[GRASS-SVN] r30171 - in grass/trunk: . include/Make
svn_grass at osgeo.org
Fri Feb 15 16:27:05 EST 2008
Author: martinl
Date: 2008-02-15 16:27:04 -0500 (Fri, 15 Feb 2008)
New Revision: 30171
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/Make/Platform.make.in
configure: #38
* switch for wxWidgets (--with-wxwidgets) added
* --with-python check rewritten
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-02-15 19:43:12 UTC (rev 30170)
+++ grass/trunk/configure 2008-02-15 21:27:04 UTC (rev 30171)
@@ -67,8 +67,12 @@
ac_help="$ac_help
--with-curses support Curses functionality (default: yes)"
ac_help="$ac_help
- --with-python support PYTHON functionality (default: no)"
+ --with-python[=path/python-config] enable Python support (python-config with path, \
+e.g. '--with-python=/usr/bin/python2.5-config', default: no)"
ac_help="$ac_help
+ --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
+e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)"
+ac_help="$ac_help
--with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
e.g. '--with-gdal=/usr/local/bin/gdal-config')"
ac_help="$ac_help
@@ -717,7 +721,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:721: checking host system type" >&5
+echo "configure:725: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -740,7 +744,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:744: checking for $ac_word" >&5
+echo "configure:748: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -767,7 +771,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:771: checking for $ac_word" >&5
+echo "configure:775: checking for $ac_word" >&5
@@ -815,7 +819,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:819: checking for $ac_word" >&5
+echo "configure:823: checking for $ac_word" >&5
@@ -844,7 +848,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:848: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:852: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -855,12 +859,12 @@
cat > conftest.$ac_ext << EOF
-#line 859 "configure"
+#line 863 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -886,19 +890,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:890: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:894: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:895: checking whether we are using GNU C" >&5
+echo "configure:899: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:902: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:906: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -916,7 +920,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:920: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:924: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -945,10 +949,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:949: checking for Cygwin environment" >&5
+echo "configure:953: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 952 "configure"
+#line 956 "configure"
int main() {
@@ -959,7 +963,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:963: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:967: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -975,17 +979,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:979: checking for mingw32 environment" >&5
+echo "configure:983: checking for mingw32 environment" >&5
-#line 982 "configure"
+#line 986 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:993: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1003,7 +1007,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1007: checking for executable suffix" >&5
+echo "configure:1011: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1011,10 +1015,10 @@
rm -f conftest*
echo 'int main () { return 0; }' > conftest.$ac_ext
ac_cv_exeext=
- if { (eval echo configure:1015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
+ if { (eval echo configure:1019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
for file in conftest.*; do
case $file in
- *.c | *.o | *.obj) ;;
+ *.$ac_ext | *.c | *.o | *.obj) ;;
*) ac_cv_exeext=`echo $file | sed -e s/conftest//` ;;
esac
done
@@ -1036,23 +1040,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1040: checking for full floating-point support" >&5
+echo "configure:1044: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1045: checking whether "cc -mieee" works" >&5
+echo "configure:1049: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1049 "configure"
+#line 1053 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1068,7 +1072,7 @@
else
-#line 1072 "configure"
+#line 1076 "configure"
#include <float.h>
@@ -1082,7 +1086,7 @@
EOF
-if { (eval echo configure:1086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1095,14 +1099,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1099: checking for full floating-point support with -mieee" >&5
+echo "configure:1103: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1106 "configure"
+#line 1110 "configure"
#include <float.h>
@@ -1116,7 +1120,7 @@
EOF
-if { (eval echo configure:1120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1153,7 +1157,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1157: checking for $ac_word" >&5
+echo "configure:1161: checking for $ac_word" >&5
case "$pwd" in
@@ -1191,7 +1195,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1195: checking for source directory" >&5
+echo "configure:1199: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1202,7 +1206,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1206: checking for build directory" >&5
+echo "configure:1210: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1265,7 +1269,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1269: checking for MacOSX App" >&5
+echo "configure:1273: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1288,7 +1292,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1292: checking how to build libraries" >&5
+echo "configure:1296: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1331,7 +1335,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1335: checking for $ac_word" >&5
+echo "configure:1339: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1356,7 +1360,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1360: checking how to run the C preprocessor" >&5
+echo "configure:1364: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1369,13 +1373,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1373 "configure"
+#line 1377 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1383: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1386,13 +1390,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1390 "configure"
+#line 1394 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1396: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1400: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1403,13 +1407,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1407 "configure"
+#line 1411 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1437,7 +1441,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1441: checking if 64bit support is requested" >&5
+echo "configure:1445: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1457,7 +1461,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1461: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1465: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1481,7 +1485,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1485: checking system version (for dynamic loading)" >&5
+echo "configure:1489: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1507,13 +1511,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1511: checking for dlopen in -ldl" >&5
+echo "configure:1515: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1517 "configure"
+#line 1521 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1524,7 +1528,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1571,7 +1575,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1575: checking for $ac_word" >&5
+echo "configure:1579: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1700,13 +1704,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1704: checking for gettimeofday in -lbsd" >&5
+echo "configure:1708: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1710 "configure"
+#line 1714 "configure"
@@ -1717,7 +1721,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1758,13 +1762,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1762: checking for inet_ntoa in -lbind" >&5
+echo "configure:1766: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1768 "configure"
+#line 1772 "configure"
@@ -1775,7 +1779,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1836,13 +1840,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1840: checking for shl_load in -ldld" >&5
+echo "configure:1844: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1846 "configure"
+#line 1850 "configure"
@@ -1853,7 +1857,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1918,13 +1922,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1922: checking for shl_load in -ldld" >&5
+echo "configure:1926: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1928 "configure"
+#line 1932 "configure"
@@ -1935,7 +1939,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2057,15 +2061,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2061: checking for dld.h" >&5
+echo "configure:2065: checking for dld.h" >&5
-#line 2064 "configure"
+#line 2068 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2125,15 +2129,15 @@
else
-echo "configure:2129: checking for dld.h" >&5
+echo "configure:2133: checking for dld.h" >&5
-#line 2132 "configure"
+#line 2136 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2230,9 +2234,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2234: checking for ELF" >&5
+echo "configure:2238: checking for ELF" >&5
-#line 2236 "configure"
+#line 2240 "configure"
#ifdef __ELF__
@@ -2262,15 +2266,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2266: checking for dlfcn.h" >&5
+echo "configure:2270: checking for dlfcn.h" >&5
-#line 2269 "configure"
+#line 2273 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2274: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2294,9 +2298,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2298: checking for ELF" >&5
+echo "configure:2302: checking for ELF" >&5
-#line 2300 "configure"
+#line 2304 "configure"
#ifdef __ELF__
@@ -2620,17 +2624,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2624: checking for ld accepts -Bexport flag" >&5
+echo "configure:2628: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2627 "configure"
+#line 2631 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -2978,15 +2982,21 @@
fi
# Check whether --with-python or --without-python was given.
if test "${with_python+set}" = set; then
withval="$with_python"
else
- with_python=no
+ with_python="no"
fi
+# Check whether --with-wxwidgets or --without-wxwidgets was given.
