[GRASS-SVN] r30173 - in grass/trunk/gui/wxpython: . vdigit
svn_grass at osgeo.org
Fri Feb 15 17:04:11 EST 2008
Author: martinl
Date: 2008-02-15 17:04:11 -0500 (Fri, 15 Feb 2008)
New Revision: 30173
Added:
grass/trunk/gui/wxpython/vdigit/Makefile
Removed:
grass/trunk/gui/wxpython/vdigit/Makefile.in
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/driver.cpp
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI/vdigit: * Makefile template removed
* fix compiler warnings
* compile vdigit if configured --with-wxwidgets
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2008-02-15 21:44:24 UTC (rev 30172)
+++ grass/trunk/gui/wxpython/Makefile 2008-02-15 22:04:11 UTC (rev 30173)
@@ -1,11 +1,17 @@
MODULE_TOPDIR = ../..
-# SUBDIRS=vdigit docs
SUBDIRS = docs
-ETCDIR = $(ETC)/wxpython
+include $(MODULE_TOPDIR)/include/Make/Platform.make
+ifneq ($(USE_WXWIDGETS),)
+ SUBDIRS += vdigit
+endif
include $(MODULE_TOPDIR)/include/Make/Dir.make
+ETCDIR = $(ETC)/wxpython
default: parsubdirs install_scripts
install_scripts:
@@ -17,8 +23,6 @@
$(INSTALL_DATA) images/* $(ETCDIR)/images/
$(INSTALL_DATA) scripts/* $(ETCDIR)/scripts/
$(INSTALL_DATA) gis_set.py wxgui.py README $(ETCDIR)/
-# $(INSTALL_DATA) vdigit/_grass6_wxvdigit.so $(ETCDIR)/vdigit/
-# $(INSTALL_DATA) vdigit/grass6_wxvdigit.py $(ETCDIR)/vdigit/
$(INSTALL) -m 755 wxgui $(ETCDIR)/scripts/
clean: cleansubdirs
Copied: grass/trunk/gui/wxpython/vdigit/Makefile (from rev 30165, grass/trunk/gui/wxpython/vdigit/Makefile.in)
--- grass/trunk/gui/wxpython/vdigit/Makefile (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/Makefile 2008-02-15 22:04:11 UTC (rev 30173)
@@ -0,0 +1,43 @@
+MODULE_TOPDIR = ../../..
+include $(MODULE_TOPDIR)/include/Make/Lib.make
+SWIG = swig
+CXXFLAGS = -c -fpic -I$(ARCH_DISTDIR)/include $(GDALCFLAGS) $(PYTHONCFLAGS) $(WXWIDGETSCXXFLAGS)
+LDFLAGS = -shared -fpic -L$(ARCH_LIBDIR) $(VECTLIB) $(GISLIB) $(GDALLIBS) $(VEDITLIB) $(WXWIDGETSLIB) -lgdi
+LOCAL_HEADERS = digit.h driver.h
+SOURCES = driver.cpp digit.cpp cats.cpp line.cpp vertex.cpp select.cpp grass6_wxvdigit_wrap.cpp
+OBJARCH = OBJ.$(ARCH)
+OBJ := $(patsubst %.cpp, $(OBJARCH)/%.o, $(SOURCES))
+default: grass6_wxvdigit.so install_vdigit
+clean:
+ -rm -rf $(OBJARCH) _grass6_wxvdigit.so grass6_wxvdigit.i
+grass6_wxvdigit.i:
+ cat ./digit.i > grass6_wxvdigit.i
+ cat ./dig_types.i >> grass6_wxvdigit.i
+ echo "/* auto-generate swig typedef file */" >> grass6_wxvdigit.i
+ cat ./driver.h >> grass6_wxvdigit.i
+ cat ./digit.h >> grass6_wxvdigit.i
+create_wrap.cpp: grass6_wxvdigit.i
+ $(SWIG) -c++ -python -shadow -o $@ $<
+$(OBJARCH)/%.o: %.cpp $(LOCAL_HEADERS)
+ $(CXX) $(CXXFLAGS) $(INCLUDE_DIRS) $< -o $@
+grass6_wxvdigit.so: $(OBJ)
+ $(CXX) $(LDFLAGS) $(OBJ) -o _grass6_wxvdigit.so
+install_vdigit:
+ $(INSTALL_DATA) _grass6_wxvdigit.so $(ETCDIR)/vdigit/
+ $(INSTALL_DATA) grass6_wxvdigit.py $(ETCDIR)/vdigit/
Deleted: grass/trunk/gui/wxpython/vdigit/Makefile.in
--- grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-02-15 21:44:24 UTC (rev 30172)
+++ grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-02-15 22:04:11 UTC (rev 30173)
@@ -1,44 +0,0 @@
-### DEFINITIONS
-PYTHONVERSION=@PYVERSION@
-### END DEFINITIONS
-MODULE_TOPDIR = ../../..
