[GRASS-SVN] r30135 - grass/trunk/scripts/v.univar.sh
Wed Feb 13 20:10:26 EST 2008
Author: hamish
Date: 2008-02-13 20:10:26 -0500 (Wed, 13 Feb 2008)
New Revision: 30135
   grass/trunk/scripts/v.univar.sh/v.univar.sh
quote variables
Modified: grass/trunk/scripts/v.univar.sh/v.univar.sh
--- grass/trunk/scripts/v.univar.sh/v.univar.sh	2008-02-14 01:07:13 UTC (rev 30134)
+++ grass/trunk/scripts/v.univar.sh/v.univar.sh	2008-02-14 01:10:26 UTC (rev 30135)
@@ -88,7 +88,7 @@
 cleanup()
- \rm -f $TMP $TMP.sort
+   \rm -f "$TMP" "$TMP.sort"
 # what to do in case of user break:
@@ -118,9 +118,9 @@
 fi
 if [ -z "$GIS_OPT_WHERE" ] ; then
-   db.select table=$GIS_OPT_TABLE $db $drv sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE" -c > "$TMP"
+   db.select table="$GIS_OPT_TABLE" $db $drv sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE" -c > "$TMP"
 else
-   db.select table=$GIS_OPT_TABLE $db $drv sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE WHERE $GIS_OPT_WHERE" -c > "$TMP"
+   db.select table="$GIS_OPT_TABLE" $db $drv sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE WHERE $GIS_OPT_WHERE" -c > "$TMP"
 fi
@@ -142,7 +142,7 @@
 # calculate statistics
 g.message "Calculating statistics..."
-cat $TMP | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0; min = 10e10 ; max = -min}
+cat "$TMP" | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0; min = 10e10 ; max = -min}
 function abs(x){return x < 0 ? -x : x}
 (NF>0) {
 	sum += $1 ; sum2 += $1 * $1 ; sum3 += abs($1) ; N++;
@@ -170,9 +170,9 @@
 if [ $GIS_FLAG_E -eq 1 ] ; then
   #preparations:
-  cat $TMP | sort -n > $TMP.sort
-  NUMBER=`cat $TMP.sort | wc -l | awk '{print $1}'`
-  ODDEVEN=`echo $NUMBER | awk '{print $1%2}'`
+  cat "$TMP" | sort -n > $TMP.sort
+  NUMBER=`cat "$TMP.sort" | wc -l | awk '{print $1}'`
+  ODDEVEN=`echo "$NUMBER" | awk '{print $1%2}'`
   # 0.25 quartile
   QUARTILE=0.25
