get('prompt','') == 'color':
# Heuristic way of finding whether transparent is allowed
@@ -1080,8 +1100,6 @@
if tooltip:
txt.SetToolTipString(tooltip)
maxsizes = (0,0)
tabsizer[section].SetSizeHints( tab[section] )
@@ -1190,8 +1208,8 @@
porf[ 'value' ] = me.GetValue()
self.OnUpdateValues()
+ event.Skip()
def createCmd( self, ignoreErrors = False ):
Produce a command line string (list) or feeding into GRASS.
@@ -1209,7 +1227,38 @@
cmd = None
return cmd
+ def OnRefit(self, event):
+ # The Expando control will redo the layout of the
+ # sizer it belongs to, but sometimes this may not be
+ # enough, so it will send us this event so we can do any
+ # other layout adjustments needed. In this case we'll
+ # just resize the frame to fit the new needs of the sizer.
+ print 'in on refit'
+ self.Fit()
+ if event != None:
+ event.Skip()
+ def OnSelectButton(self, event):
+ Calls map selection control as a dialog instead of a comboBox so that
+ multiple maps can be selected.
+ # Get any values already set in map txtctrl.
+ elements = self.selecttxt.GetValue()
+ name = ''
+ dlg = gselect.SelectDialog(self, type=self.element)
+ dlg.CenterOnParent(wx.BOTH)
+ if dlg.ShowModal() == wx.ID_OK:
+ name = dlg.ElementName()
+ name = name.split('@')[0]
+ if elements == '':
+ elements = name
+ else:
+ elements = '%s,%s' % (elements, name)
+ self.selecttxt.SetValue(elements)
def getInterfaceDescription( cmd ):