-include $(MODULE_TOPDIR)/include/Make/Lib.make
-SWIG=swig
-WXCXXFLAGS := $(shell wx-config --cxxflags)
-CXXFLAGS = -c -fpic -I$(ARCH_DISTDIR)/include -I/usr/include/python$(PYTHONVERSION) $(GDALCFLAGS) $(WXCXXFLAGS)
-WXLDFLAGS := $(shell wx-config --libs)
-LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) $(VECTLIB) $(GISLIB) $(GDALLIBS) $(VEDITLIB) -lgdi $(WXLDFLAGS)
-LOCAL_HEADERS=digit.h driver.h
-SOURCES=driver.cpp digit.cpp cats.cpp line.cpp vertex.cpp select.cpp grass6_wxvdigit_wrap.cpp
-OBJARCH=OBJ.$(ARCH)
-OBJ := $(patsubst %.cpp, $(OBJARCH)/%.o, $(SOURCES))
-default: grass6_wxvdigit.so
-clean:
- -rm -rf $(OBJARCH) _grass6_wxvdigit.so grass6_wxvdigit.i
-grass6_wxvdigit.i:
- cat ./digit.i > grass6_wxvdigit.i
- cat ./dig_types.i >> grass6_wxvdigit.i
- echo "/* auto-generate swig typedef file */" >> grass6_wxvdigit.i
- cat ./driver.h >> grass6_wxvdigit.i
- cat ./digit.h >> grass6_wxvdigit.i
-grass6_wxvdigit_wrap.cpp: grass6_wxvdigit.i
- $(SWIG) -c++ -python -shadow -o $@ $<
-$(OBJARCH)/%.o: %.cpp $(LOCAL_HEADERS)
- $(CXX) $(CXXFLAGS) $(INCLUDE_DIRS) $< -o $@
-grass6_wxvdigit.so: $(OBJ)
- $(CXX) $(LDFLAGS) $(OBJ) -o _grass6_wxvdigit.so
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-02-15 21:44:24 UTC (rev 30172)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-02-15 22:04:11 UTC (rev 30173)
@@ -25,7 +25,7 @@
int Digit::InitCats()
- int ndblinks, nfields, field, ncats, max_cat;
+ int ndblinks, nfields, field, ncats;
int cat, type, id;
struct field_info *fi;
@@ -162,6 +162,7 @@
return lc;
+ line = -1;
if (line_id == -1) {
line = display->selected->value[0];
@@ -222,6 +223,7 @@
return -1;
+ line = -1;
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-02-15 21:44:24 UTC (rev 30172)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-02-15 22:04:11 UTC (rev 30173)
@@ -114,7 +114,6 @@
G_debug(3, "wxDriver.DrawMap(): region: w=%f, e=%f, s=%f, n=%f",
region.box.W, region.box.E, region.box.S, region.box.N);
- bool inBox;
dc->BeginDrawing();
for (int i = 0; i < listLines->n_values; i++) {
DrawLine(listLines->value[i]);
@@ -147,6 +146,9 @@
wxPen *pen;
+ pen = NULL;
+ draw = false;
// read line
type = Vect_read_line (mapInfo, points, cats, line);
@@ -243,7 +245,7 @@
// long int startId = ids[line].startId + 1;
if (dcId > 0 && drawSegments) {
dcId = 2; // first segment
- for (int i = 0; i < pointsScreen->GetCount() - 1; dcId += 2) {
+ for (size_t i = 0; i < pointsScreen->GetCount() - 1; dcId += 2) {
wxPoint *point_beg = (wxPoint *) pointsScreen->Item(i)->GetData();
wxPoint *point_end = (wxPoint *) pointsScreen->Item(++i)->GetData();
@@ -261,7 +263,7 @@
else {
wxPoint points[pointsScreen->GetCount()];
