[GRASS-SVN] r30143 - grass-addons/imagery/i.warp
Thu Feb 14 01:32:00 EST 2008
Author: hamish
Date: 2008-02-14 01:32:00 -0500 (Thu, 14 Feb 2008)
New Revision: 30143
Removed:
   grass-addons/imagery/i.warp/i.warp61
rename i.warp addon script
Deleted: grass-addons/imagery/i.warp/i.warp61
--- grass-addons/imagery/i.warp/i.warp61	2008-02-14 06:00:53 UTC (rev 30142)
+++ grass-addons/imagery/i.warp/i.warp61	2008-02-14 06:32:00 UTC (rev 30143)
@@ -1,130 +0,0 @@
-#!/bin/sh
-# MODULE:       i.warp
-# AUTHOR(S):    Hamish Bowman
-#               Department of Marine Science
-#               Otago University, New Zealand
-#               3 June 2005
-# PURPOSE:      Use GCPs from i.points to run gdalwarp using splines
-# COPYRIGHT:    (c) Hamish Bowman
-# REQUIREMENTS:
-#       gdalwarp from the GDAL package.   http://www.gdal.org
-#     xx  GRASS 6.1-cvs newer than 1 June 2005
-#%Module
-#%  description: Georectify an image using thin plate splines
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old_file,file,input
-#% description: Name of input image (JPEG, TIFF, etc.)
-#% required : yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new_file,file,output
-#% description: Name for georeferenced and warped GeoTIFF
-#% required : yes
-#%end
-#%option
-#% key: group
-#% type: string
-#% gisprompt: old,group,group
-#% description: Name of imagery group containing GCPs
-#% required : yes
-#%end
-if [ -z "$GISBASE" ] ; then
-   echo "You must be in GRASS GIS to run this program." >&2
-   exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-   exec g.parser "$0" "$@"
-fi
-#### check if we have awk
-if [ ! -x "`which awk`" ] ; then
-    echo "$PROG: awk required, please install awk or gawk first" 1>&2
-    exit 1
-fi
-# set environment so that awk works properly in all languages
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-INFILE="$GIS_OPT_input"
-OUTFILE="`basename $GIS_OPT_output .tif`.tif"
-GROUP="$GIS_OPT_group"
-if [ ! -e "$INFILE" ] ; then
-    echo "ERROR: unable to read input file." 1>&2
-    exit 1
-fi
-if [ -e "$OUTFILE" ] ; then
-    echo "ERROR: output file already exists." 1>&2
-    exit 1
-fi
-eval `g.filename elem=group file=${GROUP}/POINTS`
-POINTS_FILE="$file"
-if [ ! -e "$POINTS_FILE" ] ; then
-    echo "ERROR: unable to read POINTS file. Run i.points first." 1>&2
-    exit 1
-fi
-#### setup temporary file
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
-    echo "ERROR: unable to create temporary files" 1>&2
-    exit 1
-fi
-DIMS="`gdalinfo "$INFILE" | grep '^Lower Right' | cut -f2 -d'(' | \
-    cut -f1 -d')' |  tr ',' ' '`"
-WIDTH="`echo $DIMS | cut -f1 -d' '`"
-HEIGHT="`echo $DIMS | cut -f2 -d' '`"
-## BUG: GCPs need to be sorted top to bottom!!  (??????)
-GDAL_GCP="`cat "$POINTS_FILE" | grep -v '^#'| grep -v '0$' | sort -n -r --key=2 | \
-    awk -v hgt=$HEIGHT -v wth=$WIDTH \
-      '{printf("-gcp %.3f %.3f %f %f ", $1, hgt - $2, $3, $4)}'`"
-echo $GDAL_GCP | sed -e 's/-gcp/\ngcp/g' -e 's/ /\t/g'
-echo
-echo "Adding GCPs ..."
-gdal_translate $GDAL_GCP "$INFILE" "$TMP".tif
-sleep 1
-echo "Rectifying ..."
-## BUG: outfile name needs to be at least 20 chars long!!
-gdalwarp -tps -rcs -co compress=lzw "$TMP".tif "$OUTFILE"_warp_warp_warp_warp
-#gdalwarp -tps -rcs -co compress=lzw -srcnodata 255 -dstnodata 255 "$TMP".tif "$OUTFILE"_warp_warp_warp_warp
-sleep 1
-mv "$OUTFILE"_warp_warp_warp_warp "$OUTFILE"
-rm -f "$TMP".tif "$TMP"
-echo "Done!"
-echo ""
-echo "In target location:  r.in.gdal -o input=$OUTFILE output=`basename $OUTFILE .tif`"
