[GRASS-SVN] r30071 - in grass/trunk/gui/wxpython: . gui_modules
icons
svn_grass at osgeo.org
Sun Feb 10 17:03:58 EST 2008
Author: martinl
Date: 2008-02-10 17:03:58 -0500 (Sun, 10 Feb 2008)
New Revision: 30071
grass/trunk/gui/wxpython/README
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/icons/icon.py
wxGUI: Preferences dialog improved, settings can be stored to the file.
Modified: grass/trunk/gui/wxpython/README
--- grass/trunk/gui/wxpython/README 2008-02-10 20:21:54 UTC (rev 30070)
+++ grass/trunk/gui/wxpython/README 2008-02-10 22:03:58 UTC (rev 30071)
@@ -133,18 +133,13 @@
6 - ICON THEMES
-Currently only two icon themes are available:
- * default (based on TCL/TK GUI prototype)
- * Silk
+Currently two icon themes are available:
+ * original GRASS (based on TCL/TK GUI prototype)
+ * Silk-based
-To enable 'Silk' icon theme set GRASS variable:
+User can change icon theme in Preferences dialog
+('Config->Preferences').
-$ g.gisenv set=GRASS_ICONPATH=$GISBASE/etc/wx/icons/silk
-To re-enable default icons (TCL/TK theme)
7 - DIGITIZATION TOOL
To enable digitization tool you need to compile display driver located
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-02-10 20:21:54 UTC (rev 30070)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-02-10 22:03:58 UTC (rev 30071)
@@ -49,14 +49,15 @@
class GException(Exception):
"""Generic exception"""
- def __init__(self, message):
+ def __init__(self, message, parent=None):
self.message = message
+ self.parent = parent
def __str__(self):
- wx.MessageBox(parent=None,
+ wx.MessageBox(parent=self.parent,
caption=_("Error"),
message=self.message,
- style=wx.ICON_ERROR)
+ style=wx.ICON_ERROR | wx.CENTRE)
return ''
@@ -69,13 +70,27 @@
GException.__init__(message)
def __str__(self):
caption=_("Error in command execution"),
- return ''
+ return ''
+class SettingsError(GException):
+ """Exception used for GRASS settings, see
+ gui_modules/preferences.py."""
+ def __init(self, message):
+ GException.__init__(message)
+ def __str__(self):
+ caption=_("Preferences error"),
+ message=self.message,
+ return ''
class DigitError(GException):
"""Exception raised during digitization session"""
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-02-10 20:21:54 UTC (rev 30070)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-02-10 22:03:58 UTC (rev 30071)
@@ -30,20 +30,116 @@
sys.path.append(gmpath)
import gcmd
+import grassenv
class Settings:
"""Generic class where to store settings"""
def __init__(self):
+ # filename for settings
+ self.fileName = ".grasswx"
+ # default settings
self.defaultSettings = {
# general
'displayFont' : '',
# advanced
- 'settingsFile' : 'home', # home, location, mapset
+ 'settingsFile' : 'gisdbase', # gisdbase, location, mapset
'digitInterface' : 'vdigit', # vedit, vdigit
+ 'iconTheme': 'silk', # grass, silk
+ # user settings
self.userSettings = copy.deepcopy(self.defaultSettings)
+ try:
+ self.ReadSettingsFile()
+ except IOError, e:
+ raise gcmd.SettingsError(e)
+ except:
+ gcmd.SettingsError('Reading settings failed.')
+ def ReadSettingsFile(self, settings=None):
+ """Reads settings file (mapset, location, gisdbase)"""
+ if settings is None:
+ settings = self.userSettings
+ # look for settings file
+ # -> mapser
+ # -> location
+ # -> gisdbase
+ gisdbase = grassenv.GetGRASSVariable("GISDBASE")
+ location_name = grassenv.GetGRASSVariable("LOCATION_NAME")
+ mapset_name = grassenv.GetGRASSVariable("MAPSET")
+ mapset_file = os.path.join(gisdbase, location_name, mapset_name, self.fileName)
+ location_file = os.path.join(gisdbase, location_name, self.fileName)
+ gisdbase_file = os.path.join(gisdbase, self.fileName)
+ if os.path.isfile(mapset_file):
+ self.__ReadFile(mapset_file)
+ elif os.path.isfile(location_file):
+ self.__ReadFile(location_file)
+ elif os.path.isfile(gisdbase_file):
+ self.__ReadFile(gisdbase_file)
+ def __ReadFile(self, filename, settings=None):
+ """Read settings from file to dict"""
+ try:
+ file = open(filename, "r")
+ for line in file.readlines():
+ try:
+ key, value = line.rstrip('%s' % os.linesep).split(':', 1)
+ except:
+ raise SettingsError('Reading settings from file <%s> failed. '
+ 'Line \'%s\'.' % (filename, line))
+ if settings.has_key(key):
+ settings[key] = value
+ else:
+ 'Unknow item <%s>.' % (filename, key))
+ except:
+ raise gcmd.SettingsError('Reading settings from file <%s> failed.' % filename)
+ file.close()
+ def SaveToFile(self, settings=None):
+ """Save settings to the file"""
+ loc = self.Get('settingsFile')
+ filePath = None
+ if loc == 'gisdbase':
+ filePath = os.path.join(gisdbase, self.fileName)
+ elif loc == 'location':
+ filePath = os.path.join(gisdbase, location_name, self.fileName)
+ elif loc == 'mapset':
+ filePath = os.path.join(gisdbase, location_name, mapset_name, self.fileName)
+ if filePath is None:
+ raise gcmd.SettingsError('Uknown file location.')
