[GRASS-SVN] r30095 - grass/trunk/gui/wxpython/vdigit
svn_grass at osgeo.org
Tue Feb 12 07:30:10 EST 2008
Author: martinl
Date: 2008-02-12 07:30:10 -0500 (Tue, 12 Feb 2008)
New Revision: 30095
Added:
grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit.py
grass/trunk/gui/wxpython/vdigit/Makefile.in
grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
wxGUI/vdigit: * vdigit python module added to SVN
* swig-based cpp wrapper file updated
* Makefile template modified to avoid regenerating wrapper cpp file
Property changes on: grass/trunk/gui/wxpython/vdigit
___________________________________________________________________
- Makefile
*.so
grass6_wxvdigit.*
OBJ.*
+ Makefile
*.so
OBJ.*
Modified: grass/trunk/gui/wxpython/vdigit/Makefile.in
--- grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-02-12 12:16:14 UTC (rev 30094)
+++ grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-02-12 12:30:10 UTC (rev 30095)
@@ -25,7 +25,7 @@
default: grass6_wxvdigit.so
clean:
- -rm -rf $(OBJARCH) _grass6_wxvdigit.so grass6_wxvdigit_wrap.cpp grass6_wxvdigit.py grass6_wxvdigit.i grass6_wxvdigit.pyc
+ -rm -rf $(OBJARCH) _grass6_wxvdigit.so grass6_wxvdigit.i
grass6_wxvdigit.i:
cat ./digit.i > grass6_wxvdigit.i
@@ -37,11 +37,8 @@
grass6_wxvdigit_wrap.cpp: grass6_wxvdigit.i
$(SWIG) -c++ -python -shadow -o $@ $<
-$(OBJARCH)/grass6_wxvdigit_wrap.o: grass6_wxvdigit_wrap.cpp $(OBJARCH)
- $(CXX) $(CXXFLAGS) $(INCLUDE_DIRS) $< -o $@
$(OBJARCH)/%.o: %.cpp $(LOCAL_HEADERS)
-grass6_wxvdigit.so: $(OBJARCH)/grass6_wxvdigit_wrap.o $(OBJ)
- $(CXX) $(LDFLAGS) $(OBJARCH)/grass6_wxvdigit_wrap.o $(OBJ) -o _grass6_wxvdigit.so
+grass6_wxvdigit.so: $(OBJ)
+ $(CXX) $(LDFLAGS) $(OBJ) -o _grass6_wxvdigit.so
Added: grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit.py
--- grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit.py (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit.py 2008-02-12 12:30:10 UTC (rev 30095)
@@ -0,0 +1,302 @@
+# This file was automatically generated by SWIG (http://www.swig.org).
+# Version 1.3.33
+# Don't modify this file, modify the SWIG interface instead.
+# This file is compatible with both classic and new-style classes.
+import _grass6_wxvdigit
+import new
+new_instancemethod = new.instancemethod
+try:
+ _swig_property = property
+except NameError:
+ pass # Python < 2.2 doesn't have 'property'.
