[GRASS-SVN] r30089 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Mon Feb 11 11:34:45 EST 2008
Author: martinl
Date: 2008-02-11 11:34:45 -0500 (Mon, 11 Feb 2008)
New Revision: 30089
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI/vdigit: fix snapping to vertex for new feature or when editing existing feature
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-11 16:21:39 UTC (rev 30088)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-11 16:34:45 UTC (rev 30089)
@@ -938,7 +938,10 @@
for x in c:
listCoords.append(x)
- return self.digit.RewriteLine(lineid, listCoords)
+ snap, thresh = self.__getSnapThreshold()
+ return self.digit.RewriteLine(lineid, listCoords,
+ str(self.settings["backgroundMap"]), snap, thresh)
def FlipLine(self):
"""Flip selected lines/boundaries"""
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2008-02-11 16:21:39 UTC (rev 30088)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-02-11 16:34:45 UTC (rev 30089)
@@ -23,7 +23,8 @@
int AddLine(int, std::vector<double>, int, int,
const char*, int, double);
- int RewriteLine(int, std::vector<double>);
+ int RewriteLine(int, std::vector<double>,
+ const char*, int, double);
int SplitLine(double, double, double,
double);
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-02-11 16:21:39 UTC (rev 30088)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-02-11 16:34:45 UTC (rev 30089)
@@ -116,7 +116,7 @@
if (snap != NO_SNAP) { /* apply snapping (node or vertex) */
Vedit_snap_line(display->mapInfo, BgMap, nbgmaps,
-1, Points,
- threshold, (SNAP) ? 0 : 1);
+ threshold, (snap == SNAP) ? 0 : 1);
if (Vect_write_line(display->mapInfo, type, Points, Cats) < 0) {
@@ -140,17 +140,24 @@
\param line line id
\param coords line geometry
+ \param bgmap map of background map or NULL
+ \param snap snapping mode (see vedit.h)
+ \param thresh threshold value for snapping
\return new line id
\return -1 error
-int Digit::RewriteLine(int line, std::vector<double> coords)
+int Digit::RewriteLine(int line, std::vector<double> coords,
+ const char *bgmap, int snap, double threshold)
int ret, type, dim;
double x, y, z;
struct line_pnts *points;
struct line_cats *cats;
+ struct Map_info **BgMap; /* backgroud vector maps */
+ int nbgmaps; /* number of registrated background maps */
if (!display->mapInfo) {
return -1;
@@ -159,6 +166,18 @@
if (!Vect_line_alive(display->mapInfo, line)) {
return -1;
+ BgMap = NULL;
+ nbgmaps = 0;
+ if (bgmap && strlen(bgmap) > 0) {
+ BgMap = OpenBackgroundVectorMap(bgmap);
+ if (!BgMap) {
+ return -1;
+ else {
+ nbgmaps = 1;
ret = 0;
points = Vect_new_line_struct();
@@ -186,6 +205,12 @@
+ if (snap != NO_SNAP) { /* apply snapping (node or vertex) */
+ Vedit_snap_line(display->mapInfo, BgMap, nbgmaps,
+ -1, points,
/* rewrite line */
if (ret == 0) {
if (Vect_rewrite_line(display->mapInfo, line, type, points, cats) < 0) {
@@ -196,6 +221,10 @@
Vect_destroy_line_struct(points);
Vect_destroy_cats_struct(cats);
+ if (BgMap && BgMap[0]) {
+ Vect_close(BgMap[0]);
return ret;