+if test "${with_wxwidgets+set}" = set; then
+ withval="$with_wxwidgets"
+else
+ with_wxwidgets="no"
+fi
# With includes and libs options
@@ -3369,7 +3379,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3373: checking for additional include dirs" >&5
+echo "configure:3383: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3392,7 +3402,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3396: checking for additional library dirs" >&5
+echo "configure:3406: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3426,7 +3436,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3430: checking for a BSD compatible install" >&5
+echo "configure:3440: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3479,7 +3489,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3483: checking for $ac_word" >&5
+echo "configure:3493: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3510,13 +3520,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3514: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3524: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3520 "configure"
+#line 3530 "configure"
@@ -3527,7 +3537,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3552,7 +3562,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3556: checking for $ac_word" >&5
+echo "configure:3566: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3592,7 +3602,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3596: checking for $ac_word" >&5
+echo "configure:3606: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3623,7 +3633,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3627: checking for $ac_word" >&5
+echo "configure:3637: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3661,7 +3671,7 @@
-echo "configure:3665: checking for $ac_word" >&5
+echo "configure:3675: checking for $ac_word" >&5
@@ -3690,7 +3700,7 @@
-echo "configure:3694: checking for $ac_word" >&5
+echo "configure:3704: checking for $ac_word" >&5
@@ -3721,7 +3731,7 @@
-echo "configure:3725: checking for $ac_word" >&5
+echo "configure:3735: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3750,7 +3760,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3754: checking for $ac_word" >&5
+echo "configure:3764: checking for $ac_word" >&5
case "$PERL" in
@@ -3781,10 +3791,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3785: checking for ANSI C header files" >&5
+echo "configure:3795: checking for ANSI C header files" >&5
-#line 3788 "configure"
+#line 3798 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3792,7 +3802,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3806: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3809,7 +3819,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3813 "configure"
+#line 3823 "configure"
#include <string.h>
EOF
@@ -3827,7 +3837,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3831 "configure"
+#line 3841 "configure"
#include <stdlib.h>
EOF
@@ -3848,7 +3858,7 @@
else
-#line 3852 "configure"
+#line 3862 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3859,7 +3869,7 @@
exit (0); }
EOF
-if { (eval echo configure:3863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3886,15 +3896,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3890: checking for $ac_hdr" >&5
+echo "configure:3900: checking for $ac_hdr" >&5
-#line 3893 "configure"
+#line 3903 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3898: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3908: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3923,15 +3933,15 @@
do
-echo "configure:3927: checking for $ac_hdr" >&5
+echo "configure:3937: checking for $ac_hdr" >&5
-#line 3930 "configure"
+#line 3940 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3945: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3960,15 +3970,15 @@
do
-echo "configure:3964: checking for $ac_hdr" >&5
+echo "configure:3974: checking for $ac_hdr" >&5
-#line 3967 "configure"
+#line 3977 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3972: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3982: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3997,15 +4007,15 @@
do
-echo "configure:4001: checking for $ac_hdr" >&5
+echo "configure:4011: checking for $ac_hdr" >&5
-#line 4004 "configure"
+#line 4014 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4019: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4034,15 +4044,15 @@
do
-echo "configure:4038: checking for $ac_hdr" >&5
+echo "configure:4048: checking for $ac_hdr" >&5
-#line 4041 "configure"
+#line 4051 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4056: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4068,10 +4078,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4072: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4082: checking whether time.h and sys/time.h may both be included" >&5
-#line 4075 "configure"
+#line 4085 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4080,7 +4090,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4094: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4100,10 +4110,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4104: checking for off_t" >&5
+echo "configure:4114: checking for off_t" >&5
-#line 4107 "configure"
+#line 4117 "configure"
#if STDC_HEADERS
@@ -4130,10 +4140,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4134: checking for uid_t in sys/types.h" >&5
+echo "configure:4144: checking for uid_t in sys/types.h" >&5
-#line 4137 "configure"
+#line 4147 "configure"
EOF
@@ -4161,10 +4171,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4165: checking return type of signal handlers" >&5
+echo "configure:4175: checking return type of signal handlers" >&5
-#line 4168 "configure"
+#line 4178 "configure"
#include <signal.h>
@@ -4181,7 +4191,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4185: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4195: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4199,10 +4209,10 @@
-echo "configure:4203: checking for Cygwin environment" >&5
+echo "configure:4213: checking for Cygwin environment" >&5
-#line 4206 "configure"
+#line 4216 "configure"
int main() {
@@ -4213,7 +4223,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4217: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4227: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4231,10 +4241,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4235: checking for $ac_func" >&5
+echo "configure:4245: checking for $ac_func" >&5
-#line 4238 "configure"
+#line 4248 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4257,7 +4267,7 @@
; return 0; }
EOF
-if { (eval echo configure:4261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4283,10 +4293,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4287: checking for $ac_func" >&5
+echo "configure:4297: checking for $ac_func" >&5
-#line 4290 "configure"
+#line 4300 "configure"
@@ -4309,7 +4319,7 @@
; return 0; }
EOF
-if { (eval echo configure:4313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4335,10 +4345,10 @@
for ac_func in drand48
do
-echo "configure:4339: checking for $ac_func" >&5
+echo "configure:4349: checking for $ac_func" >&5
-#line 4342 "configure"
+#line 4352 "configure"
@@ -4361,7 +4371,7 @@
; return 0; }
EOF
-if { (eval echo configure:4365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4387,10 +4397,10 @@
for ac_func in putenv setenv
do
-echo "configure:4391: checking for $ac_func" >&5
+echo "configure:4401: checking for $ac_func" >&5
-#line 4394 "configure"
+#line 4404 "configure"
@@ -4413,7 +4423,7 @@
; return 0; }
EOF
-if { (eval echo configure:4417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4439,10 +4449,10 @@
for ac_func in nanosleep
do
-echo "configure:4443: checking for $ac_func" >&5
+echo "configure:4453: checking for $ac_func" >&5
-#line 4446 "configure"
+#line 4456 "configure"
@@ -4465,7 +4475,7 @@
; return 0; }
EOF
-if { (eval echo configure:4469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4490,13 +4500,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4494: checking whether setpgrp takes no argument" >&5
+echo "configure:4504: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4500 "configure"
+#line 4510 "configure"
#ifdef HAVE_UNISTD_H
@@ -4516,7 +4526,7 @@
EOF
-if { (eval echo configure:4520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4544,16 +4554,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4548: checking for long long int" >&5
+echo "configure:4558: checking for long long int" >&5
-#line 4550 "configure"
+#line 4560 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4557: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4567: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4573,7 +4583,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4577: checking for W11" >&5
+echo "configure:4587: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4601,7 +4611,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4605: checking for X" >&5
+echo "configure:4615: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4661,12 +4671,12 @@
# First, try using that file with no special directory specified.
-#line 4665 "configure"
+#line 4675 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4680: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4735,14 +4745,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4739 "configure"
+#line 4749 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4847,17 +4857,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4851: checking whether -R must be followed by a space" >&5
+echo "configure:4861: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4854 "configure"
+#line 4864 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4873,14 +4883,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4877 "configure"
+#line 4887 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4912,13 +4922,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4916: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4926: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4922 "configure"
+#line 4932 "configure"
@@ -4929,7 +4939,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4950,13 +4960,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4954: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4964: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4960 "configure"
+#line 4970 "configure"
@@ -4967,7 +4977,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4995,10 +5005,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4999: checking for gethostbyname" >&5
+echo "configure:5009: checking for gethostbyname" >&5
-#line 5002 "configure"
+#line 5012 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5021,7 +5031,7 @@
; return 0; }
EOF
-if { (eval echo configure:5025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5041,13 +5051,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5045: checking for gethostbyname in -lnsl" >&5
+echo "configure:5055: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5051 "configure"
+#line 5061 "configure"
@@ -5058,7 +5068,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5087,10 +5097,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5091: checking for connect" >&5
+echo "configure:5101: checking for connect" >&5
-#line 5094 "configure"
+#line 5104 "configure"
which can conflict with char connect(); below. */
@@ -5113,7 +5123,7 @@
; return 0; }
EOF
-if { (eval echo configure:5117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5133,13 +5143,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5137: checking for connect in -lsocket" >&5
+echo "configure:5147: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5143 "configure"
+#line 5153 "configure"
@@ -5150,7 +5160,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5173,10 +5183,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5177: checking for remove" >&5
+echo "configure:5187: checking for remove" >&5
-#line 5180 "configure"
+#line 5190 "configure"
which can conflict with char remove(); below. */
@@ -5199,7 +5209,7 @@
; return 0; }
EOF
-if { (eval echo configure:5203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5219,13 +5229,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5223: checking for remove in -lposix" >&5
+echo "configure:5233: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5229 "configure"
+#line 5239 "configure"
@@ -5236,7 +5246,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5259,10 +5269,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5263: checking for shmat" >&5
+echo "configure:5273: checking for shmat" >&5
-#line 5266 "configure"
+#line 5276 "configure"
which can conflict with char shmat(); below. */
@@ -5285,7 +5295,7 @@
; return 0; }
EOF
-if { (eval echo configure:5289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5305,13 +5315,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5309: checking for shmat in -lipc" >&5
+echo "configure:5319: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5315 "configure"
+#line 5325 "configure"
@@ -5322,7 +5332,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5354,13 +5364,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5358: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5368: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5364 "configure"
+#line 5374 "configure"
@@ -5371,7 +5381,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5409,7 +5419,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5413: checking whether to use Curses" >&5
+echo "configure:5423: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5428,15 +5438,15 @@
do
-echo "configure:5432: checking for $ac_hdr" >&5
+echo "configure:5442: checking for $ac_hdr" >&5
-#line 5435 "configure"
+#line 5445 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5467,10 +5477,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5471: checking curses.h WINDOW structure component" >&5
+echo "configure:5481: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5474 "configure"
+#line 5484 "configure"
#include <curses.h>
@@ -5479,7 +5489,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5483: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5493: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5488,7 +5498,7 @@
fi
rm -f conftest*
-#line 5492 "configure"
+#line 5502 "configure"
#include <curses.h>
@@ -5497,7 +5507,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5511: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5513,13 +5523,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5517: checking for initscr in -lncurses" >&5
