[GRASS-SVN] r30194 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Feb 16 18:16:27 EST 2008
Author: cmbarton
Date: 2008-02-16 18:16:27 -0500 (Sat, 16 Feb 2008)
New Revision: 30194
Added:
grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py
New mapcalc builder
Added: grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/mcalc_builder.py 2008-02-16 23:16:27 UTC (rev 30194)
@@ -0,0 +1,400 @@
+MODULE: mcalc_builder.py
+CLASSES:
+ * MapCalcFrame
+PURPOSE: GRASS builds r.mapcalc statements
+ Usage:
+ mcalc_builder
+AUTHOR(S): GRASS Development Team
+ Original author: Michael Barton, Arizona State University
+COPYRIGHT: (C) 2008 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+import wx
+import os,sys
+import time
+import grassenv
+import gcmd
+import gselect
+import subprocess
+imagePath = os.path.join( os.getenv("GISBASE"), "etc", "wxpython")
+sys.path.append(imagePath)
+import images
+imagepath = images.__path__[0]
+sys.path.append(imagepath)
+class MapCalcFrame(wx.Frame):
+ """Mapcalc Frame class"""
+ def __init__(self, parent, id, title, pos=wx.DefaultPosition,
+ size=wx.DefaultSize, style=wx.TAB_TRAVERSAL|wx.DEFAULT_FRAME_STYLE):
+ wx.Frame.__init__(self, parent, id, title, pos=pos, size=size, style=style)
+ self.Centre(wx.BOTH)
+ self.SetTitle(_("GRASS Mapcalc Statement Builder") )
+ #self.SetIcon(wx.Icon(os.path.join(imagepath,
+ # 'grass_sql.png'),
+ # wx.BITMAP_TYPE_ANY))
+ # variables
+ self.parent = parent
+ self.heading = 'mapcalc statement'
+ self.newmap = ''
+ self.funct_list = [
+ 'abs(x)',
+ 'acos(x)',
+ 'asin(x)',
+ 'atan(x)',
+ 'atan(x,y)',
+ 'cos(x)',
+ 'double(x)',
+ 'eval([x,y,...,]z)',
+ 'exp(x)',
+ 'exp(x,y)',
+ 'float(x)',
+ 'graph(x,x1,y1[x2,y2..])',
+ 'if(x)',
+ 'if(x,a)',
+ 'if(x,a,b)',
+ 'if(x,a,b,c)',
+ 'int(x)',
+ 'isnull(x)',
+ 'log(x)',
+ 'log(x,b)',
+ 'max(x,y[,z...])',
+ 'median(x,y[,z...])',
+ 'min(x,y[,z...])',
+ 'mode(x,y[,z...])',
+ 'not(x)',
+ 'pow(x,y)',
+ 'rand(a,b)',
+ 'round(x)',
+ 'sin(x)',
+ 'sqrt(x)',
+ 'tan(x)',
+ 'xor(x,y)',
+ 'row()',
+ 'col()',
+ 'x()',
+ 'y()',
+ 'ewres()',
+ 'nsres()',
+ 'null()'
+ # Init
+ # Buttons
+ self.btn_clear = wx.Button(self, -1, "Clear")
+ self.btn_help = wx.Button(self, -1, "Help")
+ self.btn_run = wx.Button(self, -1, "Run")
+ self.btn_close = wx.Button(self, -1, "Close")
+ self.btn_pow = wx.Button(self, -1, "^")
+ self.btn_pow.SetToolTipString('exponent')
+ self.btn_div = wx.Button(self, -1, "/")
+ self.btn_div.SetToolTipString('divide')
+ self.btn_add = wx.Button(self, -1, "+")
+ self.btn_add.SetToolTipString('add')
+ self.btn_minus = wx.Button(self, -1, "-")
+ self.btn_minus.SetToolTipString('subtract')
+ self.btn_mod = wx.Button(self, -1, "%")
+ self.btn_mod.SetToolTipString('modulus')
+ self.btn_mult = wx.Button(self, -1, "*")
+ self.btn_mult.SetToolTipString('multiply')
+ self.btn_paren = wx.Button(self, -1, "( )")
+ self.btn_lshift = wx.Button(self, -1, "<<")
+ self.btn_lshift.SetToolTipString('left shift')
+ self.btn_rshift = wx.Button(self, -1, ">>")
+ self.btn_rshift.SetToolTipString('right shift')
+ self.btn_rshiftu = wx.Button(self, -1, ">>>")
+ self.btn_rshiftu.SetToolTipString('right shift (unsigned)')
+ self.btn_gt = wx.Button(self, -1, ">")
+ self.btn_gt.SetToolTipString('greater than')
+ self.btn_gteq = wx.Button(self, -1, ">=")
+ self.btn_gteq.SetToolTipString('greater than or equal to')
+ self.btn_lt = wx.Button(self, -1, "<")
+ self.btn_lt.SetToolTipString('less than or equal to')
+ self.btn_lteq = wx.Button(self, -1, "<=")
+ self.btn_lteq.SetToolTipString('less than')
+ self.btn_eq = wx.Button(self, -1, "==")
+ self.btn_eq.SetToolTipString('equal to')
+ self.btn_noteq = wx.Button(self, -1, "!=")
+ self.btn_noteq.SetToolTipString('not equal to')
+ self.btn_compl = wx.Button(self, -1, "~")
+ self.btn_compl.SetToolTipString("one's complement")
+ self.btn_not = wx.Button(self, -1, "!")
