[GRASS-SVN] r30224 - grass/trunk/raster/simwe/r.sim.water
svn_grass at osgeo.org
Sun Feb 17 22:49:50 EST 2008
Author: helena
Date: 2008-02-17 22:49:50 -0500 (Sun, 17 Feb 2008)
New Revision: 30224
grass/trunk/raster/simwe/r.sim.water/main.c
default number of walkers adjusted to number of cells
Modified: grass/trunk/raster/simwe/r.sim.water/main.c
--- grass/trunk/raster/simwe/r.sim.water/main.c 2008-02-18 02:34:03 UTC (rev 30223)
+++ grass/trunk/raster/simwe/r.sim.water/main.c 2008-02-18 03:49:50 UTC (rev 30224)
@@ -49,7 +49,7 @@
/* DEFINE GLOB VAR */
-#define NWALK "1000000"
+/* #define NWALK "1000000" */
#define DIFFC "0.8"
#define HMAX "0.3"
#define HALPHA "4.0"
@@ -256,9 +256,9 @@
parm.nwalk = G_define_option();
parm.nwalk->key = "nwalk";
parm.nwalk->type = TYPE_INTEGER;
- parm.nwalk->answer = NWALK;
+/* parm.nwalk->answer = NWALK; */
parm.nwalk->required = NO;
- parm.nwalk->description = _("Number of walkers");
+ parm.nwalk->description = _("Number of walkers, default is twice the no. of cells");
parm.nwalk->guisection = _("Parameters");
parm.niter = G_define_option();
@@ -346,7 +346,7 @@
outwalk = parm.outwalk->answer;
sfile = parm.sfile->answer;
- sscanf(parm.nwalk->answer, "%d", &maxwa);
+/* sscanf(parm.nwalk->answer, "%d", &maxwa); */
sscanf(parm.niter->answer, "%d", ×ec);
sscanf(parm.outiter->answer, "%d", &iterout);
sscanf(parm.density->answer, "%d", &ldemo);
@@ -379,7 +379,7 @@
/* Report the final value of rain_val*/
- printf("rain_val is set to: %f\n",rain_val);
+ G_message(_("rain_val is set to: %f\n"),rain_val);
/* if no Mannings map, then:*/
if(parm.manin->answer==NULL){
@@ -405,7 +405,7 @@
/* Report the final value of manin_val*/
- printf("manin_val is set to: %f\n",manin_val);
+ G_message(_("manin_val is set to: %f\n"),manin_val);
/* if no infiltration map, then:*/
if(parm.infil->answer==NULL){
@@ -431,7 +431,7 @@
/* Report the final value of infil_val*/
- printf("infil_val is set to: %f\n",infil_val);
+ G_message(_("infil_val is set to: %f\n"),infil_val);
/* Recompute timesec from user input in minutes
* to real timesec in seconds */
@@ -440,15 +440,17 @@
if ((timesec/iterout) > 100.0)
G_message(_("More than 100 files are going to be created !!!!!"));
- /* compute how big the raster is and set this to appr 2 walkers per cell
+ /* compute how big the raster is and set this to appr 2 walkers per cell */
if(parm.nwalk->answer==NULL){
+ maxwa = mx*my*2;
rwalk = (double) (mx*my*2.);
+ G_message(_("default nwalk=%d, rwalk=%f"), maxwa, rwalk);
} else {
+ sscanf(parm.nwalk->answer, "%d", &maxwa);
rwalk = (double) maxwa;
- rwalk = (double) maxwa;
+/* rwalk = (double) maxwa; */
if (conv != 1.0)
G_message(_("Using metric conversion factor %f, step=%f"), conv, step);