+echo "configure:5527: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5523 "configure"
+#line 5533 "configure"
@@ -5530,7 +5540,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5549,13 +5559,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5553: checking for initscr in -lcurses" >&5
+echo "configure:5563: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5559 "configure"
+#line 5569 "configure"
@@ -5566,7 +5576,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5595,13 +5605,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5599: checking for keypad in -lncurses" >&5
+echo "configure:5609: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5605 "configure"
+#line 5615 "configure"
@@ -5612,7 +5622,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5634,13 +5644,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5638: checking for keypad in -lcurses" >&5
+echo "configure:5648: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5644 "configure"
+#line 5654 "configure"
@@ -5651,7 +5661,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5681,13 +5691,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5685: checking for gtty in -lcompat" >&5
+echo "configure:5695: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5691 "configure"
+#line 5701 "configure"
@@ -5698,7 +5708,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5717,13 +5727,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5721: checking for gtty in -lbsd-compat" >&5
+echo "configure:5731: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5727 "configure"
+#line 5737 "configure"
@@ -5734,7 +5744,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5753,13 +5763,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5757: checking for gtty in -lbsd" >&5
+echo "configure:5767: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5763 "configure"
+#line 5773 "configure"
@@ -5770,7 +5780,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5804,12 +5814,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5808: checking for library containing cuserid" >&5
+echo "configure:5818: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5813 "configure"
+#line 5823 "configure"
@@ -5820,7 +5830,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5831,7 +5841,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5835 "configure"
+#line 5845 "configure"
@@ -5842,7 +5852,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5868,10 +5878,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5872: checking for xdrmem_create" >&5
+echo "configure:5882: checking for xdrmem_create" >&5
-#line 5875 "configure"
+#line 5885 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5894,7 +5904,7 @@
; return 0; }
EOF
-if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5912,13 +5922,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5916: checking for xdrmem_create in -lsun" >&5
+echo "configure:5926: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5922 "configure"
+#line 5932 "configure"
@@ -5929,7 +5939,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5948,13 +5958,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5952: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5962: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5958 "configure"
+#line 5968 "configure"
@@ -5965,7 +5975,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5984,13 +5994,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5988: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5998: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 5994 "configure"
+#line 6004 "configure"
@@ -6001,7 +6011,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6020,13 +6030,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6024: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6034: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6030 "configure"
+#line 6040 "configure"
@@ -6037,7 +6047,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6071,10 +6081,10 @@
for ac_func in asprintf
do
-echo "configure:6075: checking for $ac_func" >&5
+echo "configure:6085: checking for $ac_func" >&5
-#line 6078 "configure"
+#line 6088 "configure"
@@ -6097,7 +6107,7 @@
; return 0; }
EOF
-if { (eval echo configure:6101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6124,10 +6134,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6128: checking for atan" >&5
+echo "configure:6138: checking for atan" >&5
-#line 6131 "configure"
+#line 6141 "configure"
which can conflict with char atan(); below. */
@@ -6150,7 +6160,7 @@
; return 0; }
EOF
-if { (eval echo configure:6154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6168,13 +6178,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6172: checking for atan in -lm" >&5
+echo "configure:6182: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6178 "configure"
+#line 6188 "configure"
@@ -6185,7 +6195,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6212,10 +6222,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6216: checking for dlsym" >&5
+echo "configure:6226: checking for dlsym" >&5
-#line 6219 "configure"
+#line 6229 "configure"
which can conflict with char dlsym(); below. */
@@ -6238,7 +6248,7 @@
; return 0; }
EOF
-if { (eval echo configure:6242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6256,13 +6266,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6260: checking for dlsym in -ldl" >&5
+echo "configure:6270: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6266 "configure"
+#line 6276 "configure"
@@ -6273,7 +6283,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6300,10 +6310,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6304: checking for iconv" >&5
+echo "configure:6314: checking for iconv" >&5
-#line 6307 "configure"
+#line 6317 "configure"
which can conflict with char iconv(); below. */
@@ -6326,7 +6336,7 @@
; return 0; }
EOF
-if { (eval echo configure:6330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6344,13 +6354,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6348: checking for iconv in -liconv" >&5
+echo "configure:6358: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6354 "configure"
+#line 6364 "configure"
@@ -6361,7 +6371,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6380,13 +6390,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6384: checking for iconv in -lgiconv" >&5
+echo "configure:6394: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6390 "configure"
+#line 6400 "configure"
@@ -6397,7 +6407,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6416,10 +6426,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6420: checking for libiconv" >&5
+echo "configure:6430: checking for libiconv" >&5
-#line 6423 "configure"
+#line 6433 "configure"
which can conflict with char libiconv(); below. */
@@ -6442,7 +6452,7 @@
; return 0; }
EOF
-if { (eval echo configure:6446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6460,13 +6470,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6464: checking for libiconv in -liconv" >&5
+echo "configure:6474: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6470 "configure"
+#line 6480 "configure"
@@ -6477,7 +6487,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6496,13 +6506,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6500: checking for libiconv in -lgiconv" >&5
+echo "configure:6510: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6506 "configure"
+#line 6516 "configure"
@@ -6513,7 +6523,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6550,10 +6560,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6554: checking for socket" >&5
+echo "configure:6564: checking for socket" >&5
-#line 6557 "configure"
+#line 6567 "configure"
which can conflict with char socket(); below. */
@@ -6576,7 +6586,7 @@
; return 0; }
EOF
-if { (eval echo configure:6580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6594,13 +6604,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6598: checking for socket in -lsocket" >&5
+echo "configure:6608: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6604 "configure"
+#line 6614 "configure"
@@ -6611,7 +6621,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6659,7 +6669,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6663: checking for location of zlib includes" >&5
+echo "configure:6673: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6685,15 +6695,15 @@
do
-echo "configure:6689: checking for $ac_hdr" >&5
+echo "configure:6699: checking for $ac_hdr" >&5
-#line 6692 "configure"
+#line 6702 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6727,7 +6737,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6731: checking for location of zlib library" >&5
+echo "configure:6741: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6752,13 +6762,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6756: checking for deflate in -lz" >&5
+echo "configure:6766: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6762 "configure"
+#line 6772 "configure"
@@ -6769,7 +6779,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6817,7 +6827,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6821: checking for location of External PROJ.4 includes" >&5
+echo "configure:6831: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6843,15 +6853,15 @@
do
-echo "configure:6847: checking for $ac_hdr" >&5
+echo "configure:6857: checking for $ac_hdr" >&5
-#line 6850 "configure"
+#line 6860 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6865: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6888,7 +6898,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6892: checking External PROJ.4 version" >&5
+echo "configure:6902: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6896,7 +6906,7 @@
else
-#line 6900 "configure"
+#line 6910 "configure"
#include <stdio.h>
@@ -6908,7 +6918,7 @@
EOF
-if { (eval echo configure:6912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6933,7 +6943,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6937: checking for location of External PROJ.4 library" >&5
+echo "configure:6947: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6958,13 +6968,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6962: checking for pj_get_def in -lproj" >&5
+echo "configure:6972: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 6968 "configure"
+#line 6978 "configure"
@@ -6975,7 +6985,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7009,7 +7019,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7013: checking for location of External PROJ.4 data files" >&5
+echo "configure:7023: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7033,14 +7043,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7037: checking for epsg" >&5
+echo "configure:7047: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7044: checking for $PROJSHARE/epsg" >&5
+echo "configure:7054: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7072,7 +7082,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7076: checking for $ac_word" >&5
+echo "configure:7086: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7112,7 +7122,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7116: checking whether to use Readline" >&5
+echo "configure:7126: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7133,7 +7143,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7137: checking for location of Readline includes" >&5
+echo "configure:7147: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7159,15 +7169,15 @@
do
-echo "configure:7163: checking for $ac_hdr" >&5
+echo "configure:7173: checking for $ac_hdr" >&5
-#line 7166 "configure"
+#line 7176 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7171: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7203,15 +7213,15 @@
do
-echo "configure:7207: checking for $ac_hdr" >&5
+echo "configure:7217: checking for $ac_hdr" >&5
-#line 7210 "configure"
+#line 7220 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7225: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7245,7 +7255,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7249: checking for location of Readline library" >&5
+echo "configure:7259: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7270,13 +7280,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7274: checking for readline in -lreadline" >&5
+echo "configure:7284: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7280 "configure"
+#line 7290 "configure"
@@ -7287,7 +7297,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7322,13 +7332,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7326: checking for add_history in -lhistory" >&5
+echo "configure:7336: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7332 "configure"
+#line 7342 "configure"
@@ -7339,7 +7349,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7382,7 +7392,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7386: checking whether to use JPEG" >&5
+echo "configure:7396: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7402,7 +7412,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7406: checking for location of JPEG includes" >&5
+echo "configure:7416: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7428,15 +7438,15 @@
do
-echo "configure:7432: checking for $ac_hdr" >&5
+echo "configure:7442: checking for $ac_hdr" >&5
-#line 7435 "configure"
+#line 7445 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7470,7 +7480,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7474: checking for location of JPEG library" >&5
+echo "configure:7484: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7497,13 +7507,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7501: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7511: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 7507 "configure"
+#line 7517 "configure"
@@ -7514,7 +7524,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7533,13 +7543,13 @@
-echo "configure:7537: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7547: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7543 "configure"
+#line 7553 "configure"
@@ -7550,7 +7560,7 @@
; return 0; }
EOF
-if { (eval echo configure:7554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7599,7 +7609,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7603: checking whether to use GDAL" >&5
+echo "configure:7613: checking whether to use GDAL" >&5
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
