[GRASS-SVN] r30099 - grass/trunk/visualization/nviz/scripts
svn_grass at osgeo.org
Tue Feb 12 08:28:16 EST 2008
Author: neteler
Date: 2008-02-12 08:28:16 -0500 (Tue, 12 Feb 2008)
New Revision: 30099
grass/trunk/visualization/nviz/scripts/panel_site.tcl
grass/trunk/visualization/nviz/scripts/panel_vect.tcl
grass/trunk/visualization/nviz/scripts/site_attr.tcl
Maris Nartiss: fixed 'display flat' button from crashing UI: 'display thematic' crashing UI if no point maps is selected; linewrap fix in site_attr
Modified: grass/trunk/visualization/nviz/scripts/panel_site.tcl
--- grass/trunk/visualization/nviz/scripts/panel_site.tcl 2008-02-12 13:19:06 UTC (rev 30098)
+++ grass/trunk/visualization/nviz/scripts/panel_site.tcl 2008-02-12 13:28:16 UTC (rev 30099)
@@ -114,7 +114,7 @@
-command "Nv_closePanel $BASE" -anchor s -bd 1
pack $bottom.close -side right
- button $bottom.draw_current -text {DRAW CURRENT} -fg darkgreen -anchor s \
+ button $bottom.draw_current -text "DRAW CURRENT" -fg darkgreen -anchor s \
-command {Nsite_draw_one [Nget_current site]} -bd 1
pack $bottom.draw_current -side left
@@ -178,7 +178,7 @@
set site_attr(FIELD_ATTR_PANEL) 0
checkbutton $row4.themechk -text "thematic mapping for vector points" \
- -variable site_attr(FIELD_ATTR_PANEL) -command "site_attr_gui $row5 $bottom $curr" \
+ -variable site_attr(FIELD_ATTR_PANEL) -command "if {$curr!=0} {site_attr_gui $row5 $bottom $curr}" \
-offvalue 0 -onvalue 1
pack $row4.themechk -side left -anchor nw
Modified: grass/trunk/visualization/nviz/scripts/panel_vect.tcl
--- grass/trunk/visualization/nviz/scripts/panel_vect.tcl 2008-02-12 13:19:06 UTC (rev 30098)
+++ grass/trunk/visualization/nviz/scripts/panel_vect.tcl 2008-02-12 13:28:16 UTC (rev 30099)
@@ -79,7 +79,7 @@
set tmp [frame $BASE.f]
button $tmp.close -text Close -command "Nv_closePanel $BASE" -anchor s -bd 1
pack $tmp.close -side right
- button $tmp.draw_current -text {DRAW CURRENT} -bd 1 -fg darkgreen \
+ button $tmp.draw_current -text "DRAW CURRENT" -bd 1 -fg darkgreen \
-command {Nvect_draw_one [Nget_current vect]}
pack $tmp.draw_current -side left
pack $tmp -side bottom -fill x -expand 1 -padx 3
@@ -89,6 +89,7 @@
set row1 [frame $tmp.row1]
set row2 [frame $tmp.row2]
set row3 [frame $tmp.row3]
+ set row4 [frame $tmp.row4]
set tmp1a [frame $row1.b]
set wlabel [label $row1.wlabel -text "line width" \
@@ -106,14 +107,14 @@
-command "change_color vect $row1.color"]
bind $row1.color <Expose> "$row1.color configure -bg \[get_curr_sv_color vect\]"
- set rb1 [radiobutton $row1.label2 -text "display flat" \
- -variable flat_state -value 1 -command "check_list $row2.list"]
+ set rb1 [radiobutton $row2.label2 -text "display flat" \
+ -variable flat_state -value 1 -command "check_list $row3.list"]
set rb2 [radiobutton $row2.label1 -text "display on surface(s):" \
-variable flat_state -value 0 \
- -command "check_list $row2.list"]
+ -command "check_list $row3.list"]
- set htscale [Nv_mkScale $row3.scale h "vector height\nabove surface" 0 10000 $height set_ht 1]
+ set htscale [Nv_mkScale $row4.scale h "vector height\nabove surface" 0 10000 $height set_ht 1]
pack $wlabel $vlinewidth -side left
@@ -122,21 +123,22 @@
pack $row1 -expand 1 -fill none -pady 4
pack $rb2 -side left
pack $row2 -side left
+ pack $row3 -side left
pack $htscale -side top -anchor w
- pack $row3 -side top -fill x -expand 1 -pady 4
+ pack $row4 -side top -fill x -expand 1 -pady 4
# Let radiobutton state handle building list
# of available surfaces
if {$flat_state == 0} {
$row2.label1 select
- check_list $row2.list
+ check_list $row3.list
} else {
$row2.label2 select
- pack $row1 $row2 -side top -fill both -expand 1
- pack $row3 -side right -fill both -expand 1
+ pack $row1 $row2 $row3 -side top -fill both -expand 1
+ pack $row4 -side right -fill both -expand 1
pack $tmp -side top -fill both -expand 1 -padx 3
return $panel
Modified: grass/trunk/visualization/nviz/scripts/site_attr.tcl
--- grass/trunk/visualization/nviz/scripts/site_attr.tcl 2008-02-12 13:19:06 UTC (rev 30098)
+++ grass/trunk/visualization/nviz/scripts/site_attr.tcl 2008-02-12 13:28:16 UTC (rev 30099)
@@ -426,8 +426,7 @@
generate a color table."
default {
- puts "WARNING: No thematic mapping preferences set"
- for $site_attr($_idx.ATTR)!"
+ puts "WARNING: No thematic mapping preferences set for $site_attr($_idx.ATTR)!"
