[GRASS-SVN] r30235 - grass/trunk/gui/wxpython/gui_modules
Mon Feb 18 10:26:31 EST 2008
Author: martinl
Date: 2008-02-18 10:26:31 -0500 (Mon, 18 Feb 2008)
New Revision: 30235
   grass/trunk/gui/wxpython/gui_modules/gselect.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/gui_modules/utils.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: user can set up mapset search path (g.mapsets -p/-l)in Preferences dialog. This variable is used in GUI dialogs. Default value is 'p' (module search path).
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py	2008-02-18 15:23:05 UTC (rev 30234)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py	2008-02-18 15:26:31 UTC (rev 30235)
@@ -22,6 +22,7 @@
 import wx.combo
 import gcmd
+from preferences import globalSettings as UserSettings
 class SelectDialog(wx.Dialog):
     def __init__(self, parent, id=wx.ID_ANY, title='Select GIS element',
@@ -159,9 +160,7 @@
         curr_mapset = gcmd.Command(cmdlist).ReadStdOutput()[0]
         #mapsets in current location
-        cmdlist = ['g.mapsets', '-p']
-        mapsets = gcmd.Command(cmdlist).ReadStdOutput()[0].split(' ')
+        mapsets = UserSettings.Get('mapsetPath', internal=True)
         # map element types to g.mlist types
         elementdict = {'cell':'rast',
                        'raster':'rast',
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-02-18 15:23:05 UTC (rev 30234)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-02-18 15:26:31 UTC (rev 30235)
@@ -28,6 +28,7 @@
 import gcmd
 import grassenv
+import utils
 class Settings:
     """Generic class where to store settings"""
@@ -39,6 +40,7 @@
         self.defaultSettings = {
             # general
             'displayFont' : '',
+            'mapsetPath' : 'p', # current mapset search path
             # advanced
             'settingsFile' : 'gisdbase', # gisdbase, location, mapset
             'digitInterface' : 'vdigit', # vedit, vdigit
@@ -54,6 +56,19 @@
         except:
             gcmd.SettingsError('Reading settings failed.')
+        # internal settings (based on user settings)
+        self.internalSettings = {}
+        self.internalSettings["mapsetPath"] = self.GetMapsetPath()
+    def GetMapsetPath(self):
+        """Store mapset search path"""
+        all, access = utils.ListOfMapsets()
+        if self.Get('mapsetPath') == 'p':
+            return access
+        else:
+            return all
     def ReadSettingsFile(self, settings=None):
         """Reads settings file (mapset, location, gisdbase)"""
         if settings is None:
@@ -137,25 +152,35 @@
         return filePath
-    def Get(self, key):
+    def Get(self, key, internal=False):
         """Get value by key
         @return value
         @return None if key not found
-        if self.userSettings.has_key(key):
-            return self.userSettings[key]
+        if internal is True:
+            settings = self.internalSettings
         else:
-            None
+            settings = self.userSettings
+        if settings.has_key(key):
+            return settings[key]
+        return None
-    def Set(self, key, value):
+    def Set(self, key, value, internal=False):
         """Set value by key
         Raise KeyError if key is not found
-            self.userSettings[key] = value
         else:
+            settings[key] = value
+        else:
             raise KeyError
 globalSettings = Settings()
@@ -238,6 +263,25 @@
                        wx.ALIGN_CENTER_VERTICAL,
                        pos=(1, 0), span=(1, 2))
+        # mapsets path
+        gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                         label=_("Mapsets path:")),
+                       flag=wx.ALIGN_LEFT |
+                       wx.ALIGN_CENTER_VERTICAL,
+                       pos=(2, 0))
+        self.mapsetPath = wx.Choice(parent=panel, id=wx.ID_ANY, size=(200, -1),