GDAL_CONFIG="$with_gdal"
@@ -7612,7 +7622,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:7616: checking for $ac_word" >&5
+echo "configure:7626: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7670,10 +7680,10 @@
ac_save_libs="$LIBS"
LIBS="$LIBS $GDAL_LIBS"
echo $ac_n "checking for GDALOpen""... $ac_c" 1>&6
-echo "configure:7674: checking for GDALOpen" >&5
+echo "configure:7684: checking for GDALOpen" >&5
-#line 7677 "configure"
+#line 7687 "configure"
which can conflict with char GDALOpen(); below. */
@@ -7696,7 +7706,7 @@
; return 0; }
EOF
-if { (eval echo configure:7700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GDALOpen=yes"
else
@@ -7715,10 +7725,10 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-echo "configure:7719: checking for GDALOpen" >&5
+echo "configure:7729: checking for GDALOpen" >&5
-#line 7722 "configure"
+#line 7732 "configure"
@@ -7741,7 +7751,7 @@
; return 0; }
EOF
-if { (eval echo configure:7745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7777,7 +7787,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7781: checking whether to use TIFF" >&5
+echo "configure:7791: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7797,7 +7807,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7801: checking for location of TIFF includes" >&5
+echo "configure:7811: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7823,15 +7833,15 @@
do
-echo "configure:7827: checking for $ac_hdr" >&5
+echo "configure:7837: checking for $ac_hdr" >&5
-#line 7830 "configure"
+#line 7840 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7835: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7845: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7865,7 +7875,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7869: checking for location of TIFF library" >&5
+echo "configure:7879: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7896,13 +7906,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7900: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7910: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ltiff $LIBS"
-#line 7906 "configure"
+#line 7916 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7913,7 +7923,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7932,13 +7942,13 @@
-echo "configure:7936: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7946: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7942 "configure"
+#line 7952 "configure"
@@ -7949,7 +7959,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7968,13 +7978,13 @@
-echo "configure:7972: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7982: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7978 "configure"
+#line 7988 "configure"
@@ -7985,7 +7995,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8004,13 +8014,13 @@
-echo "configure:8008: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8018: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8014 "configure"
+#line 8024 "configure"
@@ -8021,7 +8031,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8040,13 +8050,13 @@
-echo "configure:8044: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8054: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8050 "configure"
+#line 8060 "configure"
@@ -8057,7 +8067,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8076,13 +8086,13 @@
-echo "configure:8080: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8090: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8086 "configure"
+#line 8096 "configure"
@@ -8093,7 +8103,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8112,13 +8122,13 @@
-echo "configure:8116: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8126: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8122 "configure"
+#line 8132 "configure"
@@ -8129,7 +8139,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8148,13 +8158,13 @@
-echo "configure:8152: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8162: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8158 "configure"
+#line 8168 "configure"
@@ -8165,7 +8175,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8263,7 +8273,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8267: checking whether to use PNG" >&5
+echo "configure:8277: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8282,7 +8292,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8286: checking for location of PNG includes" >&5
+echo "configure:8296: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8308,15 +8318,15 @@
do
-echo "configure:8312: checking for $ac_hdr" >&5
+echo "configure:8322: checking for $ac_hdr" >&5
-#line 8315 "configure"
+#line 8325 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8350,7 +8360,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8354: checking for location of PNG library" >&5
+echo "configure:8364: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8375,13 +8385,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8379: checking for png_read_image in -lpng" >&5
+echo "configure:8389: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8385 "configure"
+#line 8395 "configure"
@@ -8392,7 +8402,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8434,7 +8444,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8438: checking whether to use Tcl/Tk" >&5
+echo "configure:8448: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8454,7 +8464,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8458: checking for location of Tcl/Tk includes" >&5
+echo "configure:8468: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8480,15 +8490,15 @@
do
-echo "configure:8484: checking for $ac_hdr" >&5
+echo "configure:8494: checking for $ac_hdr" >&5
-#line 8487 "configure"
+#line 8497 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8525,15 +8535,15 @@
do
-echo "configure:8529: checking for $ac_hdr" >&5
+echo "configure:8539: checking for $ac_hdr" >&5
-#line 8532 "configure"
+#line 8542 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8537: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8547: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8567,7 +8577,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8571: checking Tcl version" >&5
+echo "configure:8581: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8575,7 +8585,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8579 "configure"
+#line 8589 "configure"
#include <stdio.h>
@@ -8587,7 +8597,7 @@
EOF
-if { (eval echo configure:8591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8605,7 +8615,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8609: checking Tk version" >&5
+echo "configure:8619: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8613,7 +8623,7 @@
else
-#line 8617 "configure"
+#line 8627 "configure"
#include <stdio.h>
@@ -8625,7 +8635,7 @@
EOF
-if { (eval echo configure:8629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8654,7 +8664,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8658: checking for location of Tcl/Tk library" >&5
+echo "configure:8668: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8684,13 +8694,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8688: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8698: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8694 "configure"
+#line 8704 "configure"
@@ -8701,7 +8711,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8720,13 +8730,13 @@
-echo "configure:8724: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8734: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8730 "configure"
+#line 8740 "configure"
@@ -8737,7 +8747,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8764,13 +8774,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8768: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8778: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8774 "configure"
+#line 8784 "configure"
@@ -8781,7 +8791,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8800,13 +8810,13 @@
-echo "configure:8804: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8814: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8810 "configure"
+#line 8820 "configure"
@@ -8817,7 +8827,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8844,13 +8854,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8848: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8858: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8854 "configure"
+#line 8864 "configure"
@@ -8861,7 +8871,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8880,13 +8890,13 @@
-echo "configure:8884: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8894: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8890 "configure"
+#line 8900 "configure"
@@ -8897,7 +8907,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8975,13 +8985,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8979: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8989: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8985 "configure"
+#line 8995 "configure"
@@ -8992,7 +9002,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9011,13 +9021,13 @@
-echo "configure:9015: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9025: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9021 "configure"
+#line 9031 "configure"
@@ -9028,7 +9038,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9055,13 +9065,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9059: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9069: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9065 "configure"
+#line 9075 "configure"
@@ -9072,7 +9082,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9091,13 +9101,13 @@
-echo "configure:9095: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9105: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9101 "configure"
+#line 9111 "configure"
@@ -9108,7 +9118,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9135,13 +9145,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9139: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9149: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9145 "configure"
+#line 9155 "configure"
@@ -9152,7 +9162,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9171,13 +9181,13 @@
-echo "configure:9175: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9185: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9181 "configure"
+#line 9191 "configure"
@@ -9188,7 +9198,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9280,7 +9290,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9284: checking whether to use PostgreSQL" >&5
+echo "configure:9294: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9307,7 +9317,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9311: checking for location of PostgreSQL includes" >&5
+echo "configure:9321: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9333,15 +9343,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9337: checking for $ac_hdr" >&5
+echo "configure:9347: checking for $ac_hdr" >&5
-#line 9340 "configure"
+#line 9350 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9345: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9379,7 +9389,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9383: checking for location of PostgreSQL library" >&5
+echo "configure:9393: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9408,13 +9418,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9412: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9422: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9418 "configure"
+#line 9428 "configure"
@@ -9425,7 +9435,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9444,13 +9454,13 @@
-echo "configure:9448: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9458: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9454 "configure"
+#line 9464 "configure"
@@ -9461,7 +9471,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9480,13 +9490,13 @@
-echo "configure:9484: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9494: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9490 "configure"
+#line 9500 "configure"
@@ -9497,7 +9507,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9516,13 +9526,13 @@
-echo "configure:9520: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9530: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9526 "configure"
+#line 9536 "configure"
@@ -9533,7 +9543,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9590,13 +9600,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9594: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9604: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9600 "configure"
+#line 9610 "configure"
@@ -9607,7 +9617,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9629,13 +9639,13 @@
-echo "configure:9633: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9643: checking for PQcmdTuples in -lpq" >&5
-#line 9639 "configure"
+#line 9649 "configure"
@@ -9646,7 +9656,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9689,7 +9699,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9693: checking whether to use MySQL" >&5
+echo "configure:9703: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9709,7 +9719,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9713: checking for location of MySQL includes" >&5
+echo "configure:9723: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9735,15 +9745,15 @@
do
-echo "configure:9739: checking for $ac_hdr" >&5
+echo "configure:9749: checking for $ac_hdr" >&5
-#line 9742 "configure"
+#line 9752 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9757: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9780,7 +9790,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9784: checking for location of MySQL library" >&5
+echo "configure:9794: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9811,13 +9821,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9815: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9825: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9821 "configure"
+#line 9831 "configure"
@@ -9828,7 +9838,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9847,13 +9857,13 @@
-echo "configure:9851: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9861: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9857 "configure"
+#line 9867 "configure"
@@ -9864,7 +9874,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9883,13 +9893,13 @@
-echo "configure:9887: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9897: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9893 "configure"
