[GRASS-SVN] r30118 - grass/trunk/scripts/v.db.addtable
svn_grass at osgeo.org
Wed Feb 13 19:06:42 EST 2008
Author: hamish
Date: 2008-02-13 19:06:42 -0500 (Wed, 13 Feb 2008)
New Revision: 30118
grass/trunk/scripts/v.db.addtable/v.db.addtable
remove @mapset before setting talbe name; quoting
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable
--- grass/trunk/scripts/v.db.addtable/v.db.addtable 2008-02-13 21:54:09 UTC (rev 30117)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable 2008-02-14 00:06:42 UTC (rev 30118)
@@ -87,20 +87,22 @@
if [ ! "$file" ] ; then
g.message -e "Vector map '$GIS_OPT_MAP' not found in current mapset"
exit 1
+else
+ MAP_NAME=`echo "$GIS_OPT_MAP" | cut -f1 -d'@'`
fi
if [ -z "$GIS_OPT_TABLE" ] ; then
if [ $GIS_OPT_LAYER -eq 1 ] ; then
- g.message "Using vector map name as table name: ${GIS_OPT_MAP}"
- table=${GIS_OPT_MAP}
+ g.message "Using vector map name as table name: $MAP_NAME"
+ table="$MAP_NAME"
else
# two avoid tables with identical names on higher layers
- g.message "Using vector map name extended by layer number as table name: ${GIS_OPT_MAP}_$GIS_OPT_LAYER"
- table=${GIS_OPT_MAP}_$GIS_OPT_LAYER
+ g.message "Using vector map name extended by layer number as table name: ${MAP_NAME}_$GIS_OPT_LAYER"
+ table="${MAP_NAME}_$GIS_OPT_LAYER"
fi
else
g.message "Using user specified table name: $GIS_OPT_TABLE"
- table=$GIS_OPT_TABLE
+ table="$GIS_OPT_TABLE"
fi
# we use the DB settings of layer 1 to find out default connection
@@ -125,19 +127,19 @@
fi
else
# there is a definition for layer 1, so we check for the user defined layer
- database=`v.db.connect $GIS_OPT_MAP -g | grep -w $QUERYLAYER | awk '{print $4}'`
+ database=`v.db.connect "$GIS_OPT_MAP" -g | grep -w $QUERYLAYER | awk '{print $4}'`
if [ -z "database" ] ; then
#nothing on user defined layer, so we use the default mapset settings in this case:
database=`db.connect -p | grep database | cut -d':' -f2`
driver=`db.connect -p | grep driver | cut -d':' -f2`
else
- driver=`v.db.connect $GIS_OPT_MAP -g | grep -w $QUERYLAYER | awk '{print $5}'`
+ driver=`v.db.connect "$GIS_OPT_MAP" -g | grep -w $QUERYLAYER | awk '{print $5}'`
fi
fi
#maybe there is already a table linked to the selected layer?
-if [ $GIS_OPT_LAYER -eq 1 ] ; then
- v.db.connect $GIS_OPT_MAP -g 2> /dev/null | grep -w $GIS_OPT_LAYER > /dev/null
+if [ "$GIS_OPT_LAYER" -eq 1 ] ; then
+ v.db.connect "$GIS_OPT_MAP" -g 2> /dev/null | grep -w $GIS_OPT_LAYER > /dev/null
if [ $? -eq 0 ] ; then
g.message -e "There is already a table linked to layer <$GIS_OPT_LAYER>"
exit 1
@@ -162,9 +164,9 @@
# take care if the DBF directory is missing (heck, the DBF driver should take care!)
if [ "$driver" = "dbf" ] ; then
- if test ! -d ${LOCATION}/dbf ; then
- g.message "Creating missing DBF directory in MAPSET <${MAPSET}>"
- mkdir -p ${LOCATION}/dbf
+ if test ! -d "${LOCATION}/dbf" ; then
+ g.message "Creating missing DBF directory in MAPSET <$MAPSET>"
+ mkdir -p "${LOCATION}/dbf"
db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
fi
fi
@@ -177,16 +179,16 @@
fi
# connect the map to the DB:
-v.db.connect map=$GIS_OPT_MAP database=$database driver=$driver layer=$GIS_OPT_LAYER table=$table key=cat
+v.db.connect map="$GIS_OPT_MAP" database=$database driver=$driver layer="$GIS_OPT_LAYER" table=$table key=cat
# finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
# (creates new row for each vector line):
-v.to.db $GIS_OPT_MAP layer=$GIS_OPT_LAYER option=cat col=cat
+v.to.db "$GIS_OPT_MAP" layer=$GIS_OPT_LAYER option=cat col=cat
g.message "Current attribute table links:"
v.db.connect -p $GIS_OPT_MAP
# write cmd history:
-v.support ${GIS_OPT_MAP} cmdhist="${CMDLINE}"
+v.support map="$GIS_OPT_MAP" cmdhist="${CMDLINE}"
exit 0