+def _swig_setattr_nondynamic(self,class_type,name,value,static=1):
+ if (name == "thisown"): return self.this.own(value)
+ if (name == "this"):
+ if type(value).__name__ == 'PySwigObject':
+ self.__dict__[name] = value
+ return
+ method = class_type.__swig_setmethods__.get(name,None)
+ if method: return method(self,value)
+ if (not static) or hasattr(self,name):
+ else:
+ raise AttributeError("You cannot add attributes to %s" % self)
+def _swig_setattr(self,class_type,name,value):
+ return _swig_setattr_nondynamic(self,class_type,name,value,0)
+def _swig_getattr(self,class_type,name):
+ if (name == "thisown"): return self.this.own()
+ method = class_type.__swig_getmethods__.get(name,None)
+ if method: return method(self)
+ raise AttributeError,name
+def _swig_repr(self):
+ try: strthis = "proxy of " + self.this.__repr__()
+ except: strthis = ""
+ return "<%s.%s; %s >" % (self.__class__.__module__, self.__class__.__name__, strthis,)
+import types
+try:
+ _object = types.ObjectType
+ _newclass = 1
+except AttributeError:
+ class _object : pass
+ _newclass = 0
+del types
+class PySwigIterator(_object):
+ __swig_setmethods__ = {}
+ __setattr__ = lambda self, name, value: _swig_setattr(self, PySwigIterator, name, value)
+ __swig_getmethods__ = {}
+ __getattr__ = lambda self, name: _swig_getattr(self, PySwigIterator, name)
+ def __init__(self): raise AttributeError, "No constructor defined"
+ __repr__ = _swig_repr
+ __swig_destroy__ = _grass6_wxvdigit.delete_PySwigIterator
+ __del__ = lambda self : None;
+ def value(*args): return _grass6_wxvdigit.PySwigIterator_value(*args)
+ def incr(*args): return _grass6_wxvdigit.PySwigIterator_incr(*args)
+ def decr(*args): return _grass6_wxvdigit.PySwigIterator_decr(*args)
+ def distance(*args): return _grass6_wxvdigit.PySwigIterator_distance(*args)
+ def equal(*args): return _grass6_wxvdigit.PySwigIterator_equal(*args)
+ def copy(*args): return _grass6_wxvdigit.PySwigIterator_copy(*args)
+ def next(*args): return _grass6_wxvdigit.PySwigIterator_next(*args)
+ def previous(*args): return _grass6_wxvdigit.PySwigIterator_previous(*args)
+ def advance(*args): return _grass6_wxvdigit.PySwigIterator_advance(*args)
+ def __eq__(*args): return _grass6_wxvdigit.PySwigIterator___eq__(*args)
+ def __ne__(*args): return _grass6_wxvdigit.PySwigIterator___ne__(*args)
+ def __iadd__(*args): return _grass6_wxvdigit.PySwigIterator___iadd__(*args)
+ def __isub__(*args): return _grass6_wxvdigit.PySwigIterator___isub__(*args)
+ def __add__(*args): return _grass6_wxvdigit.PySwigIterator___add__(*args)
+ def __sub__(*args): return _grass6_wxvdigit.PySwigIterator___sub__(*args)
+ def __iter__(self): return self
+PySwigIterator_swigregister = _grass6_wxvdigit.PySwigIterator_swigregister
+PySwigIterator_swigregister(PySwigIterator)
+class IntVector(_object):
+ __setattr__ = lambda self, name, value: _swig_setattr(self, IntVector, name, value)
+ __getattr__ = lambda self, name: _swig_getattr(self, IntVector, name)
+ def iterator(*args): return _grass6_wxvdigit.IntVector_iterator(*args)
+ def __iter__(self): return self.iterator()
+ def __nonzero__(*args): return _grass6_wxvdigit.IntVector___nonzero__(*args)
+ def __len__(*args): return _grass6_wxvdigit.IntVector___len__(*args)
+ def pop(*args): return _grass6_wxvdigit.IntVector_pop(*args)
+ def __getslice__(*args): return _grass6_wxvdigit.IntVector___getslice__(*args)
+ def __setslice__(*args): return _grass6_wxvdigit.IntVector___setslice__(*args)