- for (int i = 0; i < pointsScreen->GetCount(); i++) {
+ for (size_t i = 0; i < pointsScreen->GetCount(); i++) {
points[i] = *point_beg;
@@ -317,7 +319,7 @@
dc->SetId(dcId); /* 0 | 1 (selected) */
dc->SetPen(*pen);
- for (int i = 1; i < pointsScreen->GetCount() - 1; i++, dcId += 2) {
+ for (size_t i = 1; i < pointsScreen->GetCount() - 1; i++, dcId += 2) {
point = (wxPoint*) pointsScreen->Item(i)->GetData();
if (IsSelected(line) && drawSegments) {
@@ -364,7 +366,7 @@
// get nodes
Vect_get_line_nodes(mapInfo, line, &(nodes[0]), &(nodes[1]));
- for (int i = 0; i < sizeof(nodes) / sizeof(int); i++) {
+ for (size_t i = 0; i < sizeof(nodes) / sizeof(int); i++) {
node = nodes[i];
// get coordinates
Vect_get_node_coor(mapInfo, node,
@@ -799,7 +801,6 @@
double thresh, int type, int with_z)
long int line;
- int ftype;
double px, py, pz;
std::vector<double> p;
@@ -884,7 +885,6 @@
return ListToVector(selected);
std::vector<int> dc_ids;
- long int line;
if (!drawSegments) {
dc_ids.push_back(1);
@@ -979,7 +979,9 @@
line = selected->value[0];
+ minDist = 0.0;
+ Gid = -1;
// find the closest vertex (x, y)
DCid = 1;
for(int idx = 0; idx < points->n_points; idx++) {
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-02-15 21:44:24 UTC (rev 30172)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-02-15 22:04:11 UTC (rev 30173)
@@ -38,8 +38,8 @@
int Digit::AddLine(int type, std::vector<double> coords, int layer, int cat,
const char *bgmap, int snap, double threshold)
- int i, npoints;
- int newline;
+ size_t i;
+ size_t npoints;
struct line_pnts *Points;
struct line_cats *Cats;
@@ -130,8 +130,6 @@
Vect_close(BgMap[0]);
- G_debug(2, "wxDigit.AddLine(): line=%d written", newline);
return 0;
@@ -151,7 +149,6 @@
int ret, type, dim;
- double x, y, z;
struct line_pnts *points;
struct line_cats *cats;
@@ -442,9 +439,7 @@
return -1;
- ret = Vedit_flip_lines(display->mapInfo, display->selected);
+ ret = Vedit_flip_lines(display->mapInfo, display->selected);
return ret;
@@ -493,13 +488,11 @@
\param thresh threshold value for snapping
- \return number of modified lines
+ \return 0 on success
\return -1 on error
int Digit::SnapLines(double thresh)
- int ret;
if (!display->mapInfo) {
return -1;
@@ -507,7 +500,7 @@
Vect_snap_lines_list (display->mapInfo, display->selected,
thresh, NULL, NULL);
- return ret;
+ return 0;
@@ -599,8 +592,8 @@
list = display->selected;
- Vedit_copy_lines (display->mapInfo, bgMap,
- list);
+ ret = Vedit_copy_lines (display->mapInfo, bgMap,
+ list);
if (list != display->selected) {
Vect_destroy_list(list);
@@ -640,6 +633,7 @@
nbgmaps = 0;
+ BgMap = NULL;
if (!G__name_is_fully_qualified(bgmap, name, mapset)) {
G_strncpy(name, bgmap, GNAME_MAX);