+ self.btn_not.SetToolTipString("NOT")
+ self.btn_andbit = wx.Button(self, -1, '&')
+ self.btn_andbit.SetToolTipString("bitwise AND")
+ self.btn_orbit = wx.Button(self, -1, "|")
+ self.btn_orbit.SetToolTipString("bitwise OR")
+ self.btn_and = wx.Button(self, -1, "&&&")
+ self.btn_and.SetToolTipString('logical AND')
+ self.btn_andnull = wx.Button(self, -1, "&&&&&")
+ self.btn_andnull.SetToolTipString('logical AND (ignores NULLs')
+ self.btn_or = wx.Button(self, -1, "||")
+ self.btn_or.SetToolTipString('logical OR')
+ self.btn_ornull = wx.Button(self, -1, "|||")
+ self.btn_ornull.SetToolTipString('logical OR (ignores NULLs')
+ self.btn_cond = wx.Button(self, -1, "?:")
+ self.btn_cond.SetToolTipString('conditional')
+ # Text labels
+ #self.label_headding = wx.StaticText(self, -1, '')
+ # Text areas
+ self.text_mcalc = wx.TextCtrl(self, -1, '', size=(-1,75),style=wx.TE_MULTILINE)
+ # Map and function insertion text and ComboBoxes
+ self.newmaplabel = wx.StaticText(self, -1, 'Name of new map to create')
+ self.newmaptxt = wx.TextCtrl(self, wx.ID_ANY, size=(250,-1))
+ self.mapsellabel = wx.StaticText(self, -1, 'Insert existing map')
+ self.mapselect = gselect.Select(self, wx.ID_ANY, size=(250,-1),
+ type='cell', multiple=False)
+ self.functlabel = wx.StaticText(self, -1, 'Insert mapcalc function')
+ self.function = wx.ComboBox(self, wx.ID_ANY, "", (-1,-1),
+ (250, -1), self.funct_list, wx.CB_DROPDOWN
+ | wx.CB_READONLY
+ | wx.TE_PROCESS_ENTER
+ #| wx.CB_SORT
+ # Bindings
+ self.btn_compl.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_not.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_pow.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_div.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_add.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_minus.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_mod.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_mult.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_lshift.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_rshift.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_rshiftu.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_gt.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_gteq.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_lt.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_lteq.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_eq.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_noteq.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_andbit.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_orbit.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_and.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_andnull.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_or.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_ornull.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_cond.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_paren.Bind(wx.EVT_BUTTON, self.AddMark)
+ self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
+ self.btn_clear.Bind(wx.EVT_BUTTON, self.OnClear)
+ self.btn_run.Bind(wx.EVT_BUTTON, self.OnMCalcRun)
+ self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
+ self.newmaptxt.Bind(wx.EVT_TEXT, self.OnNewmap)
+ #self.mapselect.Bind(wx.EVT_COMBOBOX, self.OnSelect)