+ def __delslice__(*args): return _grass6_wxvdigit.IntVector___delslice__(*args)
+ def __delitem__(*args): return _grass6_wxvdigit.IntVector___delitem__(*args)
+ def __getitem__(*args): return _grass6_wxvdigit.IntVector___getitem__(*args)
+ def __setitem__(*args): return _grass6_wxvdigit.IntVector___setitem__(*args)
+ def append(*args): return _grass6_wxvdigit.IntVector_append(*args)
+ def empty(*args): return _grass6_wxvdigit.IntVector_empty(*args)
+ def size(*args): return _grass6_wxvdigit.IntVector_size(*args)
+ def clear(*args): return _grass6_wxvdigit.IntVector_clear(*args)
+ def swap(*args): return _grass6_wxvdigit.IntVector_swap(*args)
+ def get_allocator(*args): return _grass6_wxvdigit.IntVector_get_allocator(*args)
+ def begin(*args): return _grass6_wxvdigit.IntVector_begin(*args)
+ def end(*args): return _grass6_wxvdigit.IntVector_end(*args)
+ def rbegin(*args): return _grass6_wxvdigit.IntVector_rbegin(*args)
+ def rend(*args): return _grass6_wxvdigit.IntVector_rend(*args)
+ def pop_back(*args): return _grass6_wxvdigit.IntVector_pop_back(*args)
+ def erase(*args): return _grass6_wxvdigit.IntVector_erase(*args)
+ def __init__(self, *args):
+ this = _grass6_wxvdigit.new_IntVector(*args)
+ try: self.this.append(this)
+ except: self.this = this
+ def push_back(*args): return _grass6_wxvdigit.IntVector_push_back(*args)
+ def front(*args): return _grass6_wxvdigit.IntVector_front(*args)
+ def back(*args): return _grass6_wxvdigit.IntVector_back(*args)
+ def assign(*args): return _grass6_wxvdigit.IntVector_assign(*args)
+ def resize(*args): return _grass6_wxvdigit.IntVector_resize(*args)
+ def insert(*args): return _grass6_wxvdigit.IntVector_insert(*args)
+ def reserve(*args): return _grass6_wxvdigit.IntVector_reserve(*args)
+ def capacity(*args): return _grass6_wxvdigit.IntVector_capacity(*args)
+ __swig_destroy__ = _grass6_wxvdigit.delete_IntVector
+IntVector_swigregister = _grass6_wxvdigit.IntVector_swigregister
+IntVector_swigregister(IntVector)
+class DoubleVector(_object):
+ __setattr__ = lambda self, name, value: _swig_setattr(self, DoubleVector, name, value)
+ __getattr__ = lambda self, name: _swig_getattr(self, DoubleVector, name)
+ def iterator(*args): return _grass6_wxvdigit.DoubleVector_iterator(*args)
+ def __nonzero__(*args): return _grass6_wxvdigit.DoubleVector___nonzero__(*args)
+ def __len__(*args): return _grass6_wxvdigit.DoubleVector___len__(*args)
+ def pop(*args): return _grass6_wxvdigit.DoubleVector_pop(*args)
+ def __getslice__(*args): return _grass6_wxvdigit.DoubleVector___getslice__(*args)
+ def __setslice__(*args): return _grass6_wxvdigit.DoubleVector___setslice__(*args)
+ def __delslice__(*args): return _grass6_wxvdigit.DoubleVector___delslice__(*args)
+ def __delitem__(*args): return _grass6_wxvdigit.DoubleVector___delitem__(*args)
+ def __getitem__(*args): return _grass6_wxvdigit.DoubleVector___getitem__(*args)
+ def __setitem__(*args): return _grass6_wxvdigit.DoubleVector___setitem__(*args)
+ def append(*args): return _grass6_wxvdigit.DoubleVector_append(*args)
+ def empty(*args): return _grass6_wxvdigit.DoubleVector_empty(*args)
+ def size(*args): return _grass6_wxvdigit.DoubleVector_size(*args)
+ def clear(*args): return _grass6_wxvdigit.DoubleVector_clear(*args)
+ def swap(*args): return _grass6_wxvdigit.DoubleVector_swap(*args)
+ def get_allocator(*args): return _grass6_wxvdigit.DoubleVector_get_allocator(*args)