+                                      choices=['mapset search path', 'all available mapsets'])
+        if self.settings.Get('mapsetPath') == 'p':
+            self.mapsetPath.SetSelection(0)
+        else:
+            self.mapsetPath.SetSelection(1)
+        gridSizer.Add(item=self.mapsetPath,
+                      flag=wx.ALIGN_RIGHT |
+                      pos=(2, 1))
         sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
         border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=3)
@@ -245,7 +289,8 @@
         # bindings
         fontButton.Bind(wx.EVT_BUTTON, self.OnSetFont)
+        self.mapsetPath.Bind(wx.EVT_CHOICE, self.OnChangeMapsetPath)
         return panel
     def __CreateAdvancedPage(self, notebook):
@@ -370,6 +415,16 @@
         event.Skip()
+    def OnChangeMapsetPath(self, event):
+        """Mapset path changed"""
+        if event.GetSelection() == 0:
+            self.settings.Set('mapsetPath', 'p')
+        else:
+            self.settings.Set('mapsetPath', 'l')
+        # update internal settings
+        self.settings.Set("mapsetPath", self.settings.GetMapsetPath(), internal=True)
     def OnSave(self, event):
         """Button 'Save' clicked"""
         self.__UpdateSettings()
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py	2008-02-18 15:23:05 UTC (rev 30234)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py	2008-02-18 15:26:31 UTC (rev 30235)
@@ -17,6 +17,13 @@
 import os
 import sys
+try:
+    import subprocess
+except:
+    compatPath = os.path.join(globalvar.ETCWXDIR, "compat")
+    sys.path.append(compatPath)
+    import subprocess
 def GetTempfile(pref=None):
     Creates GRASS temporary file using defined prefix.
@@ -139,19 +146,29 @@
     import gcmd
     all_mapsets = []
     accessible_mapsets = []
+    ### FIXME
+    # problem using Command here (see preferences.py)
+    # cmd = gcmd.Command(['g.mapsets', '-l'])
+    cmd = subprocess.Popen(['g.mapsets', '-l'],
+                           stdout=subprocess.PIPE)
-    cmd = gcmd.Command(['g.mapsets', '-l'])
     try:
-        for mset in cmd.ReadStdOutput()[0].split(' '):
-            all_mapsets.append(mset.strip('%s' % os.linesep))
+        # for mset in cmd.ReadStdOutput()[0].split(' '):
+        for mset in cmd.stdout.readlines()[0].strip('%s' % os.linesep).split(' '):
+            if len(mset) > 0:
+                all_mapsets.append(mset)
     except:
         raise gcmd.CmdError('Unable to get list of available mapsets.')
-    cmd = gcmd.Command(['g.mapsets', '-p'])
+    # cmd = gcmd.Command(['g.mapsets', '-p'])
+    cmd = subprocess.Popen(['g.mapsets', '-p'],
     try:
-            accessible_mapsets.append(mset.strip('\n'))
+            if len(mset) > 0:
+                accessible_mapsets.append(mset)
     except:
         raise gcmd.CmdError('Unable to get list of accessible mapsets.')
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-02-18 15:23:05 UTC (rev 30234)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-02-18 15:26:31 UTC (rev 30235)
@@ -46,6 +46,7 @@
 import utils
 from debug import Debug as Debug
 from icon import Icons as Icons
 try:
     import subprocess
 except:
@@ -1483,9 +1484,10 @@
         bodySizer.Add(item=wx.StaticText(parent=self, label=_("Mapset:")),
                       flag=wx.ALIGN_CENTER_VERTICAL,
                       pos=(1,0))
         self.mapset = wx.ComboBox(parent=self, id=wx.ID_ANY,
                                   style=wx.CB_SIMPLE | wx.CB_READONLY,
-                                  choices=utils.ListOfMapsets()[0],
+                                  choices=UserSettings.Get('mapsetPath', internal=True),
                                   size=(200,-1))
         self.mapset.SetStringSelection(grassenv.GetGRASSVariable("MAPSET"))
         bodySizer.Add(item=self.mapset,