+#line 9903 "configure"
@@ -9900,7 +9910,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9919,13 +9929,13 @@
-echo "configure:9923: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9933: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9929 "configure"
+#line 9939 "configure"
@@ -9936,7 +9946,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9955,13 +9965,13 @@
-echo "configure:9959: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9969: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9965 "configure"
+#line 9975 "configure"
@@ -9972,7 +9982,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9991,13 +10001,13 @@
-echo "configure:9995: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10005: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10001 "configure"
+#line 10011 "configure"
@@ -10008,7 +10018,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10027,13 +10037,13 @@
-echo "configure:10031: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10041: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10037 "configure"
+#line 10047 "configure"
@@ -10044,7 +10054,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10063,13 +10073,13 @@
-echo "configure:10067: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10077: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10073 "configure"
+#line 10083 "configure"
@@ -10080,7 +10090,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10170,7 +10180,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:10174: checking for $ac_word" >&5
+echo "configure:10184: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10211,10 +10221,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10215: checking for mysql_server_init" >&5
+echo "configure:10225: checking for mysql_server_init" >&5
-#line 10218 "configure"
+#line 10228 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10237,7 +10247,7 @@
; return 0; }
EOF
-if { (eval echo configure:10241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10275,7 +10285,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10279: checking whether to use SQLite" >&5
+echo "configure:10289: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10295,7 +10305,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10299: checking for location of SQLite includes" >&5
+echo "configure:10309: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10321,15 +10331,15 @@
do
-echo "configure:10325: checking for $ac_hdr" >&5
+echo "configure:10335: checking for $ac_hdr" >&5
-#line 10328 "configure"
+#line 10338 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10343: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10372,7 +10382,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10376: checking for location of SQLite library" >&5
+echo "configure:10386: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10399,13 +10409,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10403: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10413: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10409 "configure"
+#line 10419 "configure"
@@ -10416,7 +10426,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10435,13 +10445,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10439: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10449: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10445 "configure"
+#line 10455 "configure"
@@ -10452,7 +10462,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10505,7 +10515,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10509: checking whether to use FFMPEG" >&5
+echo "configure:10519: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10525,7 +10535,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10529: checking for location of FFMPEG includes" >&5
+echo "configure:10539: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10551,15 +10561,15 @@
do
-echo "configure:10555: checking for $ac_hdr" >&5
+echo "configure:10565: checking for $ac_hdr" >&5
-#line 10558 "configure"
+#line 10568 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10563: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10595,15 +10605,15 @@
do
-echo "configure:10599: checking for $ac_hdr" >&5
+echo "configure:10609: checking for $ac_hdr" >&5
-#line 10602 "configure"
+#line 10612 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10639,15 +10649,15 @@
do
-echo "configure:10643: checking for $ac_hdr" >&5
+echo "configure:10653: checking for $ac_hdr" >&5
-#line 10646 "configure"
+#line 10656 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10651: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10661: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10690,7 +10700,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10694: checking for location of FFMPEG library" >&5
+echo "configure:10704: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10717,13 +10727,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10721: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10731: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $LIBS"
-#line 10727 "configure"
+#line 10737 "configure"
@@ -10734,7 +10744,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10753,13 +10763,13 @@
-echo "configure:10757: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10767: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec -lavutil $MATHLIB $LIBS"
-#line 10763 "configure"
+#line 10773 "configure"
@@ -10770,7 +10780,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10815,13 +10825,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10819: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10829: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $LIBS"
-#line 10825 "configure"
+#line 10835 "configure"
@@ -10832,7 +10842,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10851,13 +10861,13 @@
-echo "configure:10855: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10865: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat -lavutil $MATHLIB $LIBS"
-#line 10861 "configure"
+#line 10871 "configure"
@@ -10868,7 +10878,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10928,7 +10938,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10932: checking whether to use OpenGL" >&5
+echo "configure:10942: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10962,7 +10972,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10966: checking for location of OpenGL includes" >&5
+echo "configure:10976: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10988,15 +10998,15 @@
do
-echo "configure:10992: checking for $ac_hdr" >&5
+echo "configure:11002: checking for $ac_hdr" >&5
-#line 10995 "configure"
+#line 11005 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11000: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11010: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11030,7 +11040,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11034: checking for location of OpenGL library" >&5
+echo "configure:11044: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11059,13 +11069,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11063: checking for glBegin in -lGL" >&5
+echo "configure:11073: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11069 "configure"
+#line 11079 "configure"
@@ -11076,7 +11086,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11095,13 +11105,13 @@
-echo "configure:11099: checking for glBegin in -lGL" >&5
+echo "configure:11109: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11105 "configure"
+#line 11115 "configure"
@@ -11112,7 +11122,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11131,13 +11141,13 @@
-echo "configure:11135: checking for glBegin in -lGL" >&5
+echo "configure:11145: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11141 "configure"
+#line 11151 "configure"
@@ -11148,7 +11158,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11167,13 +11177,13 @@
-echo "configure:11171: checking for glBegin in -lGL" >&5
+echo "configure:11181: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11177 "configure"
+#line 11187 "configure"
@@ -11184,7 +11194,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11246,13 +11256,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11250: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11260: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11256 "configure"
+#line 11266 "configure"
@@ -11263,7 +11273,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11282,13 +11292,13 @@
-echo "configure:11286: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11296: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11292 "configure"
+#line 11302 "configure"
@@ -11299,7 +11309,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11343,10 +11353,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11347: checking for glXCreatePbuffer" >&5
+echo "configure:11357: checking for glXCreatePbuffer" >&5
-#line 11350 "configure"
+#line 11360 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11369,7 +11379,7 @@
; return 0; }
EOF
-if { (eval echo configure:11373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11391,10 +11401,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11395: checking for glXCreateGLXPixmap" >&5
+echo "configure:11405: checking for glXCreateGLXPixmap" >&5
-#line 11398 "configure"
+#line 11408 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11417,7 +11427,7 @@
; return 0; }
EOF
-if { (eval echo configure:11421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11456,7 +11466,7 @@
-echo "configure:11460: checking for location of OpenGL includes" >&5
+echo "configure:11470: checking for location of OpenGL includes" >&5
@@ -11482,15 +11492,15 @@
do
-echo "configure:11486: checking for $ac_hdr" >&5
+echo "configure:11496: checking for $ac_hdr" >&5
-#line 11489 "configure"
+#line 11499 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11494: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11525,10 +11535,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11529: checking for glBegin" >&5
+echo "configure:11539: checking for glBegin" >&5
-#line 11532 "configure"
+#line 11542 "configure"
which can conflict with char glBegin(); below. */
@@ -11551,7 +11561,7 @@
; return 0; }
EOF
-if { (eval echo configure:11555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11566,10 +11576,10 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11570: checking for gluBeginCurve" >&5
+echo "configure:11580: checking for gluBeginCurve" >&5
-#line 11573 "configure"
+#line 11583 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11592,7 +11602,7 @@
; return 0; }
EOF
-if { (eval echo configure:11596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11638,7 +11648,7 @@
-echo "configure:11642: checking for location of OpenGL includes" >&5
+echo "configure:11652: checking for location of OpenGL includes" >&5
@@ -11664,15 +11674,15 @@
do
-echo "configure:11668: checking for $ac_hdr" >&5
+echo "configure:11678: checking for $ac_hdr" >&5
-#line 11671 "configure"
+#line 11681 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11676: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11706,7 +11716,7 @@
-echo "configure:11710: checking for location of OpenGL library" >&5
+echo "configure:11720: checking for location of OpenGL library" >&5
@@ -11729,33 +11739,33 @@
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11733: checking for OpenGL library" >&5
+echo "configure:11743: checking for OpenGL library" >&5
LIBS="-lopengl32"
-#line 11736 "configure"
+#line 11746 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
OPENGLLIB=-lopengl32
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11749: checking for GLU library" >&5
+echo "configure:11759: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB"
-#line 11752 "configure"
+#line 11762 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11806,7 +11816,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11810: checking whether to use ODBC" >&5
+echo "configure:11820: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11825,7 +11835,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11829: checking for location of ODBC includes" >&5
+echo "configure:11839: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11851,15 +11861,15 @@
do
-echo "configure:11855: checking for $ac_hdr" >&5
+echo "configure:11865: checking for $ac_hdr" >&5
-#line 11858 "configure"
+#line 11868 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11863: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11893,7 +11903,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11897: checking for location of ODBC library" >&5
+echo "configure:11907: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11918,13 +11928,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11922: checking for SQLConnect in -lodbc" >&5
+echo "configure:11932: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11928 "configure"
+#line 11938 "configure"
#include "confdefs.h"
@@ -11935,7 +11945,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11960,13 +11970,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11964: checking for SQLConnect in -liodbc" >&5
+echo "configure:11974: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11970 "configure"
+#line 11980 "configure"
@@ -11977,7 +11987,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12026,7 +12036,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12030: checking whether to use FFTW" >&5
+echo "configure:12040: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12045,7 +12055,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12049: checking for location of FFTW includes" >&5
+echo "configure:12059: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12071,15 +12081,15 @@
do
-echo "configure:12075: checking for $ac_hdr" >&5
+echo "configure:12085: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 12078 "configure"
+#line 12088 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12093: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12107,15 +12117,15 @@
do
-echo "configure:12111: checking for $ac_hdr" >&5
+echo "configure:12121: checking for $ac_hdr" >&5
-#line 12114 "configure"
+#line 12124 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12119: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12129: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12143,15 +12153,15 @@
do
-echo "configure:12147: checking for $ac_hdr" >&5