+ def begin(*args): return _grass6_wxvdigit.DoubleVector_begin(*args)
+ def end(*args): return _grass6_wxvdigit.DoubleVector_end(*args)
+ def rbegin(*args): return _grass6_wxvdigit.DoubleVector_rbegin(*args)
+ def rend(*args): return _grass6_wxvdigit.DoubleVector_rend(*args)
+ def pop_back(*args): return _grass6_wxvdigit.DoubleVector_pop_back(*args)
+ def erase(*args): return _grass6_wxvdigit.DoubleVector_erase(*args)
+ this = _grass6_wxvdigit.new_DoubleVector(*args)
+ def push_back(*args): return _grass6_wxvdigit.DoubleVector_push_back(*args)
+ def front(*args): return _grass6_wxvdigit.DoubleVector_front(*args)
+ def back(*args): return _grass6_wxvdigit.DoubleVector_back(*args)
+ def assign(*args): return _grass6_wxvdigit.DoubleVector_assign(*args)
+ def resize(*args): return _grass6_wxvdigit.DoubleVector_resize(*args)
+ def insert(*args): return _grass6_wxvdigit.DoubleVector_insert(*args)
+ def reserve(*args): return _grass6_wxvdigit.DoubleVector_reserve(*args)
+ def capacity(*args): return _grass6_wxvdigit.DoubleVector_capacity(*args)
+ __swig_destroy__ = _grass6_wxvdigit.delete_DoubleVector
+DoubleVector_swigregister = _grass6_wxvdigit.DoubleVector_swigregister
+DoubleVector_swigregister(DoubleVector)
+class IntVecIntMap(_object):
+ __setattr__ = lambda self, name, value: _swig_setattr(self, IntVecIntMap, name, value)
+ __getattr__ = lambda self, name: _swig_getattr(self, IntVecIntMap, name)
+ def iterator(*args): return _grass6_wxvdigit.IntVecIntMap_iterator(*args)
+ def __nonzero__(*args): return _grass6_wxvdigit.IntVecIntMap___nonzero__(*args)
+ def __len__(*args): return _grass6_wxvdigit.IntVecIntMap___len__(*args)
+ def __getitem__(*args): return _grass6_wxvdigit.IntVecIntMap___getitem__(*args)
+ def __delitem__(*args): return _grass6_wxvdigit.IntVecIntMap___delitem__(*args)
+ def has_key(*args): return _grass6_wxvdigit.IntVecIntMap_has_key(*args)
+ def keys(*args): return _grass6_wxvdigit.IntVecIntMap_keys(*args)
+ def values(*args): return _grass6_wxvdigit.IntVecIntMap_values(*args)
+ def items(*args): return _grass6_wxvdigit.IntVecIntMap_items(*args)
+ def __contains__(*args): return _grass6_wxvdigit.IntVecIntMap___contains__(*args)
+ def key_iterator(*args): return _grass6_wxvdigit.IntVecIntMap_key_iterator(*args)
+ def value_iterator(*args): return _grass6_wxvdigit.IntVecIntMap_value_iterator(*args)
+ def __iter__(self): return self.key_iterator()
+ def iterkeys(self): return self.key_iterator()
+ def itervalues(self): return self.value_iterator()
+ def iteritems(self): return self.iterator()
+ def __setitem__(*args): return _grass6_wxvdigit.IntVecIntMap___setitem__(*args)
+ this = _grass6_wxvdigit.new_IntVecIntMap(*args)
+ def empty(*args): return _grass6_wxvdigit.IntVecIntMap_empty(*args)
+ def size(*args): return _grass6_wxvdigit.IntVecIntMap_size(*args)
+ def clear(*args): return _grass6_wxvdigit.IntVecIntMap_clear(*args)
+ def swap(*args): return _grass6_wxvdigit.IntVecIntMap_swap(*args)
+ def get_allocator(*args): return _grass6_wxvdigit.IntVecIntMap_get_allocator(*args)
+ def begin(*args): return _grass6_wxvdigit.IntVecIntMap_begin(*args)
+ def end(*args): return _grass6_wxvdigit.IntVecIntMap_end(*args)
+ def rbegin(*args): return _grass6_wxvdigit.IntVecIntMap_rbegin(*args)
+ def rend(*args): return _grass6_wxvdigit.IntVecIntMap_rend(*args)
+ def count(*args): return _grass6_wxvdigit.IntVecIntMap_count(*args)
+ def erase(*args): return _grass6_wxvdigit.IntVecIntMap_erase(*args)
