[GRASS-SVN] r30176 - grass/trunk
svn_grass at osgeo.org
Fri Feb 15 17:42:03 EST 2008
Author: neteler
Date: 2008-02-15 17:42:03 -0500 (Fri, 15 Feb 2008)
New Revision: 30176
grass/trunk/configure
grass/trunk/configure.in
fix #44
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-02-15 22:25:44 UTC (rev 30175)
+++ grass/trunk/configure 2008-02-15 22:42:03 UTC (rev 30176)
@@ -1018,7 +1018,7 @@
if { (eval echo configure:1019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
for file in conftest.*; do
case $file in
- *.$ac_ext | *.c | *.o | *.obj) ;;
+ *.c | *.o | *.obj) ;;
*) ac_cv_exeext=`echo $file | sed -e s/conftest//` ;;
esac
done
@@ -15985,34 +15985,36 @@
echo ""
-echo " Source directory: ${SRCDIR}"
+echo " Source directory: ${SRCDIR}"
-echo " Build directory: ${DSTDIR}"
+echo " Build directory: ${DSTDIR}"
-echo " Installation directory: ${INSTDIR}"
+echo " Installation directory: ${INSTDIR}"
-echo " Startup script in directory: ${bindir}"
+echo " Startup script in directory: ${bindir}"
-echo " C compiler: ${CC} ${CFLAGS}"
+echo " C compiler: ${CC} ${CFLAGS}"
-echo " C++ compiler: ${CXX} ${CXXFLAGS}"
+echo " C++ compiler: ${CXX} ${CXXFLAGS}"
-#LOC_MSG([ FORTRAN compiler: ${F77} ${FFLAGS}])
+#LOC_MSG([ FORTRAN compiler: ${F77} ${FFLAGS}])
-echo " Building shared libraries: ${shared_ok}"
+echo " Building shared libraries: ${shared_ok}"
-echo " 64bit support: ${do64bit}"
+echo " 64bit support: ${do64bit}"
-echo " OpenGL platform: ${OPENGL_TYPE}"
+echo " OpenGL platform: ${OPENGL_TYPE}"
+echo " MacOSX application: `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
echo ""
@@ -16025,6 +16027,8 @@
echo " C++ support: `if test -n "${USE_CXX}" ; then echo yes ; else echo no ; fi`"
+echo " Cairo support: `if test -n "${USE_CAIRO}" ; then echo yes ; else echo no ; fi`"
echo " DWG support: `if test -n "${USE_OPENDWG}" ; then echo yes ; else echo no ; fi`"
echo " FFMPEG support: `if test -n "${USE_FFMPEG}" ; then echo yes ; else echo no ; fi`"
@@ -16073,9 +16077,5 @@
echo " X11 support: `if test -n "${USE_X11}" ; then echo yes ; else echo no ; fi`"
-echo " Cairo support: `if test -n "${USE_CAIRO}" ; then echo yes ; else echo no ; fi`"
-echo " MacOSX application: `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
echo ""
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-02-15 22:25:44 UTC (rev 30175)
+++ grass/trunk/configure.in 2008-02-15 22:42:03 UTC (rev 30176)
@@ -1761,21 +1761,23 @@
LOC_MSG()
LOC_MSG([GRASS is now configured for: ${host}])
LOC_MSG()
-LOC_MSG([ Source directory: ${SRCDIR}])
-LOC_MSG([ Build directory: ${DSTDIR}])
-LOC_MSG([ Installation directory: ${INSTDIR}])
-LOC_MSG([ Startup script in directory: ${bindir}])
-LOC_MSG([ C compiler: ${CC} ${CFLAGS}])
-LOC_MSG([ C++ compiler: ${CXX} ${CXXFLAGS}])
-LOC_MSG([ Building shared libraries: ${shared_ok}])
-LOC_MSG([ 64bit support: ${do64bit}])
-LOC_MSG([ OpenGL platform: ${OPENGL_TYPE}])
+LOC_MSG([ Source directory: ${SRCDIR}])
+LOC_MSG([ Build directory: ${DSTDIR}])
+LOC_MSG([ Installation directory: ${INSTDIR}])
+LOC_MSG([ Startup script in directory: ${bindir}])
+LOC_MSG([ C compiler: ${CC} ${CFLAGS}])
+LOC_MSG([ C++ compiler: ${CXX} ${CXXFLAGS}])
+LOC_MSG([ Building shared libraries: ${shared_ok}])
+LOC_MSG([ 64bit support: ${do64bit}])
+LOC_MSG([ OpenGL platform: ${OPENGL_TYPE}])
+LOC_MSG_USE(MacOSX application,MACOSX_APP)
LOC_MSG()
LOC_MSG_USE(NVIZ,USE_TOGL)
LOC_MSG()
LOC_MSG_USE(BLAS support,USE_BLAS)
LOC_MSG_USE(C++ support,USE_CXX)
+LOC_MSG_USE(Cairo support,USE_CAIRO)
LOC_MSG_USE(DWG support,USE_OPENDWG)
LOC_MSG_USE(FFMPEG support,USE_FFMPEG)
LOC_MSG_USE(FFTW support,USE_FFTW)
@@ -1800,6 +1802,4 @@
LOC_MSG_USE(wxWidgets support,USE_WXWIDGETS)
LOC_MSG_USE(TIFF support,USE_TIFF)
LOC_MSG_USE(X11 support,USE_X11)
-LOC_MSG_USE(Cairo support,USE_CAIRO)
-LOC_MSG_USE(MacOSX application,MACOSX_APP)
LOC_MSG()
