[GRASS-SVN] r30182 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Sat Feb 16 07:51:19 EST 2008
Author: martinl
Date: 2008-02-16 07:51:19 -0500 (Sat, 16 Feb 2008)
New Revision: 30182
grass/trunk/gui/wxpython/README
Use g.gui instead wxgui, vdigit notes updated
Modified: grass/trunk/gui/wxpython/README
--- grass/trunk/gui/wxpython/README 2008-02-16 12:13:08 UTC (rev 30181)
+++ grass/trunk/gui/wxpython/README 2008-02-16 12:51:19 UTC (rev 30182)
@@ -38,7 +38,7 @@
1 - INSTALLATION
-Go to directory:
+Go to:
$ cd gui/wxpython
@@ -49,7 +49,7 @@
2 - STARTUP WITH GRASS INITIALIZATION
If you want to run wxPython GUI automatically when you start
-GRASS, edit your .grassrc6 file to replace...
+GRASS, edit your .grassrc6 file to replace
GRASS_GUI: tcktk (or whatever you have here)
@@ -57,7 +57,7 @@
GRASS_GUI: wxpython
-or easier start new GRASS session with -wx switch.
+or easier start new GRASS session with -wxpython switch.
$ grass -wxpython
@@ -65,13 +65,13 @@
Simply type
-$ wxgui
+$ g.gui wxpython
from the GRASS terminal.
You can also specify workspace file to load on startup.
-$ wxgui myworkspace.grc
+$ g.gui gui=wxpython workspace=myworkspace.grc
4 - CLI Display scripts
@@ -138,12 +138,16 @@
7 - DIGITIZATION TOOL
-To enable digitization tool you need to compile display driver located
-in directory 'vdigit'. Note that you need to compile GRASS
-with C++ support (--with-cxx).
+To enable digitization tool you need to compile 'vdigit'
+component. Note that you must configure GRASS with C++ (--with-cxx),
+Python (--with-python) and wxWidgets (--with-wxwidgets) support.
-First, create symlink, e.g.
+First, create a symlink to _gdi_.so shared library
+$ ln -s `locate _gdi_.so` $GISBASE/lib/libgdi.so
+e.g.
$ ln -s /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so $GISBASE/lib/libgdi.so
Then you can compile the driver