+ def find(*args): return _grass6_wxvdigit.IntVecIntMap_find(*args)
+ def lower_bound(*args): return _grass6_wxvdigit.IntVecIntMap_lower_bound(*args)
+ def upper_bound(*args): return _grass6_wxvdigit.IntVecIntMap_upper_bound(*args)
+ __swig_destroy__ = _grass6_wxvdigit.delete_IntVecIntMap
+IntVecIntMap_swigregister = _grass6_wxvdigit.IntVecIntMap_swigregister
+IntVecIntMap_swigregister(IntVecIntMap)
+class DisplayDriver(_object):
+ __setattr__ = lambda self, name, value: _swig_setattr(self, DisplayDriver, name, value)
+ __getattr__ = lambda self, name: _swig_getattr(self, DisplayDriver, name)
+ this = _grass6_wxvdigit.new_DisplayDriver(*args)
+ __swig_destroy__ = _grass6_wxvdigit.delete_DisplayDriver
+ def DrawMap(*args): return _grass6_wxvdigit.DisplayDriver_DrawMap(*args)
+ def SelectLinesByBox(*args): return _grass6_wxvdigit.DisplayDriver_SelectLinesByBox(*args)
+ def SelectLineByPoint(*args): return _grass6_wxvdigit.DisplayDriver_SelectLineByPoint(*args)
+ def GetSelected(*args): return _grass6_wxvdigit.DisplayDriver_GetSelected(*args)
+ def SetSelected(*args): return _grass6_wxvdigit.DisplayDriver_SetSelected(*args)
+ def GetSelectedVertex(*args): return _grass6_wxvdigit.DisplayDriver_GetSelectedVertex(*args)
+ def CloseMap(*args): return _grass6_wxvdigit.DisplayDriver_CloseMap(*args)
+ def OpenMap(*args): return _grass6_wxvdigit.DisplayDriver_OpenMap(*args)
+ def ReloadMap(*args): return _grass6_wxvdigit.DisplayDriver_ReloadMap(*args)
+ def SetDevice(*args): return _grass6_wxvdigit.DisplayDriver_SetDevice(*args)
+ def SetRegion(*args): return _grass6_wxvdigit.DisplayDriver_SetRegion(*args)
+ def UpdateSettings(*args): return _grass6_wxvdigit.DisplayDriver_UpdateSettings(*args)
+DisplayDriver_swigregister = _grass6_wxvdigit.DisplayDriver_swigregister
+DisplayDriver_swigregister(DisplayDriver)
+print_error = _grass6_wxvdigit.print_error
+GSQL_MAX = _grass6_wxvdigit.GSQL_MAX
+class Digit(_object):
+ __setattr__ = lambda self, name, value: _swig_setattr(self, Digit, name, value)
+ __getattr__ = lambda self, name: _swig_getattr(self, Digit, name)
+ this = _grass6_wxvdigit.new_Digit(*args)
+ def InitCats(*args): return _grass6_wxvdigit.Digit_InitCats(*args)
+ def AddLine(*args): return _grass6_wxvdigit.Digit_AddLine(*args)
+ def RewriteLine(*args): return _grass6_wxvdigit.Digit_RewriteLine(*args)
+ def SplitLine(*args): return _grass6_wxvdigit.Digit_SplitLine(*args)
+ def DeleteLines(*args): return _grass6_wxvdigit.Digit_DeleteLines(*args)
+ def MoveLines(*args): return _grass6_wxvdigit.Digit_MoveLines(*args)
+ def FlipLines(*args): return _grass6_wxvdigit.Digit_FlipLines(*args)
+ def MergeLines(*args): return _grass6_wxvdigit.Digit_MergeLines(*args)
+ def BreakLines(*args): return _grass6_wxvdigit.Digit_BreakLines(*args)
+ def SnapLines(*args): return _grass6_wxvdigit.Digit_SnapLines(*args)
+ def ConnectLines(*args): return _grass6_wxvdigit.Digit_ConnectLines(*args)
+ def TypeConvLines(*args): return _grass6_wxvdigit.Digit_TypeConvLines(*args)
+ def ZBulkLabeling(*args): return _grass6_wxvdigit.Digit_ZBulkLabeling(*args)
+ def CopyLines(*args): return _grass6_wxvdigit.Digit_CopyLines(*args)
+ def MoveVertex(*args): return _grass6_wxvdigit.Digit_MoveVertex(*args)
+ def ModifyLineVertex(*args): return _grass6_wxvdigit.Digit_ModifyLineVertex(*args)
+ def SelectLinesByQuery(*args): return _grass6_wxvdigit.Digit_SelectLinesByQuery(*args)
