[GRASS-SVN] r30109 - in grass/trunk/raster: r.coin r.in.gdal
r.quant r.report r.transect r.water.outlet
svn_grass at osgeo.org
Wed Feb 13 04:40:49 EST 2008
Author: neteler
Date: 2008-02-13 04:40:48 -0500 (Wed, 13 Feb 2008)
New Revision: 30109
grass/trunk/raster/r.coin/inter.c
grass/trunk/raster/r.in.gdal/main.c
grass/trunk/raster/r.quant/global.h
grass/trunk/raster/r.report/parse.c
grass/trunk/raster/r.transect/main.c
grass/trunk/raster/r.water.outlet/basin.h
grass/trunk/raster/r.water.outlet/main.c
use GNAME_MAX, GMAPSET_MAX; some error msg fix
Modified: grass/trunk/raster/r.coin/inter.c
--- grass/trunk/raster/r.coin/inter.c 2008-02-13 06:28:58 UTC (rev 30108)
+++ grass/trunk/raster/r.coin/inter.c 2008-02-13 09:40:48 UTC (rev 30109)
@@ -25,7 +25,7 @@
int cols;
char key;
- char line[128],outname[128],command[1024];
+ char line[128],outname[GNAME_MAX],command[1024];
char ans[80];
setbuf(stderr,NULL);
@@ -37,11 +37,11 @@
mapset1 = G_ask_cell_old("Enter Name of Map Layer 1",map1name);
if(!mapset1)
- exit (0);
+ G_fatal_error (_("Raster map <%s> not found"), map1name);
mapset2 = G_ask_cell_old("Enter Name of Map Layer 2",map2name);
if(!mapset2)
- exit (0);
+ G_fatal_error (_("Raster map <%s> not found"), map2name);
make_coin();
check_report_size();
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2008-02-13 06:28:58 UTC (rev 30108)
+++ grass/trunk/raster/r.in.gdal/main.c 2008-02-13 09:40:48 UTC (rev 30109)
@@ -602,7 +602,7 @@
struct Key_Value *proj_info=NULL, *proj_units=NULL;
char errbuf[256];
int permissions;
- char target_mapset[80];
+ char target_mapset[GMAPSET_MAX];
struct Key_Value *out_proj_info, /* projection information of */
*out_unit_info; /* input and output mapsets */
Modified: grass/trunk/raster/r.quant/global.h
--- grass/trunk/raster/r.quant/global.h 2008-02-13 06:28:58 UTC (rev 30108)
+++ grass/trunk/raster/r.quant/global.h 2008-02-13 09:40:48 UTC (rev 30109)
@@ -3,15 +3,15 @@
struct Quant quant_struct;
CELL old_min, old_max;
DCELL old_dmin, old_dmax;
- char *name[100]; /* input map names */
- char *mapset[100]; /* input mapsets */
+ char *name[GNAME_MAX]; /* input map names */
+ char *mapset[GMAPSET_MAX]; /* input mapsets */
int noi;
#else
extern struct Quant quant_struct;
extern CELL old_min, old_max;
extern DCELL old_dmin, old_dmax;
- extern char *name[100]; /* input map names */
- extern char *mapset[100]; /* input mapsets */
+ extern char *name[GNAME_MAX]; /* input map names */
+ extern char *mapset[GMAPSET_MAX]; /* input mapsets */
extern int noi;
#endif
/* read_rules.c */
Modified: grass/trunk/raster/r.report/parse.c
--- grass/trunk/raster/r.report/parse.c 2008-02-13 06:28:58 UTC (rev 30108)
+++ grass/trunk/raster/r.report/parse.c 2008-02-13 09:40:48 UTC (rev 30109)
@@ -235,8 +235,7 @@
int parse_layer (char *s)
- char msg[100];
- char name[200];
+ char name[GNAME_MAX];
char *mapset;
struct FPRange fp_range;
int n;
@@ -245,9 +244,7 @@
mapset = G_find_cell2 (name, "");
if (mapset == NULL)
G_fatal_error (_("Raster map <%s> not found"), s);
n = nlayers++ ;
layers = (LAYER *)G_realloc(layers, nlayers * sizeof(LAYER));
@@ -261,10 +258,8 @@
if(is_fp[n])
if(G_read_fp_range (name, mapset, &fp_range) < 0)
G_fatal_error (_("Unable to read fp range for raster map <%s>"),
name);
G_get_fp_range_min_max (&fp_range, &DMIN[n], &DMAX[n]);
Modified: grass/trunk/raster/r.transect/main.c
--- grass/trunk/raster/r.transect/main.c 2008-02-13 06:28:58 UTC (rev 30108)
+++ grass/trunk/raster/r.transect/main.c 2008-02-13 09:40:48 UTC (rev 30109)
@@ -33,7 +33,7 @@
int n,err;
int projection;
char *mapset;
- char name[256];
struct GModule *module;
struct
Modified: grass/trunk/raster/r.water.outlet/basin.h
--- grass/trunk/raster/r.water.outlet/basin.h 2008-02-13 06:28:58 UTC (rev 30108)
+++ grass/trunk/raster/r.water.outlet/basin.h 2008-02-13 09:40:48 UTC (rev 30109)
@@ -45,7 +45,7 @@
GLOBAL SHORT updrain[3][3] UPDRAINVAR;
GLOBAL char dr_mod[9] DRVAR ;
GLOBAL char dc_mod[9] DCVAR ;
-GLOBAL char basin_name[80], swale_name[80], half_name[80], elev_name[80], armsed_name[80];
+GLOBAL char basin_name[GNAME_MAX], swale_name[GNAME_MAX], half_name[GNAME_MAX], elev_name[GNAME_MAX], armsed_name[GNAME_MAX];
GLOBAL int nrows, ncols, done, total;
GLOBAL int array_size, high_index, do_index;
GLOBAL char *drain_ptrs, ha_f, el_f, ar_f;
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c 2008-02-13 06:28:58 UTC (rev 30108)
+++ grass/trunk/raster/r.water.outlet/main.c 2008-02-13 09:40:48 UTC (rev 30109)
@@ -35,7 +35,7 @@
double N,E;
int row, col, basin_fd, drain_fd;
CELL *cell_buf;
- char drain_name[80], *drain_mapset, E_f, dr_f, ba_f, N_f, errr;
+ char drain_name[GNAME_MAX], *drain_mapset, E_f, dr_f, ba_f, N_f, errr;
struct Option *opt1, *opt2, *opt3, *opt4;
char *buf;
