[GRASS-SVN] r30124 - grass/trunk/scripts/i.in.spotvgt
svn_grass at osgeo.org
Wed Feb 13 19:36:33 EST 2008
Author: hamish
Date: 2008-02-13 19:36:33 -0500 (Wed, 13 Feb 2008)
New Revision: 30124
grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt
quote variables; --quiet
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt 2008-02-14 00:25:36 UTC (rev 30123)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt 2008-02-14 00:36:33 UTC (rev 30124)
@@ -178,16 +178,16 @@
### create VRT header for NDVI
-PROJFILE=${SPOTDIR}/0001_LOG.TXT
-VRTFILE=$TMPFILE.vrt
+PROJFILE="${SPOTDIR}/0001_LOG.TXT"
+VRTFILE="$TMPFILE.vrt"
# first process the NDVI:
-rm -f $VRTFILE
-create_VRT_file $VRTFILE $GIS_OPT_FILE
+rm -f "$VRTFILE"
+create_VRT_file "$VRTFILE" "$GIS_OPT_FILE"
## let's import the NDVI map...
g.message "Importing SPOT VGT NDVI map..."
-r.in.gdal $VRTFILE output=$NAME
+r.in.gdal "$VRTFILE" output="$NAME"
if [ $? -eq 1 ] ; then
g.message -e "An error occurred. Stop."
exit 1
@@ -207,16 +207,16 @@
# switch to a temporary region
WIND_OVERRIDE=spot_$PID
export WIND_OVERRIDE
-g.region -d 2>&1 >/dev/null
-g.region rast=$NAME 2>&1 >/dev/null
+g.region -d --quiet
+g.region rast="$NAME" --quiet
g.message "Remapping digital numbers to NDVI..."
-r.mapcalc "${NAME}_$PID=0.004 * $NAME - 0.1"
-g.remove rast=$NAME 2>&1 >/dev/null
-g.rename rast=${NAME}_$PID,${NAME} >/dev/null
+r.mapcalc "${NAME}_$PID = 0.004 * $NAME - 0.1"
+g.remove rast="$NAME" --quiet
+g.rename rast="${NAME}_$PID","$NAME" --quiet
#apply color table:
-r.colors ${NAME} color=ndvi 2>&1 >/dev/null
+r.colors "$NAME" color=ndvi --quiet
# second, optionally process the SM quality map:
@@ -248,18 +248,18 @@
if [ $GIS_FLAG_A -eq 1 ] ; then
g.message "Importing SPOT VGT NDVI quality map..."
- rm -f $VRTFILE
- create_VRT_file $VRTFILE `echo ${GIS_OPT_FILE} | sed 's+NDV+SM+g'`
+ rm -f "$VRTFILE"
+ create_VRT_file "$VRTFILE" `echo ${GIS_OPT_FILE} | sed 's+NDV+SM+g'`
## let's import the SM quality map...
- r.in.gdal $VRTFILE output=$NAME.sm
+ r.in.gdal "$VRTFILE" output="$NAME.sm"
exit 1
fi
# some of the possible values:
-r.colors $NAME.sm col=rules << EOF
+r.colors "$NAME.sm" col=rules << EOF
8 50 50 50
11 70 70 70
12 90 90 90
@@ -278,19 +278,19 @@
g.message ""
g.message message="Filtering NDVI map by Status Map quality layer..."
r.mapcalc "${NAME}_filt=if($NAME.sm >= 248, $NAME, null() )"
- r.colors ${NAME}_filt color=ndvi 2>&1 >/dev/null
+ r.colors "${NAME}_filt" color=ndvi --quiet
g.message message="Filtered SPOT VEGETATION NDVI map <${NAME}_filt>."
fi
# remove the temporary region
-g.remove region=spot_$PID 2>&1 >/dev/null
+g.remove region="spot_$PID" --quiet
#### clean up the mess
-rm -f $VRTFILE $TMPFILE
+rm -f "$VRTFILE" "$TMPFILE"
#### end
# write cmd history:
-r.support ${NAME} history="${CMDLINE}"
+r.support "$NAME" history="${CMDLINE}"
g.message "Done."
