[GRASS-SVN] r30129 - grass/trunk/scripts/r.reclass.area
svn_grass at osgeo.org
Wed Feb 13 19:49:42 EST 2008
Author: hamish
Date: 2008-02-13 19:49:42 -0500 (Wed, 13 Feb 2008)
New Revision: 30129
grass/trunk/scripts/r.reclass.area/r.reclass.area
quote variables
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area
--- grass/trunk/scripts/r.reclass.area/r.reclass.area 2008-02-14 00:47:02 UTC (rev 30128)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area 2008-02-14 00:49:42 UTC (rev 30129)
@@ -94,7 +94,7 @@
fi
-file2=$infile.clump.$outfile
+file2="$infile.clump.$outfile"
eval `g.findfile element=cell file=$infile`
filename="${fullname}"
@@ -103,7 +103,7 @@
g.message -e "Raster map [$infile] does not exist."
exit 1
else
- infile=$filename
+ infile="$filename"
fi
eval `g.findfile element=cell file=$file2`
@@ -114,7 +114,7 @@
exit 1
else
g.message "Generating a clumped raster file ..."
- r.clump input=$infile output=$file2
+ r.clump input="$infile" output="$file2"
fi
## calculation in acres
@@ -146,22 +146,22 @@
if test $op = 0; then
g.message "Generating a reclass rules file with area size less than or equal to $limit hectares"
r.stats -aln in=$file2,$infile fs='|' | awk -F'|' '{limit='$limit'; hectares=$5 * 0.0001;
- {if (hectares <= limit) printf("%d = %d %s\n",$1,$3,$4)}}' > $infile.rules
+ {if (hectares <= limit) printf("%d = %d %s\n",$1,$3,$4)}}' > "$infile.rules"
else
g.message "Generating a reclass rules file with area size greater than or equal to $limit hectares"
- {if (hectares >= limit) printf("%d = %d %s\n",$1,$3,$4)}}' > $infile.rules
+ {if (hectares >= limit) printf("%d = %d %s\n",$1,$3,$4)}}' > "$infile.rules"
fi
#fi
if test "$outfile" = ""; then
-outfile=${infile}_${limit}
+ outfile="${infile}_${limit}"
fi
g.message "Generating reclass raster map <$outfile>"
-cat $infile.rules | r.reclass i=$file2 o=$outfile.recl
+cat "$infile.rules" | r.reclass i="$file2" o="$outfile.recl"
r.mapcalc "$outfile=$outfile.recl"
g.message "Written: $outfile"
-g.remove rast=$outfile.recl,$file2 > /dev/null 2> /dev/null
+g.remove rast="$outfile.recl","$file2" --quiet
#####cleanup
-rm -f $infile.rules
+rm -f "$infile.rules"