+ self.mapselect.Bind(wx.EVT_TEXT, self.OnSelect)
+ #self.mapselect.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
+ self.function.Bind(wx.EVT_COMBOBOX, self.OnSelect)
+ #self.function.Bind(wx.EVT_TEXT, self.OnSelect)
+ self.function.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
+ self.__doLayout()
+ def __doLayout(self):
+ #mcalc_box = wx.StaticBox(self, -1, "%s" % self.heading)
+ #mcalc_boxsizer = wx.StaticBoxSizer(mcalc_box,wx.VERTICAL)
+ #mcalc_boxsizer.Add(self.text_mcalc, flag=wx.EXPAND)
+ pagesizer = wx.BoxSizer(wx.VERTICAL)
+ controlsizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnpanelsizer = wx.GridBagSizer(1,1)
+ buttonsizer1 = wx.GridBagSizer(5,1)
+ buttonsizer1.Add(self.btn_add, (0,0))
+ buttonsizer1.Add(self.btn_minus, (0,1))
+ buttonsizer1.Add(self.btn_mod, (5,0))
+ buttonsizer1.Add(self.btn_mult, (1,0))
+ buttonsizer1.Add(self.btn_div, (1,1))
+ buttonsizer1.Add(self.btn_pow, (5,1))
+ buttonsizer1.Add(self.btn_gt, (2,0))
+ buttonsizer1.Add(self.btn_gteq, (2,1))
+ buttonsizer1.Add(self.btn_eq, (4,0))
+ buttonsizer1.Add(self.btn_lt, (3,0))
+ buttonsizer1.Add(self.btn_lteq, (3,1))
+ buttonsizer1.Add(self.btn_noteq, (4,1))
+ buttonsizer2 = wx.GridBagSizer(5,1)
+ buttonsizer2.Add(self.btn_and, (0,0))
+ buttonsizer2.Add(self.btn_andbit, (1,0))
+ buttonsizer2.Add(self.btn_andnull, (2,0))
+ buttonsizer2.Add(self.btn_or, (0,1))
+ buttonsizer2.Add(self.btn_orbit, (1,1))
+ buttonsizer2.Add(self.btn_ornull, (2,1))
+ buttonsizer2.Add(self.btn_lshift, (3,0))
+ buttonsizer2.Add(self.btn_rshift, (3,1))
+ buttonsizer2.Add(self.btn_rshiftu, (4,0))
+ buttonsizer2.Add(self.btn_cond, (5,0))
+ buttonsizer2.Add(self.btn_compl, (5,1))
+ buttonsizer2.Add(self.btn_not, (4,1))
+ buttonsizer3 = wx.GridBagSizer(7, 1)
+ buttonsizer3.Add(self.newmaplabel, (0,0), (1,2), wx.ALIGN_CENTER)
+ buttonsizer3.Add(self.newmaptxt, (1,0), (1,2))
+ buttonsizer3.Add(self.mapsellabel, (2,0), (1,2), wx.ALIGN_CENTER)
+ buttonsizer3.Add(self.mapselect, (3,0), (1,2))
+ buttonsizer3.Add(self.functlabel, (4,0), (1,2), wx.ALIGN_CENTER)
+ buttonsizer3.Add(self.function, (5,0), (1,2))
+ buttonsizer3.Add(self.btn_clear, (6,0))
+ buttonsizer3.Add(self.btn_paren, (6,1))
+ buttonsizer4 = wx.GridSizer(4, 3, 3, 3)
+ buttonsizer4.Add(self.btn_run,0,wx.RIGHT,5)
+ buttonsizer4.Add(self.btn_close,0,wx.RIGHT,5)
+ buttonsizer4.Add(self.btn_help,0,wx.RIGHT,5)
+ label = wx.StaticText(self, -1, 'Mapcalc operators')
+ btnpanelsizer.Add(label, (0,0), (1,2), wx.ALIGN_CENTER)
+ btnpanelsizer.Add(buttonsizer1, (1,0), (1,1), wx.RIGHT|wx.TOP, 5)
+ btnpanelsizer.Add(buttonsizer2, (1,1), (1,1), wx.LEFT|wx.TOP, 5)
+ controlsizer.Add(btnpanelsizer, 0, wx.ALIGN_CENTER_HORIZONTAL|wx.RIGHT, border=20)
+ controlsizer.Add(buttonsizer3, proportion=0)
+ pagesizer.Add(controlsizer, flag=wx.EXPAND|wx.ALL,border=10)
+ pagesizer.Add(self.text_mcalc, flag=wx.EXPAND|wx.ALL,border=5)
+ pagesizer.Add(buttonsizer4, 0, wx.ALIGN_CENTER_HORIZONTAL|wx.ALL, border=5)
+ self.SetAutoLayout(True)
+ self.SetSizer(pagesizer)
+ pagesizer.Fit(self)
+ #pagesizer.SetSizeHints(self)
+ self.Layout()
+ self.Show(True)
+ def AddMark(self,event):
+ if event.GetId() == self.btn_compl.GetId(): mark = "~"
+ elif event.GetId() == self.btn_not.GetId(): mark = "!"
