[GRASS-SVN] r30138 -
grass/branches/releasebranch_6_3/scripts/i.landsat.rgb
svn_grass at osgeo.org
Thu Feb 14 00:18:53 EST 2008
Author: hamish
Date: 2008-02-14 00:18:53 -0500 (Thu, 14 Feb 2008)
New Revision: 30138
grass/branches/releasebranch_6_3/scripts/i.landsat.rgb/i.landsat.rgb
work with FP input maps (merge from Trunk)
Modified: grass/branches/releasebranch_6_3/scripts/i.landsat.rgb/i.landsat.rgb
--- grass/branches/releasebranch_6_3/scripts/i.landsat.rgb/i.landsat.rgb 2008-02-14 05:09:56 UTC (rev 30137)
+++ grass/branches/releasebranch_6_3/scripts/i.landsat.rgb/i.landsat.rgb 2008-02-14 05:18:53 UTC (rev 30138)
@@ -81,7 +81,13 @@
exec g.parser "$0" "$@"
fi
-# setting environment, so that awk works properly in all languages (unused?)
+# check if we have awk
+if [ ! -x "`which awk`" ] ; then
+ g.message -e "awk required, please install awk or gawk first"
+ exit 1
+fi
+# setting environment, so that awk works properly in all languages
unset LC_ALL
LC_NUMERIC=C
export LC_NUMERIC
@@ -116,10 +122,10 @@
if [ 0 -eq $GIS_FLAG_P ] ; then
for i in $RED $GREEN $BLUE ; do
- g.message "Processing [$i] .."
+ g.message "Processing <$i> ..."
MIN=`r.univar -ge $i perc=2 | grep "^percentile_" | cut -d'=' -f2`
MAX=`r.univar -ge $i perc=$BRIGHTNESS | grep "^percentile_" | cut -d'=' -f2`
- #echo "[$i]: min=$MIN max=$MAX"
+ g.message -d message="<$i>: min=$MIN max=$MAX"
r.colors $i col=rules << EOF
0% black
$MIN black
@@ -131,18 +137,14 @@
ALL_MAX=0
ALL_MIN=255
- if [ $MAX -gt $ALL_MAX ] ; then
- ALL_MAX=$MAX
- fi
- if [ $MIN -lt $ALL_MIN ] ; then
- ALL_MIN=$MIN
- fi
+ ALL_MAX=`echo "$MAX $ALL_MAX" | awk '{if ($1 > $2) print $1; else print $2}'`
+ ALL_MIN=`echo "$MIN $ALL_MIN" | awk '{if ($1 < $2) print $1; else print $2}'`
done
- #echo "all_min=$ALL_MIN all_max=$ALL_MAX"
+ g.message -d message="all_min=$ALL_MIN all_max=$ALL_MAX"
0% black