+echo "configure:12157: checking for $ac_hdr" >&5
-#line 12150 "configure"
+#line 12160 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12155: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12165: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12197,7 +12207,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12201: checking for location of FFTW library" >&5
+echo "configure:12211: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12222,13 +12232,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12226: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12236: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12232 "configure"
+#line 12242 "configure"
@@ -12239,7 +12249,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12264,13 +12274,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12268: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12278: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12274 "configure"
+#line 12284 "configure"
@@ -12281,7 +12291,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12306,13 +12316,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12310: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12320: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12316 "configure"
+#line 12326 "configure"
@@ -12323,7 +12333,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12380,7 +12390,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12384: checking whether to use BLAS" >&5
+echo "configure:12394: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12401,7 +12411,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12405: checking for location of BLAS includes" >&5
+echo "configure:12415: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12421,7 +12431,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12425: checking for location of BLAS library" >&5
+echo "configure:12435: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12447,15 +12457,15 @@
do
-echo "configure:12451: checking for $ac_hdr" >&5
+echo "configure:12461: checking for $ac_hdr" >&5
-#line 12454 "configure"
+#line 12464 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12459: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12490,13 +12500,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12494: checking for dnrm2_ in -lblas" >&5
+echo "configure:12504: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12500 "configure"
+#line 12510 "configure"
@@ -12507,7 +12517,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12526,13 +12536,13 @@
-echo "configure:12530: checking for dnrm2_ in -lblas" >&5
+echo "configure:12540: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12536 "configure"
+#line 12546 "configure"
@@ -12543,7 +12553,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12587,13 +12597,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12591: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12601: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12597 "configure"
+#line 12607 "configure"
@@ -12604,7 +12614,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12619,13 +12629,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12623: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12633: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12629 "configure"
+#line 12639 "configure"
@@ -12636,7 +12646,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12651,13 +12661,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12655: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12665: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12661 "configure"
+#line 12671 "configure"
@@ -12668,7 +12678,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12713,16 +12723,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12717: checking for sgemm in $vlib_flags" >&5
+echo "configure:12727: checking for sgemm in $vlib_flags" >&5
-#line 12719 "configure"
+#line 12729 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12740,13 +12750,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12744: checking for sgemm_ in -lblas" >&5
+echo "configure:12754: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12750 "configure"
+#line 12760 "configure"
@@ -12757,7 +12767,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12772,13 +12782,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12776: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12786: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12782 "configure"
+#line 12792 "configure"
@@ -12789,7 +12799,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12804,13 +12814,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12808: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12818: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12814 "configure"
+#line 12824 "configure"
@@ -12821,7 +12831,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12855,13 +12865,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12859: checking for acosp in -lsunmath" >&5
+echo "configure:12869: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lsunmath $LIBS"
-#line 12865 "configure"
+#line 12875 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12872,7 +12882,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12887,13 +12897,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12891: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12901: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12897 "configure"
+#line 12907 "configure"
@@ -12904,7 +12914,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12934,13 +12944,13 @@
# Generic BLAS library
-echo "configure:12938: checking for sgemm_ in -lblas" >&5
+echo "configure:12948: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12944 "configure"
+#line 12954 "configure"
@@ -12951,7 +12961,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12990,7 +13000,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12994: checking whether to use LAPACK" >&5
+echo "configure:13004: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13015,7 +13025,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13019: checking for location of LAPACK includes" >&5
+echo "configure:13029: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13035,7 +13045,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13039: checking for location of LAPACK library" >&5
+echo "configure:13049: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13061,15 +13071,15 @@
do
-echo "configure:13065: checking for $ac_hdr" >&5
+echo "configure:13075: checking for $ac_hdr" >&5
-#line 13068 "configure"
+#line 13078 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13101,10 +13111,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13105: checking for dsegv_" >&5
+echo "configure:13115: checking for dsegv_" >&5
-#line 13108 "configure"
+#line 13118 "configure"
which can conflict with char dsegv_(); below. */
@@ -13127,7 +13137,7 @@
; return 0; }
EOF
-if { (eval echo configure:13131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13154,13 +13164,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13158: checking for desgv_ in -llapack" >&5
+echo "configure:13168: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13164 "configure"
+#line 13174 "configure"
@@ -13171,7 +13181,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13203,13 +13213,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13207: checking for dgesv_ in -llapack" >&5
+echo "configure:13217: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13213 "configure"
+#line 13223 "configure"
@@ -13220,7 +13230,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13239,13 +13249,13 @@
-echo "configure:13243: checking for dgesv_ in -llapack" >&5
+echo "configure:13253: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13249 "configure"
+#line 13259 "configure"
@@ -13256,7 +13266,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13312,7 +13322,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13316: checking whether to use Motif" >&5
+echo "configure:13326: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13331,7 +13341,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13335: checking for location of Motif includes" >&5
+echo "configure:13345: checking for location of Motif includes" >&5
case "$with_motif_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13357,15 +13367,15 @@
do
-echo "configure:13361: checking for $ac_hdr" >&5
+echo "configure:13371: checking for $ac_hdr" >&5
-#line 13364 "configure"
+#line 13374 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13399,7 +13409,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13403: checking for location of Motif library" >&5
+echo "configure:13413: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13424,13 +13434,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13428: checking for XmStringCreate in -lXm" >&5
+echo "configure:13438: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13434 "configure"
+#line 13444 "configure"
@@ -13441,7 +13451,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13482,7 +13492,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13486: checking whether to use Cairo" >&5
+echo "configure:13496: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13508,15 +13518,15 @@
do
-echo "configure:13512: checking for $ac_hdr" >&5
+echo "configure:13522: checking for $ac_hdr" >&5
-#line 13515 "configure"
+#line 13525 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13520: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13530: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13553,10 +13563,10 @@
LDFLAGS="$LDFLAGS $CAIROLIB"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13557: checking for cairo_create" >&5
+echo "configure:13567: checking for cairo_create" >&5
-#line 13560 "configure"
+#line 13570 "configure"
which can conflict with char cairo_create(); below. */
@@ -13579,7 +13589,7 @@
; return 0; }
EOF
-if { (eval echo configure:13583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13614,7 +13624,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13618: checking whether to use GLw" >&5
+echo "configure:13628: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -13633,7 +13643,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13637: checking for location of GLw includes" >&5
+echo "configure:13647: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13659,15 +13669,15 @@
do
-echo "configure:13663: checking for $ac_hdr" >&5
+echo "configure:13673: checking for $ac_hdr" >&5
-#line 13666 "configure"
+#line 13676 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13695,15 +13705,15 @@
do
-echo "configure:13699: checking for $ac_hdr" >&5
+echo "configure:13709: checking for $ac_hdr" >&5
-#line 13702 "configure"
+#line 13712 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13717: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13743,7 +13753,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13747: checking for location of GLw library" >&5
+echo "configure:13757: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13768,13 +13778,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13772: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13782: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13778 "configure"
+#line 13788 "configure"
@@ -13785,7 +13795,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13810,13 +13820,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13814: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13824: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13820 "configure"
+#line 13830 "configure"
@@ -13827,7 +13837,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13852,13 +13862,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13856: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13866: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13862 "configure"
+#line 13872 "configure"
@@ -13869,7 +13879,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13894,13 +13904,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13898: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13908: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13904 "configure"
+#line 13914 "configure"
@@ -13911,7 +13921,7 @@
; return 0; }
EOF
-if { (eval echo configure:13915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13936,13 +13946,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13940: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:13950: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13946 "configure"
+#line 13956 "configure"
@@ -13953,7 +13963,7 @@
; return 0; }
EOF
-if { (eval echo configure:13957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13978,13 +13988,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13982: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:13992: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13988 "configure"
+#line 13998 "configure"
@@ -13995,7 +14005,7 @@
; return 0; }
EOF
-if { (eval echo configure:13999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14022,13 +14032,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14026: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14036: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14032 "configure"
+#line 14042 "configure"
@@ -14039,7 +14049,7 @@
; return 0; }
EOF
-if { (eval echo configure:14043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14058,13 +14068,13 @@
-echo "configure:14062: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14072: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14068 "configure"
+#line 14078 "configure"
@@ -14075,7 +14085,7 @@
; return 0; }
EOF
-if { (eval echo configure:14079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14102,13 +14112,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14106: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14116: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14112 "configure"
+#line 14122 "configure"
@@ -14119,7 +14129,7 @@
; return 0; }
EOF
-if { (eval echo configure:14123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14138,13 +14148,13 @@
-echo "configure:14142: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14152: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14148 "configure"
+#line 14158 "configure"
@@ -14155,7 +14165,7 @@
; return 0; }
EOF
-if { (eval echo configure:14159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14268,7 +14278,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14272: checking whether to use FreeType" >&5