+ elif event.GetId() == self.btn_pow.GetId(): mark = "^"
+ elif event.GetId() == self.btn_div.GetId(): mark = "/"
+ elif event.GetId() == self.btn_add.GetId(): mark = "+"
+ elif event.GetId() == self.btn_minus.GetId(): mark = "-"
+ elif event.GetId() == self.btn_mod.GetId(): mark = "%"
+ elif event.GetId() == self.btn_mult.GetId(): mark = "*"
+ elif event.GetId() == self.btn_lshift.GetId(): mark = "<<"
+ elif event.GetId() == self.btn_rshift.GetId(): mark = ">>"
+ elif event.GetId() == self.btn_rshiftu.GetId(): mark = ">>>"
+ elif event.GetId() == self.btn_gt.GetId(): mark = ">"
+ elif event.GetId() == self.btn_gteq.GetId(): mark = ">="
+ elif event.GetId() == self.btn_lt.GetId(): mark = "<"
+ elif event.GetId() == self.btn_lteq.GetId(): mark = "<="
+ elif event.GetId() == self.btn_eq.GetId(): mark = "=="
+ elif event.GetId() == self.btn_noteq.GetId(): mark = "!="
+ elif event.GetId() == self.btn_andbit.GetId(): mark = "&"
+ elif event.GetId() == self.btn_orbit.GetId(): mark = "|"
+ elif event.GetId() == self.btn_or.GetId(): mark = "||"
+ elif event.GetId() == self.btn_ornull.GetId(): mark = "|||"
+ elif event.GetId() == self.btn_and.GetId(): mark = "&&"
+ elif event.GetId() == self.btn_andnull.GetId(): mark = "&&&"
+ elif event.GetId() == self.btn_cond.GetId(): mark = "?:"
+ elif event.GetId() == self.btn_brackets.GetId(): mark = "()"
+ self.__addSomething(mark)
+ def OnNewmap(self, event):
+ self.newmap = event.GetString()
+ def OnSelect(self, event):
+ item = event.GetString()
+ self.__addSomething(item)
+ self.text_mcalc.SetFocus()
+ def __addSomething(self,what):
+ mcalcstr = self.text_mcalc.GetValue()
+ newmcalcstr = ''
+ position = self.text_mcalc.GetInsertionPoint()
+ selection = self.text_mcalc.GetSelection()
+ newmcalcstr = mcalcstr[:position]
+ try:
+ if newmcalcstr[-1] != " ":
+ newmcalcstr += " "
+ except:
+ pass
+ newmcalcstr += what
+ position_offset = len(what)
+ newmcalcstr += " "+mcalcstr[position:]
+ self.text_mcalc.SetValue(newmcalcstr)
+ self.text_mcalc.SetInsertionPoint(position+position_offset)
+ self.text_mcalc.Update()
+ def OnMCalcRun(self,event):
+ if self.newmap == '':
+ wx.MessageBox("You must enter the name of a new map to create")
+ return
+ if self.parent:
+ try:
+ mctxt = self.text_mcalc.GetValue().strip().replace("\n"," ")
+ mctxt = mctxt.replace(" ","")
+ cmdstr = 'r.mapcalc %s=%s' % (self.newmap,mctxt)
+ cmdlist = ['r.mapcalc', ' %s=%s' % (self.newmap,mctxt)]
+ p = os.system(cmdstr)
+ #p = gcmd.Command(cmdlist, stderr=None)
+ #print p.PrintModuleOutput
+ except:
+ pass
+ def OnClear(self, event):
+ self.text_mcalc.SetValue("")
+ def OnHelp(self, event):
+ cmdlist = ['g.manual','r.mapcalc']
+ gcmd.Command(cmdlist)
+ pass
+ def OnClose(self,event):
+ self.Destroy()
+if __name__ == "__main__":
+ if len(sys.argv) != 2:
+ print >>sys.stderr, __doc__
+ sys.exit()
+ app = wx.App(0)
+ sqlb = SQLFrame(None, -1, 'SQL Builder',sys.argv[1])
+ app.MainLoop()