+ def CopyCats(*args): return _grass6_wxvdigit.Digit_CopyCats(*args)
+ def GetCategory(*args): return _grass6_wxvdigit.Digit_GetCategory(*args)
+ def GetLineCats(*args): return _grass6_wxvdigit.Digit_GetLineCats(*args)
+ def SetLineCats(*args): return _grass6_wxvdigit.Digit_SetLineCats(*args)
+ def GetLayers(*args): return _grass6_wxvdigit.Digit_GetLayers(*args)
+ __swig_destroy__ = _grass6_wxvdigit.delete_Digit
+Digit_swigregister = _grass6_wxvdigit.Digit_swigregister
+Digit_swigregister(Digit)
+GV_POINT = _grass6_wxvdigit.GV_POINT
+GV_LINE = _grass6_wxvdigit.GV_LINE
+GV_BOUNDARY = _grass6_wxvdigit.GV_BOUNDARY
+GV_CENTROID = _grass6_wxvdigit.GV_CENTROID
+GV_FACE = _grass6_wxvdigit.GV_FACE
+GV_KERNEL = _grass6_wxvdigit.GV_KERNEL
+GV_AREA = _grass6_wxvdigit.GV_AREA
+GV_VOLUME = _grass6_wxvdigit.GV_VOLUME
+GV_POINTS = _grass6_wxvdigit.GV_POINTS
+GV_LINES = _grass6_wxvdigit.GV_LINES
+PORT_DOUBLE_MAX = _grass6_wxvdigit.PORT_DOUBLE_MAX
+NO_SNAP = _grass6_wxvdigit.NO_SNAP
+SNAP = _grass6_wxvdigit.SNAP
+SNAPVERTEX = _grass6_wxvdigit.SNAPVERTEX
+QUERY_UNKNOWN = _grass6_wxvdigit.QUERY_UNKNOWN
+QUERY_LENGTH = _grass6_wxvdigit.QUERY_LENGTH
+QUERY_DANGLE = _grass6_wxvdigit.QUERY_DANGLE
Modified: grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
--- grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp 2008-02-12 12:16:14 UTC (rev 30094)
+++ grass/trunk/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp 2008-02-12 12:30:10 UTC (rev 30095)
@@ -10912,16 +10912,29 @@
Digit *arg1 = (Digit *) 0 ;
int arg2 ;
std::vector<double,std::allocator<double > > arg3 ;
+ char *arg4 = (char *) 0 ;
+ int arg5 ;
+ double arg6 ;
int result;
void *argp1 = 0 ;
int res1 = 0 ;
int val2 ;
int ecode2 = 0 ;
+ int res4 ;
+ char *buf4 = 0 ;
+ int alloc4 = 0 ;
+ int val5 ;
+ int ecode5 = 0 ;
+ double val6 ;
+ int ecode6 = 0 ;
PyObject * obj0 = 0 ;
PyObject * obj1 = 0 ;
PyObject * obj2 = 0 ;
+ PyObject * obj3 = 0 ;
+ PyObject * obj4 = 0 ;
+ PyObject * obj5 = 0 ;
- if (!PyArg_ParseTuple(args,(char *)"OOO:Digit_RewriteLine",&obj0,&obj1,&obj2)) SWIG_fail;
+ if (!PyArg_ParseTuple(args,(char *)"OOOOOO:Digit_RewriteLine",&obj0,&obj1,&obj2,&obj3,&obj4,&obj5)) SWIG_fail;
res1 = SWIG_ConvertPtr(obj0, &argp1,SWIGTYPE_p_Digit, 0 | 0 );
if (!SWIG_IsOK(res1)) {
SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "Digit_RewriteLine" "', argument " "1"" of type '" "Digit *""'");
@@ -10941,10 +10954,27 @@
arg3 = *ptr;
if (SWIG_IsNewObj(res)) delete ptr;
- result = (int)(arg1)->RewriteLine(arg2,arg3);
+ res4 = SWIG_AsCharPtrAndSize(obj3, &buf4, NULL, &alloc4);
+ if (!SWIG_IsOK(res4)) {
+ SWIG_exception_fail(SWIG_ArgError(res4), "in method '" "Digit_RewriteLine" "', argument " "4"" of type '" "char const *""'");
+ arg4 = reinterpret_cast< char * >(buf4);
+ ecode5 = SWIG_AsVal_int(obj4, &val5);
+ if (!SWIG_IsOK(ecode5)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode5), "in method '" "Digit_RewriteLine" "', argument " "5"" of type '" "int""'");
+ arg5 = static_cast< int >(val5);
+ ecode6 = SWIG_AsVal_double(obj5, &val6);
+ if (!SWIG_IsOK(ecode6)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode6), "in method '" "Digit_RewriteLine" "', argument " "6"" of type '" "double""'");
+ arg6 = static_cast< double >(val6);
+ result = (int)(arg1)->RewriteLine(arg2,arg3,(char const *)arg4,arg5,arg6);
resultobj = SWIG_From_int(static_cast< int >(result));
+ if (alloc4 == SWIG_NEWOBJ) delete[] buf4;
return resultobj;
fail:
return NULL;