+echo "configure:14282: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14287,7 +14297,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14291: checking for location of FreeType includes" >&5
+echo "configure:14301: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14313,15 +14323,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14317: checking for $ac_hdr" >&5
+echo "configure:14327: checking for $ac_hdr" >&5
-#line 14320 "configure"
+#line 14330 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14335: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14355,7 +14365,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14359: checking for location of FreeType library" >&5
+echo "configure:14369: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14380,13 +14390,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14384: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14394: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14390 "configure"
+#line 14400 "configure"
@@ -14397,7 +14407,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14438,7 +14448,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14442: checking whether to use NLS" >&5
+echo "configure:14452: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14458,10 +14468,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14462: checking for gettext" >&5
+echo "configure:14472: checking for gettext" >&5
-#line 14465 "configure"
+#line 14475 "configure"
which can conflict with char gettext(); below. */
@@ -14484,7 +14494,7 @@
; return 0; }
EOF
-if { (eval echo configure:14488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14502,13 +14512,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14506: checking for gettext in -lintl" >&5
+echo "configure:14516: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14512 "configure"
+#line 14522 "configure"
@@ -14519,7 +14529,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14554,7 +14564,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14558: checking whether to use C++" >&5
+echo "configure:14568: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14570,7 +14580,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14574: checking for $ac_word" >&5
+echo "configure:14584: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14599,7 +14609,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14603: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14613: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14610,12 +14620,12 @@
cat > conftest.$ac_ext << EOF
-#line 14614 "configure"
+#line 14624 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14641,19 +14651,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14645: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14655: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14650: checking whether we are using GNU C++" >&5
+echo "configure:14660: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14657: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14667: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14671,7 +14681,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14675: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14685: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14712,7 +14722,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14716: checking whether to use openDWG" >&5
+echo "configure:14726: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14732,7 +14742,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14736: checking for location of openDGW includes" >&5
+echo "configure:14746: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14758,15 +14768,15 @@
do
-echo "configure:14762: checking for $ac_hdr" >&5
+echo "configure:14772: checking for $ac_hdr" >&5
-#line 14765 "configure"
+#line 14775 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14780: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14800,7 +14810,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14804: checking for location of openDWG library" >&5
+echo "configure:14814: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14847,7 +14857,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14851: checking for special C compiler options needed for large files" >&5
+echo "configure:14861: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14855,7 +14865,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14859 "configure"
+#line 14869 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14871,7 +14881,7 @@
; return 0; }
EOF
-if { (eval echo configure:14875: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14885: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14880,7 +14890,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14884 "configure"
+#line 14894 "configure"
@@ -14896,7 +14906,7 @@
; return 0; }
EOF
-if { (eval echo configure:14900: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14910: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14916,11 +14926,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14920: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14930: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14924 "configure"
+#line 14934 "configure"
@@ -14936,14 +14946,14 @@
; return 0; }
EOF
-if { (eval echo configure:14940: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14950: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14947 "configure"
+#line 14957 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14961,7 +14971,7 @@
; return 0; }
EOF
-if { (eval echo configure:14965: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14975: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14980,11 +14990,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14984: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14994: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14988 "configure"
+#line 14998 "configure"
@@ -15000,14 +15010,14 @@
; return 0; }
EOF
-if { (eval echo configure:15004: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15014: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15011 "configure"
+#line 15021 "configure"
#define _LARGE_FILES 1
@@ -15025,7 +15035,7 @@
; return 0; }
EOF
-if { (eval echo configure:15029: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15044,25 +15054,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15048: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15058: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15052 "configure"
+#line 15062 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15069: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15066 "configure"
+#line 15076 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15071,7 +15081,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15075: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15085: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15092,10 +15102,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15096: checking if system supports Large Files at all" >&5
+echo "configure:15106: checking if system supports Large Files at all" >&5
-#line 15099 "configure"
+#line 15109 "configure"
#include <stdio.h>
@@ -15127,7 +15137,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15131: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15141: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15155,34 +15165,34 @@
# Python check
+echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
+echo "configure:15170: checking whether to use Python" >&5
-echo $ac_n "checking whether to use PYTHON""... $ac_c" 1>&6
-echo "configure:15161: checking whether to use PYTHON" >&5
-echo "$ac_t"""$with_python"" 1>&6
-case "$with_python" in
- "no") USE_PYTHON= ;;
- "yes") USE_PYTHON="1" ;;
- *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
-esac
+PYTHONINC=
+PYTHONCFLAGS=
+PYTHONLDFLAGS=
+USE_PYTHON=
+if test "$with_python" = "no" ; then
+ echo "$ac_t""no" 1>&6
+else
+ echo "$ac_t""yes" 1>&6
+ USE_PYTHON="1"
+ if test "$with_python" != "yes" ; then
+ PY_CONFIG="$with_python"
+ fi
-if test -n "$USE_PYTHON"; then
-# check for Python executable
-if test -z "$PYTHON_BIN"; then
- # Extract the first word of "python", so it can be a program name with args.
-set dummy python; ac_word=$2
+ # Extract the first word of "python-config", so it can be a program name with args.
+set dummy python-config; ac_word=$2
-echo "configure:15179: checking for $ac_word" >&5
+echo "configure:15189: checking for $ac_word" >&5
-case "$PYTHON_BIN" in
+case "$PY_CONFIG" in
- ac_cv_path_PYTHON_BIN="$PYTHON_BIN" # Let the user override the test with a path.
+ ac_cv_path_PY_CONFIG="$PY_CONFIG" # Let the user override the test with a path.
- ac_cv_path_PYTHON_BIN="$PYTHON_BIN" # Let the user override the test with a dos path.
+ ac_cv_path_PY_CONFIG="$PY_CONFIG" # Let the user override the test with a dos path.
IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
@@ -15190,65 +15200,118 @@
for ac_dir in $ac_dummy; do
test -z "$ac_dir" && ac_dir=.
if test -f $ac_dir/$ac_word; then
- ac_cv_path_PYTHON_BIN="$ac_dir/$ac_word"
+ ac_cv_path_PY_CONFIG="$ac_dir/$ac_word"
break
fi
done
IFS="$ac_save_ifs"
+ test -z "$ac_cv_path_PY_CONFIG" && ac_cv_path_PY_CONFIG="no"
esac
-PYTHON_BIN="$ac_cv_path_PYTHON_BIN"
-if test -n "$PYTHON_BIN"; then
- echo "$ac_t""$PYTHON_BIN" 1>&6
+PY_CONFIG="$ac_cv_path_PY_CONFIG"
+if test -n "$PY_CONFIG"; then
+ echo "$ac_t""$PY_CONFIG" 1>&6
else
fi
- if test -z "$PYTHON_BIN"; then
- # Extract the first word of "python2.3", so it can be a program name with args.
-set dummy python2.3; ac_word=$2
-echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15212: checking for $ac_word" >&5
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
- ac_dummy="$PATH"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$ac_word; then
- break
- fi
- done
- IFS="$ac_save_ifs"
-esac
+ if test "$PY_CONFIG" = "no" ; then
+ { echo "configure: error: *** couldn't find python-config" 1>&2; exit 1; }
+ fi
+ # With Python includes directory
+ PYTHONINC=`"$PY_CONFIG" --includes`
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$PYTHONINC $CPPFLAGS"
+for ac_hdr in Python.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:15234: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 15237 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:15242: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=yes"
else
+ echo "$ac_err" >&5
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+ ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+ cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+{ echo "configure: error: *** Unable to locate Python includes." 1>&2; exit 1; }
fi
+done
- # Extract the first word of "python2.4", so it can be a program name with args.
-set dummy python2.4; ac_word=$2
+CPPFLAGS=$ac_save_cppflags
+ PYTHONCFLAGS=`"$PY_CONFIG" --cflags`
+ # With Python library directory
+ PYTHONLDFLAGS=`"$PY_CONFIG" --ldflags`
+fi # Done checking Python
+# Enable wxWidgets support (for wxGUI)
+echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
+echo "configure:15288: checking whether to use wxWidgets" >&5
+WXVERSION=
+WXWIDGETSCXXFLAGS=
+WXWIDGETSCPPFLAGS=
+WXWIDGETSLIB=
+USE_WXWIDGETS=
+if test "$with_wxwidgets" = "no" ; then
+else
+ USE_WXWIDGETS="1"
+ if test "`basename $with_wxwidgets`" = "wx-config" ; then
+ WX_CONFIG="$with_wxwidgets"
+ fi
+ # Extract the first word of "wx-config", so it can be a program name with args.
+set dummy wx-config; ac_word=$2
-echo "configure:15245: checking for $ac_word" >&5
+echo "configure:15308: checking for $ac_word" >&5
+case "$WX_CONFIG" in
+ ac_cv_path_WX_CONFIG="$WX_CONFIG" # Let the user override the test with a path.
+ ac_cv_path_WX_CONFIG="$WX_CONFIG" # Let the user override the test with a dos path.
@@ -15256,90 +15319,157 @@
+ ac_cv_path_WX_CONFIG="$ac_dir/$ac_word"
break
fi
done
IFS="$ac_save_ifs"
+ test -z "$ac_cv_path_WX_CONFIG" && ac_cv_path_WX_CONFIG="no"
esac
+WX_CONFIG="$ac_cv_path_WX_CONFIG"
+if test -n "$WX_CONFIG"; then
+ echo "$ac_t""$WX_CONFIG" 1>&6
else
fi
- { echo "configure: error: python binary not found in path" 1>&2; exit 1; }
- fi
- fi
- fi
-fi
-PYTHON=`basename $PYTHON_BIN`
+ if test "$WX_CONFIG" = "no" ; then
+ { echo "configure: error: *** couldn't find wx-config
+ wxWidgets must be installed on your system.
+ Please check that wx-config is in path, the directory
+ where wxWidgets libraries are installed (returned by
+ 'wx-config --libs' or 'wx-config --static --libs' command)
+ is in LD_LIBRARY_PATH or equivalent variable and
+ wxWidgets version is 2.8.1 or above." 1>&2; exit 1; }
+ fi
-echo "configure:15289: checking for $ac_word" >&5
+ # Check wxWidgets version
- ac_dummy="$PATH"
- break
- fi
- done
-esac
+ REQWX="2.8.1"
+ echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
+echo "configure:15356: checking wxWidgets version" >&5
+ if WXVERSION=`"$WX_CONFIG" --version`; then
+ echo "$ac_t""$WXVERSION" 1>&6
+ else
+ echo "$ac_t""not found" 1>&6
+ { echo "configure: error: wxWidgets is required." 1>&2; exit 1; }
+ fi
+ if test `expr "$WXVERSION" \< "$REQWX"` = 1 ; then
+ { echo "configure: error: *** wxWidgets "$REQWX" or later is required." 1>&2; exit 1; }
+ fi
+ # With wxWidgets includes directory
+ WXWIDGETSCXXFLAGS=`"$WX_CONFIG" --cxxflags`
+ WXWIDGETSCPPFLAGS=`"$WX_CONFIG" --cppflags`
+CPPFLAGS="$WXWIDGETSCPPFLAGS $CPPFLAGS"
+for ac_hdr in wx/wxprec.h
+do
+echo "configure:15379: checking for $ac_hdr" >&5
+#line 15382 "configure"
+#include <$ac_hdr>
+EOF
+{ (eval echo configure:15387: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ rm -rf conftest*
else
+ rm -rf conftest*
+fi
+rm -f conftest*
+EOF
+else
-fi
+{ echo "configure: error: *** Unable to locate wxWidgets includes." 1>&2; exit 1; }
- fi
fi
+done
-# find out python version
-echo $ac_n "checking Python version""... $ac_c" 1>&6
-echo "configure:15325: checking Python version" >&5
-PYVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:3]'`
-PYMAJVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:1]'`
-PYMINVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[2:3]'`
-echo "$ac_t""$PYVERSION" 1>&6
+for ac_hdr in wx/wxPython/pseudodc.h
+do
+echo "configure:15423: checking for $ac_hdr" >&5
-# make sure Python is version >= 2.3
-if test "$PYMAJVERSION" -lt "2" || \
- (test "$PYMAJVERSION" -eq "2" && test "$PYMINVERSION" -lt "3"); then
- { echo "configure: error: This version of GRASS requires at least Python version 2.3.