+ try:
+ file = open(filePath, "w")
+ for item in settings.keys():
+ if settings[item] != '':
+ file.write('%s:%s%s' % (item, settings[item], os.linesep))
+ except:
+ raise gcmd.SettingsError('Writing settings to file <%s> failed.' % filePath)
+ file.close()
+ return filePath
def Get(self, key):
"""Get value by key
@@ -86,23 +182,23 @@
self.__CreateAdvancedPage(notebook)
# buttons
- # btnSave = wx.Button(self, wx.ID_SAVE)
+ btnSave = wx.Button(self, wx.ID_SAVE)
btnApply = wx.Button(self, wx.ID_APPLY)
btnCancel = wx.Button(self, wx.ID_CANCEL)
- btnOk = wx.Button(self, wx.ID_OK)
- btnOk.SetDefault()
+ # btnOk = wx.Button(self, wx.ID_OK)
+ btnSave.SetDefault()
# bindigs
btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
- btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
+ btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
# sizers
btnSizer = wx.StdDialogButtonSizer()
btnSizer.AddButton(btnCancel)
- # btnSizer.AddButton(btnSave)
+ btnSizer.AddButton(btnSave)
btnSizer.AddButton(btnApply)
- btnSizer.AddButton(btnOk)
+ # btnSizer.AddButton(btnOk)
btnSizer.Realize()
mainSizer = wx.BoxSizer(wx.VERTICAL)
@@ -167,6 +263,8 @@
gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
gridSizer.AddGrowableCol(0)
+ row = 0
# place where to store settings
@@ -174,30 +272,59 @@
label=_("Place where to store settings:")),
flag=wx.ALIGN_LEFT |
wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 0))
+ pos=(row, 0))
self.settingsFile = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
- choices=['home', 'location', 'mapset'])
+ choices=['gisdbase', 'location', 'mapset'])
self.settingsFile.SetStringSelection(self.settings.Get('settingsFile'))
gridSizer.Add(item=self.settingsFile,
flag=wx.ALIGN_RIGHT |
- pos=(0, 1))
+ pos=(row, 1))
+ row += 1
+ # icon theme
+ gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("Icon theme:")),
+ flag=wx.ALIGN_LEFT |
+ wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 0))
+ self.iconTheme = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ choices=['grass', 'silk'])
+ self.iconTheme.SetStringSelection(self.settings.Get('iconTheme'))
+ gridSizer.Add(item=self.iconTheme,
+ flag=wx.ALIGN_RIGHT |
+ pos=(row, 1))
+ row += 1
+ iconNote = wordwrap(_("Note: Requires GUI restart."),
+ self.GetSize()[0]-50, wx.ClientDC(self))
+ label=iconNote),
+ pos=(row, 0), span=(1, 2))
+ row += 1
# digitization interface
label=_("Digitization interface:")),
- pos=(1, 0))
+ pos=(row, 0))
self.digitInterface = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
choices=['vdigit', 'vedit'])
self.digitInterface.SetStringSelection(self.settings.Get('digitInterface'))
gridSizer.Add(item=self.digitInterface,
- pos=(1, 1))
+ pos=(row, 1))
+ row += 1
digitNote = wordwrap(_("Note: User can choose from two interfaces for digitization. "
"The simple one uses v.edit command on the background. "
@@ -211,7 +338,7 @@
label=digitNote),
- pos=(2, 0), span=(1, 2))
sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=3)
@@ -246,9 +373,11 @@
event.Skip()
- def OnOK(self, event):
- """Button 'OK' clicked"""
+ def OnSave(self, event):
+ """Button 'Save' clicked"""
self.__UpdateSettings()
+ file = self.settings.SaveToFile()
+ self.parent.goutput.cmd_stdout.write('Settings saved to file <%s>.' % file)
self.Close()
def OnApply(self, event):
@@ -266,6 +395,9 @@
# location
self.settings.Set('settingsFile', self.settingsFile.GetStringSelection())
+ # icon theme
+ self.settings.Set('iconTheme', self.iconTheme.GetStringSelection())
self.settings.Set('digitInterface', self.digitInterface.GetStringSelection())
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2008-02-10 20:21:54 UTC (rev 30070)
+++ grass/trunk/gui/wxpython/icons/icon.py 2008-02-10 22:03:58 UTC (rev 30071)
@@ -24,11 +24,18 @@
gmPath = os.path.join(os.getenv("GISBASE"), "etc", "wx", "gui_modules")
sys.path.append(gmPath)
import grassenv
+from preferences import globalSettings as UserSettings
-iconpath = grassenv.GetGRASSVariable('GRASS_ICONPATH')
-if not iconpath:
- iconpath = os.getenv("GRASS_ICONPATH")
+# iconpath = grassenv.GetGRASSVariable('GRASS_ICONPATH')
+# if not iconpath:
+# iconpath = os.getenv("GRASS_ICONPATH")
+iconTheme = UserSettings.Get('iconTheme')
+if iconTheme and iconTheme == 'silk':
+ iconpath = os.path.join(os.getenv("GISBASE"), "etc", "wx", "icons", "silk")
+else:
+ iconpath = None
iconpath_default = os.path.join(os.getenv("GISBASE"), "etc", "gui", "icons")
iconpath_vdigit = os.path.join(os.getenv("GISBASE"), "etc", "v.digit")