-The one you have seems to be $PYVERSION. You can specify an alternate python
-by using (for example) --with-python=/usr/bin/python2.3" 1>&2; exit 1; }
+#line 15426 "configure"
+#include <$ac_hdr>
+EOF
+{ (eval echo configure:15431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ rm -rf conftest*
+else
+ rm -rf conftest*
fi
+rm -f conftest*
+EOF
+else
fi
+done
+ # With wxWidgets library directory
+ WXWIDGETSLIB=`"$WX_CONFIG" --libs`
+fi # $USE_WXWIDGETS
+# Done checking wxWidgets
USE_TERMIO=
@@ -15599,10 +15729,17 @@
s%@OPENDWGLIB@%$OPENDWGLIB%g
s%@USE_OPENDWG@%$USE_OPENDWG%g
s%@USE_LARGEFILES@%$USE_LARGEFILES%g
-s%@PYTHON_BIN@%$PYTHON_BIN%g
-s%@PYTHON@%$PYTHON%g
-s%@PYVERSION@%$PYVERSION%g
+s%@PY_CONFIG@%$PY_CONFIG%g
+s%@PYTHONINC@%$PYTHONINC%g
+s%@PYTHONCFLAGS@%$PYTHONCFLAGS%g
+s%@PYTHONLDFLAGS@%$PYTHONLDFLAGS%g
s%@USE_PYTHON@%$USE_PYTHON%g
+s%@WX_CONFIG@%$WX_CONFIG%g
+s%@WXVERSION@%$WXVERSION%g
+s%@WXWIDGETSCXXFLAGS@%$WXWIDGETSCXXFLAGS%g
+s%@WXWIDGETSCPPFLAGS@%$WXWIDGETSCPPFLAGS%g
+s%@WXWIDGETSLIB@%$WXWIDGETSLIB%g
+s%@USE_WXWIDGETS@%$USE_WXWIDGETS%g
s%@USE_TERMIO@%$USE_TERMIO%g
s%@STRIPFLAG@%$STRIPFLAG%g
s%@GRASS_HOME@%$GRASS_HOME%g
@@ -15930,6 +16067,8 @@
echo " Tcl/Tk support: `if test -n "${USE_TCLTK}" ; then echo yes ; else echo no ; fi`"
+echo " wxWidgets support: `if test -n "${USE_WXWIDGETS}" ; then echo yes ; else echo no ; fi`"
echo " TIFF support: `if test -n "${USE_TIFF}" ; then echo yes ; else echo no ; fi`"
echo " X11 support: `if test -n "${USE_X11}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-02-15 19:43:12 UTC (rev 30170)
+++ grass/trunk/configure.in 2008-02-15 21:27:04 UTC (rev 30171)
@@ -193,7 +193,12 @@
LOC_ARG_WITH(readline, Readline, no)
LOC_ARG_WITH(opendwg, openDWG, no)
LOC_ARG_WITH(curses, Curses, yes)
-LOC_ARG_WITH(python, PYTHON, no)
+AC_ARG_WITH(python,
+[ --with-python[=path/python-config] enable Python support (python-config with path, \
+e.g. '--with-python=/usr/bin/python2.5-config', default: no)],, with_python="no")
+AC_ARG_WITH(wxwidgets,
+[ --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, \
+e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)],, with_wxwidgets="no")
# With includes and libs options
@@ -1623,56 +1628,115 @@
# Python check
-LOC_CHECK_USE(python, PYTHON, USE_PYTHON)
+AC_MSG_CHECKING(whether to use Python)
+PYTHONINC=
+PYTHONCFLAGS=
+PYTHONLDFLAGS=
+USE_PYTHON=
- AC_PATH_PROG(PYTHON_BIN, python)
- AC_PATH_PROG(PYTHON_BIN, python2.3)
- AC_PATH_PROG(PYTHON_BIN, python2.4)
- AC_MSG_ERROR(python binary not found in path)
- fi
- fi
+ AC_MSG_RESULT(no)
+else
+ AC_MSG_RESULT(yes)
+ USE_PYTHON="1"
fi
-fi
-AC_SUBST(PYTHON)
+ AC_PATH_PROG(PY_CONFIG, python-config, no)
- fi
-fi
+ AC_MSG_ERROR([*** couldn't find python-config])
+ fi
-AC_MSG_CHECKING(Python version)
-PYVERSION=`$PYTHON_BIN -c ['import sys; print sys.version[:3]'`]
-PYMAJVERSION=`$PYTHON_BIN -c ['import sys; print sys.version[:1]'`]
-PYMINVERSION=`$PYTHON_BIN -c ['import sys; print sys.version[2:3]'`]
-AC_MSG_RESULT($PYVERSION)
-AC_SUBST(PYVERSION)
- AC_MSG_ERROR([This version of GRASS requires at least Python version 2.3.
-by using (for example) --with-python=/usr/bin/python2.3])
-fi
+ LOC_CHECK_INCLUDES(Python.h,Python,$PYTHONINC)
-fi
+AC_SUBST(PYTHONINC)
+AC_SUBST(PYTHONCFLAGS)
+AC_SUBST(PYTHONLDFLAGS)
AC_SUBST(USE_PYTHON)
+AC_MSG_CHECKING(whether to use wxWidgets)
+WXVERSION=
+WXWIDGETSCXXFLAGS=
+WXWIDGETSCPPFLAGS=
+WXWIDGETSLIB=
+USE_WXWIDGETS=
+ AC_MSG_RESULT(no)
+else
+ USE_WXWIDGETS="1"
+ fi
+ AC_PATH_PROG(WX_CONFIG, wx-config, no)
+ AC_MSG_ERROR([*** couldn't find wx-config
+ wxWidgets version is 2.8.1 or above.])
+ fi
+ REQWX="2.8.1"
+ AC_MSG_CHECKING([wxWidgets version])
+ AC_MSG_RESULT([$WXVERSION])
+ else
+ AC_MSG_RESULT([not found])
+ AC_MSG_ERROR([wxWidgets is required.])
+ fi
+ AC_MSG_ERROR([*** wxWidgets "$REQWX" or later is required.])
+ fi
+ LOC_CHECK_INCLUDES(wx/wxprec.h,wxWidgets,$WXWIDGETSCPPFLAGS)
+ LOC_CHECK_INCLUDES(wx/wxPython/pseudodc.h,wxWidgets,$WXWIDGETSCPPFLAGS)
+AC_SUBST(WXVERSION)
+AC_SUBST(WXWIDGETSCXXFLAGS)
+AC_SUBST(WXWIDGETSCPPFLAGS)
+AC_SUBST(WXWIDGETSLIB)
+AC_SUBST(USE_WXWIDGETS)
USE_TERMIO=
AC_SUBST(USE_TERMIO)
@@ -1733,6 +1797,7 @@
LOC_MSG_USE(Readline support,USE_READLINE)
LOC_MSG_USE(SQLite support,USE_SQLITE)
LOC_MSG_USE(Tcl/Tk support,USE_TCLTK)
+LOC_MSG_USE(wxWidgets support,USE_WXWIDGETS)
LOC_MSG_USE(TIFF support,USE_TIFF)
LOC_MSG_USE(X11 support,USE_X11)
LOC_MSG_USE(Cairo support,USE_CAIRO)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2008-02-15 19:43:12 UTC (rev 30170)
+++ grass/trunk/include/Make/Platform.make.in 2008-02-15 21:27:04 UTC (rev 30171)
@@ -209,9 +209,18 @@
USE_CAIRO = @USE_CAIRO@
#Python
-PYVERSION = @PYVERSION@
+PYTHONINC = @PYTHONINC@
+PYTHONCFLAGS = @PYTHONCFLAGS@
+PYTHONLDFLAGS = @PYTHONLDFLAGS@
USE_PYTHON = @USE_PYTHON@
+#wxWidgets
+WXVERSION = @WXVERSION@
+WXWIDGETSCXXFLAGS = @WXWIDGETSCXXFLAGS@
+WXWIDGETSCPPFLAGS = @WXWIDGETSCPPFLAGS@
+WXWIDGETSLIB = @WXWIDGETSLIB@
+USE_WXWIDGETS = @USE_WXWIDGETS@
#i18N
HAVE_NLS = @HAVE_NLS@
